Question about Kohler Home
Hissing concealed cistern
I have a 4 year old toilet which has a Kohler seat but a concealed cistern - I don't know if this is Kohler or not. It hisses due to the valve being open and water in concstantly running into the cistern. I've taken what I can off of the cistern to get a look inside and it seems to me that the part that turns the water off won't rise on its own - which if I lift it the water stops running. If I let go, it starts to run again. It has a lever which must bend to turn the water off but it does not rise to turn the water off itself. What do I need to do to fix this? To get to the whole cistern I have to remove my countertop, toilet base and an enclosure.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
The float valve needs adjusted or replaced.
Posted on Nov 30, 2014
SOURCE: Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Posted on Jan 10, 2009
  • 16 Answers
SOURCE: toilet cistern doesn't fill up
it sounds like one or more of your shut off valves has a glog from hard water calcium. were from indiana its a big problem here.To check this u will have to shut off main water supply and remove top of shut off valve and check for white crusty blockage, even if u see a few particals its present. It can severely restrict flow.
Posted on May 03, 2009
gypsycat00
  • 224 Answers
SOURCE: toilet fill runs periodically works well but wastes water
Sounds like your flapper is leaking causing the water in the tank to lower until it triggers the fill valve. Replace the flapper (they're cheap and wear out easily).
Posted on Jul 04, 2009
SOURCE: Toilet won't stop running
I have a Kohler toilet and Ingenium fill valve 85297-AA. My toilet kept running, the fill valve black cylinder wouldn't pop up and when I added blue food coloring to the tank, the blue color seeped through to the toilet bowl. First I replaced the flapper and that allowed the fill valve piece on the cylinder to pop up correctly and blue dye no longer seeped through to the bowl. I still heard a hissing sound when the toilet tank had filled and no water was going into the overflow tube. I called the tech support number on the Kohler website 1-800-4KOHLER (1-800-456-4537) . Here's what solved the problem: Turn off the water to the toilet.Take off the white cap of the fill valve by pushing it down and turning it counterclockwise as you would open up a childproof pill container. Then unhook the metal hook. Hold a cup upside down (I used a strong plastic cup) over the part of the fill valve that is left in the tank and turn on the water. (You need the cup because otherwise the water will squirt up to the ceiling.) The water will flush out the fill valve. Replace the cap and the hook and flush.
Posted on Aug 07, 2009
SOURCE: my toilet cistern is continually hissing
Hi I have exactly the same problem, in fact it could have been me writing this - 3 toliets fine, main bathroom hisses. The Geberit flushing ciphen on the left (the smaller one) has been replaced and there is still a problem. If you look carefully,the water level needs to come up over the lip of an opening on the Geberit part and this causes the valve mechanism to shut off and stop the hissing. It is fine for about 40 minutes and then the hissing starts again if you don't flush it. The reason is that the water level has gone down but there is no obvious signs of where the water is going. It could be that the central flush mechanism is leaking slightly. I am going to replace this part next. If I were you I'd see if you are getting any water leakage into the pan when toilet not in use to see if the water level in the cistern is going down James T
Posted on Oct 31, 2009
I have a leak coming through my ceiling from the ensuite toilet above. It is an ideal standard wall hung with concealed cistern behind tiles. There is no obvious access panel. The tiled wall is flush.
The flush control panel normally comes off. You can then hopefully see inside. You won't be able to see much though as the cistern will be in the way...
Places to look for leaks are:
Soil pipe to pan
Cistern to flush pipe
Flush pipe to pan
Cistern overflow.
Apr 17, 2017 | Home
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 | Home
Water level too high in Gruppo Italia in-wall cistern
check if mechanism that releases water when you flush is tight so no water escapes.
As for water level, you can adjust to less in the tank.
Jul 27, 2013 | Kohler Toilet - One Piece with Ingenium...
Villeroy and boch toilet parts
attach 2X4s behind it to ensure its stable. I had same problem but used that wood to reinforce it (covered with hardy board & paint) and reattached it and wall is very strong and toilet does not move.
Apr 27, 2013 | Villeroy & Boch 9955 S1 Subway Toilet Seat...
I have a hissing toilet. My kohler 4708 fills up, and once this happens, the left side of the tank has a constant hissing sound. When I turn off the water it stops.
Your valve inside the tank has worn down and not allowing the water to stop running. Does the water run over the top of the overflow. If so, then adjust your inlet water to a lower level so it will cut off. If that is ok, then likely the flapper is worn out and needs to be replaced.
Feb 19, 2013 | Kohler Home
Toliet seat lid doesnt drop slowly anymore ( 4 yrs. old )
Either live with it or replace it. The hinge is not serviceable and the soft close action does not last forever. They rarely last more than five years, maximum.
Jun 19, 2011 | Kohler Toilet Seat - Elongated Front Quiet...
The Rialto toilet makes it very difficult to replace the seat as you cannot access the wing nuts which in a moment of engineering genius you put inside the bowl I have already purchased a French seat to...
You should be able to remove the tank lid, reach into the cistern and find submerged at the bottom towards the front of the toilet the plastic wing nuts, hold onto these while tightening the plastic bolt from the top.
I have a Kohler toilet with a similar design, not sure if it is this exact model but they look very similar so I hope this works for you.
Apr 18, 2011 | Kohler 3386-6 Rialto Skylight Round Front...
Get seat of Kohler K-3386
Roberta3fan could be giving bad advice based on experience with other toilets. This does not seem to be an option for this toilet design. I am in a similar situation and it appears that the nut (and it is a metal bolt) is not what you would expect. Here is a picture of the anchor kit for this toilet seat: http://www.plumbingsupply.com/images/kohler-anchorkit-84999.jpg I am going to assume that the sleave that should be engaging the bolt is cross threaded and try to grab it with a pair of vice grips. I'll let you know if it works.
Jan 09, 2010 | Kohler K-3386-0 Rialto one-piece...
Push button not operating fully/correctly. cistern flushes sometimes, but not always and is only two years old. It's a Grohe concealed cistern.
hey,
Check your button/s panel, check that the hoses are connected firmly.
Disconnect the hose and blow air through it, does it work now?
If it works ok, you need a new buttons panel. (or fix it).
If problem remains, you need to disassemble the pneumatic valve and check / clean/ repair it.
Look at this guide that might help you. though it is not the exact model, principle is the same.
Have fun
Avi
Grohe GD2 flush system concealed cistern repair fix and disassembly...
Nov 23, 2009 | Grohe Home
Home Logo
324 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
