Question about Electrolux Vacuums
My washing machine electrolux typeEWF1421 show Error E60
To clean the filter
  • 937 Answers
Did you go thru the procedure to delete the code yet? Here is a general guide on troubleshooting with codes, but E50-E79 show as service calls only
http://www.electrolux.im/Files/international_english/QuickWins/TroubleShooter/Document/ReadCodeWasherWithDisplay.pdf
Posted on Nov 30, 2014
Where does the belt go on the Electrolux el8807
EL8807 no belt, separate motor for brush, use reset button. Call customer service, see my other post with the number.
Sep 30, 2014 | Electrolux EL8807A Precision BrushRoll...
Self clean and power lights flashing on electrolux
you either need new filters or you have a bad electronic board or possibly both. Most of these machines only last a couple of years. Not to discourage you, but do yourself a favor and don't buy another one. It's a chinese made Eureka with a lux label. Electrolux went bankrupt many years ago and Eureka bought the name. Miele, Sebo, Riccar, or Lindhaus are all better choices.
Oct 19, 2013 | Electrolux Twin Clean Bagless Canister...
Electrolux Epic Series 6500 SR. The machine is 15 yr. old & is working beautifully. However, when operating it emits a terrible stink, like cat *****. I've changed bags & filters but no ch
You need to have the vacuum cleaned out. If you are good with tools, just remove the motor and fans assembly, take the fans off and wash them. Brush ALL dirt out of the housing and reassemble. Your Electrolux dealer can do this but it isn't cheap. I used to be the service manager for my area. Since it isn't under warranty, you can have ANY reliable vacuum cleaner shop give a good cleanout. NEVER put anything into the cleaner to make it smell good. Electrolux cleaners get their power by having a straight through suction. The air goes through the motor. Adding smelly things can crystallize onto the motor and burn it out.
Jan 17, 2013 | Electrolux Epic 6500 Vacuum
How to clean a washable electrolux filter
Hi There,
Ok so i am going to assume you are talking about an Electrolux filter that is basically a rectangle shape with a hard plastic outer and folded corrugated filter material in the middle. The link I put to Electrolux filter would be a good example. Basically I would caution you against washing it. I know the packaging says that it is washable but what I have found is that the pores of the filter material are too fine for water to pass through. What will happen is that the vacuums suction will wedge tiny bits of dirt and dust in the pores and water will not necessarily flush it out. What is far more likely to happen is that it will wash out a fair amount but leave a portion in the filter to set and therefore continue to block suction.
You are better to use an air compressor or simply tap the filter out on a piece of newspaper and change it every year or so.
Of course if your filter is more like a Electrolux UltraActive filter which is basically foam then you simply rinse it out like a kitchen sponge and make sure it is bone dry before putting back in the machine.
Jun 26, 2012 | Electrolux Ultrasilencer Green Canister...
My daughter cleaned up the babys ***** with vacum now it smells lie throwup everytime we use vacum.we cleaned the hoses still smells .I thinits in the motor .can i clean the motorany suggestions before i...
SInce the damage is done we cannot but think of a solution. It seems the internal filters , the hose and possible the linings within can be slightly clogged.
The only option left to us is to get the above sections cleaned, the filter replaced, the motor flushed with a wash of kerosene-- you must remove the motor and carefully wash and dry all the parts, the hose and replace the filters.
I am sure you can use surgical gloves and mask in case the odour is annoying but it is worth trying before you need to dump a good machine.
Good Luck
Aug 19, 2011 | Electrolux Cleaner Lux 6000 Vacuum
I have a electrolux Pronto 2 in 1 and the suction really never seems strong plus the brush in the base doesn't turn and the vacuum has been plugged in for two days. how can I get more suction and make the...
There is a filter inside the main filter. Once that filter gets clogged it will loose suction. Pull the filter and clean it, you can wash it by hand. Turn the unit roller side up and check for a small screw cover that you can use a dime to loosen. This cover is used to remove the roller unit. Once out check and clean then check the gear assy. for miss-alignment.
Jan 24, 2011 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Electrolux canister vaccum 2100
The filter for your Electrolux 2100 is located on the rear top of the machine. It is covered by a plastic grill. You simply place your finger in the rear of the plastic grill, push the tab in slightly and lift the grill up to expose the filter. The filter is approximately 4" by 6". It is NOT washable. Most Vac Shops sell replacement filters in addition to them being available at the local Electrolux distributor.
Jul 06, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
121 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
