Ic tea1506p new &mosfet k2645 new or ok
SOURCE: i have a sansui tv set with a power problem .
Hello
W11NB80 is an N-channel 800V-0.65ohm - 11A - rated Metal Oxide Semiconductor Field Effect Transistor [MOSFET]. You can use the folowing substitutions for it
[ 11NM-80, 12NK-80 & 10NC-802]. All of these are its equalent substitutions.
Before replacing the mosfet, check the entire power supply secion for any short circuit, or zener diodes faults. If any of the zener diodes are fused, it will run out the MOSET you sumstitue again. Check it keenly. Unsolder one end of each component, lifit it up a liile from the circuit board and check. Especially zener diodes must not show any leak in 100Kohms range. It is best to replace them all I suggests.
I don't know about its availability in Keniya, yet you try to get it from any electronic spare part shops. f feels any difficulty in getting the same contact [E-Bay] site, they will reach you the exact component at your doorstep. Ok.
SOURCE: LG vertical failiure vertical line at the bottom of the crt
replace the vertical driver ic and the proccesor ic
SOURCE: ABOUT PHILIPS TELEVISION
The 8V at pin 36 won't show unless there is oscillation, the primary voltage pin is pin 10, 8v. Don't mind me asking, you have checked the B+, right? Because the blinking LED is often because of power supply problems. And if that's okay, desolder the horizontal driver output legs and connect an LED to find if it is oscillating, if it does, forget the ic part and move on with the FBT and things. Good luck.
SOURCE: philips 32pw9617 crt no picture on analog channels but sound ok
this is your tuner board faulty replace tuner board hope this helps
SOURCE: TV LOEWE 8784. Died SPP11N60S5 in the power
Hi, There could be a problem with the main board. Power not getting where its supposed to go.
Go see a Hy tech repair man.
