How do I replace a Honeywell ST6300A programmer
    Sergeant:
  • 340 Answers
Peter there will be a couple of retaining screws on the bottom attaching it to a back plate. Then it should lift off and the new one goes onto it.
Posted on Nov 30, 2014
How do you program the Honeywell RTH 2410B1019 thermostat for a heat pump.
5-1-1 Day Programmable Thermostat - Honeywell
yourhome.honeywell.com/.../thermostat/5-1-1-day-programm...
HoneywellSet the Honeywell 5-1-1 day programmable thermostat to your maximum comfort settings. Works with heat pump systems. Buy now!
Nov 18, 2015 | Honeywell Heating & Cooling
Replace a honeywell t822l1000 with a programmable unit
Match the thermostat wires to the letters on the new thermostat terminals R Red Y yellow ETC.
Nov 16, 2014 | Honeywell T827K1009 Mercury Free EconoStat...
Honeywell st6300a
change the battery if it has a back up one
May 27, 2014 | Heating & Cooling
Correct signal does not seem to be sent from the controler to the boiler,either CH comes on or HW but not necessarily when they are supposed to. Boiler engineers have been out twice and both times advise...
we had one of these and found out the battery inside had failed. the battery is none replaceable. did try to replace it but it lost its memory and was only good as a switch. think when the battery fails it loses it memory and things start going wrong. so would say change it. now thinking on it should of changed the battery why having the old one on and taken the old one off after installing the new one.
Mar 03, 2014 | Honeywell Programmable Thermostat Heater
Operating manual honeywell rth2310
Honeywell has the manual for the RTH2310 programmable thermostat on the product page: http://yourhome.honeywell.com/home/Products/Thermostats/5-2-Day-Programmable/RTH2310B.htm . The direct link to the English/French version of the operating manual is http://customer.honeywell.com/techlit/pdf/PackedLit/69-2229EF.pdf .
I hope this helps.
Dec 13, 2011 | Honeywell Programmable Thermostat Heater
Honeywell time control st6300a
A basic thermostat such as this will only have 3-5 wires that are used on it. First, shut off the power to your furnace, usually by a switch close to it, or with the breaker for it. Red will go to the R terminal, White to the W, Green to the G. Some techs will use blue for the Y terminal, or yellow if it's available, if blue or black is left over and you have a C terminal on your Thermostat, place it there. Hope this helps.
May 10, 2009 | Honeywell Focus 6300B 5-2 Days...
Replacement of heating programmer
yea you should be able to just when you remove the old one mark witch wire went to witch connection by marking it some how i personaly take one wire at a time wrap it with a small piece of white tape and write the letters on the piece of tape then when i replace with the new one i cant mess it up also look for any of the wire connections to see if any have to be or have been jumped out
Nov 14, 2008 | Honeywell Water Heaters
Honeywell st7000
what type of system do you have? cool/gas heat, heat pump, electric cool & heat. split system or package unit?
Mar 14, 2008 | Honeywell Programmable Thermostat Heater
Honeywell programmer gone dead
lift the face plate off and change the batteries
Jul 07, 2017 | Honeywell 2-way Oscillating Ceramic Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
