Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
How do I activate the auto install tab which is greyed out in set up?
Went through reset process and can only tune in one radio station?
  • 937 Answers
Try unplugging the set for a few moments then rerun set up. You need some kind of input to the TV - either cable, satellite, or an antenna.
Posted on Nov 30, 2014
Forgot how to programme radio stations on Philips Micro System MC-222
Tuning to radio stations
  1. 1 Select TUNER source. ? TUNER is displayed briefly.
  2. 2 Press BAND once or more to select your
    waveband.
  1. 3 Press down on TUNING a? or a? and release button.
    ? The radio automatically tunes to a station with sufficient reception. Display indication during automatic tuning: SEARCH.? If a FM station is received in stereo, STEREO is shown.
  2. 4 Repeat step 3 if necessary until you find the desired station.
To tune to a weak station, press TUNING briefly and repeatedly until you have found optimal reception.
Programming radio stations
You can store up to a total of 40 radio stations in the memory.
Automatic programming
Automatic programming will start with a chosen preset number. From this preset number upwards, former programmed radio stations will be overridden.The system will only programme stations which are not in the memory already.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to select the preset number where programming should start.
Note:
- If no preset number is selected, default is preset (1) and all your presets will be overridden.
Press PROGRAM for more than 2 seconds to activate programming.? AUTO is displayed and available stations are programmed in order of waveband reception strength: FM followed by MW and LW.The last preset automatically stored will then be played.
Manual programming
Tune to your desired station (see "Tuning to radio stations").
Press PROGRAM to activate programming. ? PROGRAM flashes in the display.
Press PRESET 3 or 4 (on the remote control ¡ or TM ) to allocate a number from 1 to 40 to this station.
Press PROGRAM again to confirm the setting. ? PROGRAM disappears, the preset number and the frequency of the preset station are shown.
Repeat the above four steps to store other stations.
Jun 19, 2016 | Philips Audio Players & Recorders
How do I set the radio station buttons?
Generally tune the radio to the desired station and then choose the button and hold it pressed. The sound will momentarily disappear and then return. When it returns the button will be tuned to that station.
Your radio might be different but all the digital radios I have encountered use that process.
Apr 16, 2016 | Car Audio & Video
How to I delete an occupied preset and enter another channel
My experience has always been to replace the current station preset with the new.
I recall two process:
  1. The first locate the new station that you want and tune the radio to the station. Press and hold the specific preset for several seconds to replace the old station with the new.
  2. Tune the radio to the new station and press the set button if so equipped and than press the preset button. In some radios they have group 1 and group 2. In that case press the set button once for set 1 and press it twice for set 2 and then press the preset button.
Hope this has helped?
Jan 12, 2016 | Cars & Trucks
Radio no longer has any volume: Resets suggested dont work. How to pull this sucker apart?
It sounds like your radio has had its hospitality mode activated. The hospitality mode is a mode which is often used by hotels or similar establishments, who wish to set a maximum volume limit on the radio. To remove this volume limiter follow the steps below.
Turn the unit on
Turn the volume down to minimum, 00, volume
Press and hold power for 10 seconds until volume numbers flash
Turn the volume back up to 50 (max volume)
Press power again to verify new max volume position
Jun 03, 2015 | Boston Acoustics Horizon Solo Clock Radio
How to program the radio in a 96Lincoln continental after battery was disconnected
Here is the link to the owners manual which you can download if you wish:
http://owner.ford.com/servlet/ContentServer?pagename=Owner/Page/OwnerGuidePage&year=1996&make=Lincoln&model=Continental
Here/below are the specific instructions on the radio programming (pg. 159 of above link).
Good luck & please flag if "HELPFUL". Thanks!
(from section) Luxury Audio System
Selecting the AM or FM frequency band
Push the "AM" or "FM1/FM2" button to select the desired frequency band. Pushing the "FM1/FM2" button more than once will alternate between FM1 and FM2. These functions are used with the station memory buttons described under How to tune radio stations.
HOW to tune radio stations
There are four ways for you to tune in a particular station. You can use the "TUNE", "SEEK", 'SCAN"or memory buttons.
• Using the "TUNE" function:
You can change the frequency up or down one increment at a time by Pressing and releasing either the left (< arrow/up) or - right (> arrow/down) side of the "TUNE" or "TUNE DISCS" button. To change frequencies quickly, press and hold down either the right or left side of the button.
Manual tuning adjusts your radio to any allowable broadcast frequency, whether or not a station is present on that frequency. (See All About Radio Frequencies in this section.)
• Using the "SEEK" function
: Press the right *) side of the "SEEK" button to select the next listenable station up the frequency band. Press the left (.4) side of the button to select the next listenable station down the frequency band. By holding the button down, listenable stations can be passed over to reach the desired station. Pressing the "SCAN" button will begin the scan mode up the frequency band, stopping on each listenable station for approximately five seconds. To stop the scan mode on the presently sampled station, press the "SCAN" button again.
Setting the station MEMORY PRESET buttons
: Your radio is equipped with 6 station memory buttons. These buttons can be used to select up to 6 preset AM stations and 12 FM stations (6 in FMI and 6 in FM2)
1. Select a band, then select a frequency.
2. Press one of the memory buttons and hold until the sound returns and the lamp above the memory button lights up. That
memory button is now set.
3. Follow the above steps for each memory preset button.
NOTE:
Custom memory presets can be recalled using the keyless entry system. See Memory Profile System in the Features chapter.
Using the Automatic Memory Store feature ("AUTOSET")
: If the memory buttons have been set, either by using the Auto Memory Load feature or if you have set them manually, the system is prepared tolet you use a convenient feature called Automatic Memory Store.
With Auto Memory Store, you can continually set strong stations into your memory buttons without losing your originally set stations. Your radio will automatically set your memory buttons to the strong local stations.
Activate Auto Memory Store by pushing the "AUTOSET" button once. Your radio will set the first six strong stations of the band you are in (AM, FMI or FM2) into the memory buttons. The display will flash "AUTO" and display the autoset icon "A" while the stations are being set in the memory buttons.
NOTE: If there are less than six strong stations in the frequency band, the remaining unfilled buttons will store the last strong station detected on the band. After all stations have been filled, the radio will begin playing the station stored on memory button 1.
To deactivate the Auto Memory Store mode and return to the manually-set memory button stations, simply push the "AUTOSET" button. Display will show "AUTO" then "OFF". The next time Auto Memory Store is activated on that band, the radio will store the next set of six strong stations.
Nov 23, 2014 | 1996 Lincoln Continental
How do I change the radio station on my pioneer vsx-d903s
Welcome to FixYa.
You need to use the remote control to access the radio station frequencies.
Follow the instructions below:
Thank you for using Fixya. Have a great day!
Jas247
Jul 23, 2011 | Audio Players & Recorders
How come i cant find the radio for my Phillips go gear vibe?
From the main menu, select the icon that looks like a little radio
To search for the next stronger signal, press and hold the up or down arrow
To fine tune the frequency, briefly press the up or down arrow
From the main menu, select to enter
radio mode.
• The earphones cable acts as FM
antenna.
Manually tune a radio station
While in mode, you can manually tune to a
radio station:
1 To search for the next stronger signal,
press and hold / .
2 To fine tune the frequency, briefly press
Auto-tune preset radio
station
The auto-tune feature of GoGear Vibe helps
you find radio stations and save them under the
preset numbers.
1 While in mode, select [Auto tune] >
[Yes].
»» The radio automatically tunes radio
stations and saves the frequencies to
presets.
»» There are 20 presets available.
»» To stop auto tuning, press .
»» To exit radio, press and hold for 2
seconds.
EN
Jan 09, 2011 | Philips GoGear ViBE Digital Media Player
I can't figure out how to set the radio station pre sets
hi,
there is no auto presetting available. u have to set all channels in preset manually. if u power off the subwoofer all setting will be erased.for manual preset do the following.
1. Press the FUNCTION button to select "TUNER".
2. Press the FM/AM button to select a band.
3. Select the station you want to listen to (Hold down the TUNING Up or Down button until the
frequency display begins to change. When a station is tuned in, the tuning process will stop automatically.)
when it tune the first station available do the following to preset it,
4 .Press the MEMORY button.( on remote)
5. Within 5 seconds, select a preset channel to store the
station using the PRESET buttons of the remote control
unit.
6. Within 5 seconds, press the MEMORY button.(The station is stored and the MEMORY indicator goes off. To store more stations, repeat steps 3 to 6) .
for listening preset ed station ,Press the PRESET button repeatedly until the desired
preset station is found.
ok
Dec 24, 2010 | Teac CD-X9 Shelf System
Options to auto-tune or manual re-tune are greyed
Problem solved!!
According to the Sony website I needed to get a software download in order to fix this problem. I found out how to do this from the manual and realised that the re-tune menu I was looking at was for analogue only. The pictograms onmy remote control are a blurred but the manual helpfully provided a picture showing the correct program "info" button (next to 0) which has options to look at other things, including a "detailed set up" menu on the blue tab, which provides options for software download and re-tune of digital channels.
Incidentally, I discovered that my TV model was not quite as quoted above - it is KD-28DX200U, but expect the same process works for other oldish models.
Oct 01, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
How do I preset individual radio station frequencies?
To set individual presets: 1. tune to the station you want as a preset 2. hold down the number (ie "1") on the remote until the number blinks on the system 3. repeat for all other stations
press the number on the remote to tune to your preset
this is very similar to setting the presets on my car radio
May 04, 2009 | JVC FS-D88 Shelf System
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
59 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
