Question about KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher
Kitchenaid D/W will not start, lights not all working, getting power. What's my problem?
Turned off power at panel box for a few hours, tried to reset, all lights are not coming on when selected, will not start.
  • 7 Answers
Sylvia.....is the clean light flashing or any other for that matter? Either way it sounds like the control board is locked up. There are many posts on here about how to reset it. Try the following: With the door open:
Push Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry (all the lights should light up) then close the door and hit cancel. Push the buttons as fast as you can - within 4 seconds. This will unlock the control board and you should be able to restart the dishwasher. There are many issues with this Kitchenaid including the door popping open during cycle issue. I have dealt with all of them over the past 8 years of ownership. Finally replaced it with a used Miele and sold the KA on craigslist with full disclosure of all the issues and it's history. I even threw in the rubber door stopper that we resorted to using to keep the door closed. Let us know if the above procedure works for you. Good Luck.
Posted on Nov 30, 2014
Testimonial: "Tried the reset procedure, did not work, no lights. Only lights on with my selecting is normal and sani rinse."
  • Tom Giardino Nov 30, 2014
    Sylvia, you can try this as well. first turn off the Breaker to cut power then wait a few minutes then turn back on, then within 6 seconds try (Heated dry)(normal)(heated dry)(normal).. all lights should light up then you know that you are in the service cycle, and the unit should go into a self test and clear the fault. The test take about 30 minutes.
  • 1314 Answers
SOURCE: Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Posted on Jan 01, 2008
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Posted on Mar 25, 2008
  • 2318 Answers
SOURCE: KitchenAid 24 in. KUDI01ILBS...
The motor could be defective on this appliance and will need to be replace, it could also have a defective thermal fuse.
Posted on Apr 01, 2008
SOURCE: dishwashwer won't start and can't reset to restart
Check the float. (dome shaped thing inside the washer) Mine was stuck but as soon as I lifted up on it and then reseated it I was able to return to normal. Almost too easy. Saved $!
Posted on Apr 23, 2009
  • 37 Answers
SOURCE: kitchenaid dishwasher, control panel is not
I don't know your technical ability, but there is a fuse located next to the control board inside the console, this is a good place to start. Kitchen Aid is good about putting tech sheets on the back of the kickplate and it should have wiring and diagnostic info there. Just be sure to put the sheets back so the next service tech to work on it will have them :)
Posted on Sep 01, 2009
I have a Kitchenaid KUDC25CHSSI and the cancel light flashes continuously, and will not stop unless I leave the dorr open for an hour or more. When I try to run it through a cycle, it fills with water...
Try turning the power off at the fuse box and leave it off for about 20 minutes or so, then turn it back on. There may also be a reset procedure in your manual. If the power cut off doesn't work, try to reset. If that doesn't work you probably will have to replace the touchpad.
Oct 30, 2013 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a Kitchenaid kuds25shwh1 which doesn't start because the childlock was on. I followed all the suggestions offered and lastly turning the power off to reset. After turning the power back on a...
Getting it out of child lock can be difficult but make sure you watch the light on the front panel it will go right back to lock if your not careful.I had to try several times at first I thought it would need a doctor.. but with patience it should work and unlock with the 4 second hold.. power down does not reset unless you wait 30 minutes or longer.. hope this helps
Oct 08, 2013 | KitchenAid 24 in. KUDI01FL - Multiple...
Pioneer PDP5050Hd -- Starting up. Please Wait.
Try unplugging set for a while and also disconnect all cables, seen a few where something on one specific .1 type channel confuses the set and locks it up, if you get it working go in the menu and delete that channel.
Aug 28, 2012 | Televison & Video
Kitchenaid kud101tj "cancel drain" light and "Rinse Only" lights are falhing and DW won't start???
Don't know if this will help, but when I had problems with my control panel (lights blinked and nothing worked) I fixed it by disconnecting the power completly from the dishwasher at the fuse box. Leave it off 10 or 15 minutes and then repower. That reset mine and it worked again...has happened several times and each time I could fix it by cutting the power. If that doesn't work, you may need a new control panel.
Sep 11, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Our kitchenaid dishwasher model: kudio1lbl6, doesnt work. no lights, there is power at its box
Dishwasher does not work. The power is on but when you push start it doesnt go on. When you hit cancel it goes on for a few seconds then shuts off.
Sep 04, 2010 | KitchenAid Dishwashers
My sony bravia tv will not turn on, the light on the bottom comes on but the screen is completely blank. i was watching it two hours earlier and i turned it off myself. than it didnt work when i tried...
Do you have...a dvd player a ps3 a box?
Becouse if you have, you need to change the input and maybe you forget to put it right back.
Imagine you have a ps3, you have to change the input from tv to HDMI right..well if stop play or watcha movie and torn off the LCD...when you came again the next day the LCD starts as HDMI and not as TV.
You need to change the input...
Hope it helps, if the problem persists it´s a malfuncion...
bye
Cyber
Mar 27, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
No power to Toshiba A60
Make sure the laptop is off, pull the battery, and just power it up with the AC adapter. Once you get it going, head over to the control panel, and check the settings in power management. It could be that the settings are wrong and it will not let you start it up with the battery installed.
May 04, 2009 | Toshiba Satellite A60 Notebook
F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
Oct 27, 2008 | KitchenAid Architect Series KEBC107KSS...
Jan 13, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
KitchenAid 24 in. KUDS01FLSS Built-In Dishwasher Logo
215 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
