Question about Teac Televison & Video
My TEAC LED TV LE 4087FHD turns on intermittently.I need to turn power off and on several times for the tv to switch on. Any suggestions?
I have replaced batteries in remote controller
    Top Expert:
  • Teac Master
  • 74,136 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
SMPS start voltage problem. Check all the reisistors; that supply the initial voltage to SMPS control section; at switch ON. Contact any service technician.
Posted on Nov 30, 2014
cammykins
  • 149 Answers
SOURCE: Toshiba CT-852
A universal remote would cure this problem. It's generally since they are on the same system or IR codes are similar. There isnt much you can do to fix that problem unless you have a seperate universal remote to opperate seperately.
Posted on Sep 24, 2007
SOURCE: Sylvania lc370ss9 remote problem, comcast
you have to turn off the power save setting
Posted on Apr 17, 2009
SOURCE: Tv Code for Time Warner Cable Remote
I need got a different tv tan i had when my tv was installed s i need the code
Posted on May 26, 2009
SOURCE: my samsung remote bn59-00673a does not work at all
"The Samsung Website says to take the batteries out and either press the reset button for 2-3 seconds or hold down the power button for 1 minute.
Got to say I was sceptical but it worked!! "
from http://www.fixya.com/support/t952131-samsung_bn59_00463a_remote_doesnt
Posted on Aug 03, 2009
SOURCE: alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Posted on Feb 22, 2010
Testimonial: "Excellent! It works, many thanks for your help"
Samsung plasma tv orange led
The set has a power supply circuit board INSIDE that needs to be looked at (not the power cord itself) and if bad replaced.
Dec 08, 2012 | Samsung Televison & Video
When I turn the set on green leds appear for about 30 sec then it swicthes to red stanby and flashes 5 times intermitently
May I know what is the exact model number of your TV, it is located at the rear cover, manual, and on the receipt. It will help diagnose accurately where the fault came from and confirm the blinking error code.
Jdvillanueva
Jan 11, 2012 | Televison & Video
I'm having trouble with my Toshiba 42HL196 TV. It won't power on. There is a flashing red light on front. I've read the manual and done everything it suggests with no success. I've checked inside the tv...
SYMPTOM: Won't turn on or intermittently won't turn on, Red LED Flashes.
CAUSE: Loss of Main Switched Power Sources. Standby power is OK.
SOLUTION: Replace Regulator IC Q820 with Toshiba Part # 23135094
Jan 18, 2011 | Toshiba 42HL196 42 in. LCD HDTV
Tv will intermittently not turn on. when i press the on/off switch i hear a click then i hear fans start up - the fans will die down to a steady speed. no raster. press on/off a few times then tv video...
Your Caps on the PSB- Power supply board are on their way out. Pretty soon it won't turn on at all. You will only get the Fault code blinking LED at startup. Recap the UF capacitors on the PSB. Works 90% of the time.
Jun 30, 2010 | LG MU-50PZ90C Television
Samsung TV will turn on and off several times, then stay on.
First, need to check the power bar(if you use).
then. if don't use power bar, need to check the power board.
Dec 12, 2008 | Samsung HL-R7178W 71" HDTV
TV turns off aftering powering up. red LED flashes 3 times.
3 red blinks means th lamp door in not on. if you have installed the lamp door corectly and it still does this solder all three pins together on the door switch.
Oct 08, 2007 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv power intermittant
As computer controlled as TV's are it is a good thing first to unplug the set for 2 minutes then trying operation again.
Feb 03, 2007 | Hitachi 35UX70B 35" TV
Televison & Video Logo
52 people viewed this question
Top Teac Televison & Video Experts
bengsoon Neo
JOHN TOPLISS
Are you a Teac Televison and Video Expert? Answer questions, earn points and help others
