SOURCE: hoover optima hnf6167 7kg washing
My washing machine completes its cycle but is leaking water from the left hand side on to the floor, Why is this???
SOURCE: hoover washing machine Mod OPH 714D Error E16 in
After far more research than I usually have to do, It seems that E16 means "O/C Heater"
Which means that the heating element is open curcuit. Which menas......
Either the heater element has a wire off at the back, or more likely the heater element is burned out.
They are easy to replace. Pull the machine out and remove the rear inspection plate at the bottom of the body (I think this machine has one!, sorry if it doesn't).
At the bottom of the drum, you will see a atainless steel cover, about 4 inches limg and a third of an inch wide, with rounded ends. There will be 2 spade connectors with wires in them (1 either end of the plate) and a 10mm nut in the centre. The nut tightens up a squeeze plate inside that crushes up a rubber seal to hold it in place. Undo the nut fully (you may have to push the little stud bolt that is now exposed in a little to free it off) The element should now withdraw if you grab hold of the spade connectors and tug a little to break the seal before you withdraw it.
Replacement should be the reverse of removal.
Google "Hoover washing machine heating element" to find yourself one on line, or ho to your local Hoover parts stockist
Testimonial: "thanks for your help great, having more problems now so it has to go!"
