My generator CATC32 shutdown on load and show error code FM31
IT SHUTDOWN ON LOAD AND TRIPING CIRCUTE BREAKER ALSO . ERROR CODE SHOWING FM 31
5 Suggested Answers
SOURCE: WD6122PKC error code 9E2
Normally a tripped circuit breaker is caused either by a short circuit or an overload in that particular branch. Or in some cases, a defective breaker.
The first condition can only be determined with the use of a tester by doing a short circuit test. To do this, at 1Kx resistance setting (using either an analog or a digital tester), connect one of the test prods (either the Positive or Negative prod, it really doesn't matter in this test) to one of the two prongs (live side) of the plug. Then, using the other test prod, to the other prong of the live side of the plug. What you should be reading is any value other than 0. Should your needle (in case of an analog tester) indicates or deflects to the value of 0, or if using a digital tester shows a value of 0, then in all likelihood there is a short circuit in your unit. The only way to find this is to trace where this short is originating from (this may be a little difficult with no schematic diagram to refer to). I would however suggest starting from the power cord itself since it is the breaker that is tripping with no blown fuse.
The other condition is overloading. Considering you are already using a 20A Circuit Breaker, this should aptly suffice for the threshold specification of the unit which is 15A. The question is, are there any other appliances being operated in this particular branch circuit? If there is, I would suggest that you try disconnecting/turning off all other appliances or devices using this branch and try operating your washing machine again. If it works fine, I would have to suggest that you replace your crcuit breaker with a higher current rating. To know by how much, I suggest you use this formula, Total Wattage of all appliances connected divided by Voltage Rating equals Required Ampere Rating of your breaker. I suggest using the next avalable higher ampere rating. Say if you have a 25A requirement, use a 30A circuit breaker.
Last but not least is the possibility of a defective breaker. If none of the above is the cause of the problem, I would suggest replacing the circuit breaker with a new one.
Posted on Oct 07, 2008
  • 2699 Answers
SOURCE: The washer filled with water, But it stopped and
try opening and closing the lid,you should hear a clicking sound just before the lid closes,if you don't you havea broken lid switch.let me know what you find
Posted on Jul 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 3.5 Front Load Error code 31
Electronic pressure switch circuit faulty (frequency of pressure switch signal out of limits)
Possible causes are;
Electronic pressure switch; wiring; main PCB.
Unplug the appliance and take the top off.
Locate the pressure switches (there may be 2, some have only 1).
Take the thin tube off of the switches and block one tube with your thumb.
Blow as hard as you can down the other tube.
Refit the tubes and try the machine again.
If still the same you'll need to check the wiring between the pressure switch and the main pcb (front right or in the facia depending on the type fitted).
If after this it's still faulty you'll need to begin changing parts, starting with the pressure switch(es).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 23, 2010
SOURCE: error code E:13 is showing on the washer
Mine did it too on a light load. Set to reduced spin and rinse spin and everything ok. Think this code shuts washer down when spinning out of balance to protect damaging the unit.
Posted on Sep 30, 2011
I have a honda ex 5500 generator that keeps triping the on and off breaker to the outlets what could it be
Hi there. 1) Remove all loads and start up.2) Connect a known working load and if it trips on a load too small then the tripswitch is faulty and must be replaced
Dec 10, 2016 | Honda Electrical Supplies
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
Error code main breaker trip and shows on ups that load not protected
Need to get the code and find out what code is it. Also, you might of fixed this ups by now.
Dec 24, 2013 | MGE UPS Pulsar EXL UPS System
Breaker keep triping on screen light shows P-06
Is it tripping under load? or not under load. If it is under load have breaker checked and unit tested on a load bank. If it trips under no load check for wiring shorts on the main AC lines to the plugs
Oct 02, 2013 | Kipor Electrical Supplies
Generator circuit breaker keeps tripping
wet plugs,exceeding max load of circut,whatever it is running has a short in it.
Dec 21, 2012 | Buffalo Tools Pro-series 7000 Watt Silent...
Coleman powermate generator won't generate
Check rotor again and measure to see if you have DC voltage on the brushes while running. If no then suspect capacitor
Nov 11, 2012 | Coleman Powermate Powermate 5000W...
The washer filled with water, But it stopped and would not go through any of the other cycles. No circut breakers triped, and power to a three pronged plug available. Sears Kenmore Washer 110. 25862400
Jul 25, 2010 | Kenmore 25862 Top Load Washer
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Pf error
Pf is power failure code you must push clear or reset washer by unplugging and plugging back in Good luck
Mar 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
