After installing new lamp with new housing it shows Error message
    Top Expert:
  • Office Equip... Master
  • 74,468 Answers
I don't know whether you have taken all the precautions before replacing the lamp. Before and after the lamp replacement, lamp time has to be set. Otherwise, the projector will show error message when you switch it ON after the lamp replacement. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 30, 2014
Price for XL-2400 sony replacement lamp with housing for KDF-E50A10 Grand Wega
You can get them from many places but you want to get the lamp with housing most places only sell the bare lamp annd then you have to install the new lamp into your housing being careful not to touch the lamp . You can get the Sony XL2400 lamp with housing from www.tvrepairworld.com which is 159.00 and includes installation instructions which takes about 2 minutes and no special tools required when you get the lamp with housing as an assembly.
Aug 13, 2011 | Sony Televison & Video
Bulb "End of Life" message
hi,
for replacing the lamp do yhe following.
1.Remove the lamp cover by pushing two grooves lightly with the flathead
screwdriver. You can see the lamp cover on the top of the projector. ( left side of the lens)
2.Loosen the two screws securing the lamp housing until the screwdriver
goes into a freewheeling condition. The two screws are not
removable
3.Remove the lamp housing by pulling out the handle
4.Insert a new lamp housing until the lamp housing is plugged into the
Socket
5.Secure it in place with the two screws.Be sure to tighten the screws.
6.Reattach the lamp cover
7.Snap the lamp cover into place.
Replacing a new lamp automatically clears the lamp usage hours ok
Jan 27, 2011 | NEC MT1060 Multimedia Projector
Sony projection television lamp replacement...
hello the last light at the bottom of the tv will flash this will tell you the lamp as burn't out i would buy the lamp in the housing it just makes it easyier to install when you do install it make sure
Nov 15, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Black picture the lamp does't lit. no error message.
Hi sir;Try to make a copy with open cover ( check the exposure lamp is on), if exposure lamp not on andyou already replace a new one then check the thermos fuse at the end of the lamp, replace that one.
May 29, 2009 | Canon Office Equipment & Supplies
Resetting lamp hours
No its not correct this error message is telling you your lamp is going out and pruchasing a new one will reset this otherwise you have to cut some wires! i would not recommend that!
May 25, 2009 | LG DU-62SY20D 62" Rear Projection HDTV
Projection lamp nearing end of life replace lamp still coming on
Along with the instructions for the lamp installation, you should have revceived instructions on how to reset the lamp counter. If not, this operation is listed in the owner's manual. If you can not locate that manual, please confirm your model number and I will post the instructions. Since the counter has not been reset, the TV will continue to show the "error" message.
Dan
Mar 09, 2009 | Sony KDF46E2000 46" Projection HDTV
Tv Shuts off occasionally 1min upon power up shows red lamp light
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Feb 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Service error 5100
may be the driver are not installed correctly ... just try reinstalling the drivers ... and make a check that you have inserted the ink cartilage or not ...
if not insert it and then give try ... it may work ..
if problem persists then call the service rep ...
Feb 07, 2008 | Office Equipment & Supplies
Lamp will not strike error message
this can sometimes indicate either an overheating issue, a lamp service life problem, or that the cover to the lamp housing has not been secured properly.
Dec 14, 2007 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Error Message
. Set shuts off after displaying the message "TV will shut down in a few seconds. Please check if the air flow is blocked." After shutdown, it may have a yellow status LED, self diagnostics indicates error code 38. To repair, replace the Lamp Thermal Sensor with the new version, part # 299P313010A. The sensor is located on the Lamp Cartridge Housing. See Service Tip VS-72B. Under rare circumstances, when a replacement thermal sensor is not available, refer to the original Service Tip, VS-72 (page 2 and 3 of VS-72B) If error 3-4 then this maybe problem:. Check to see if the lamp is on when the unit is off (in standby) if it is components on the Power PWB... K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects ... deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010. See Service Tip VS-73 2. If the lamp never lights suspect the Lamp part # 915P049010
Aug 22, 2007 | Mitsubishi WD-57732 Projection Television
64 people viewed this question
jasbo
jasbo
