Question about Zodiac Baracuda G2 Pool Cleaner
I have brand new pool cleanerg2 baracuda great suction but just wont move , thinking what a waste of money
    Top Expert:
  • Zodiac Master
  • 4,292 Answers
Too much suction cut back its stuck to floor
Posted on Sep 13, 2017
PartsCenter
  • 125 Answers
SOURCE: Baracuda G3 zodiac Clings to bottom or sides moving slowly
here is a link to the Technical Support at Baracuda. this should be able to solve your problems. initially sounds like maybe too much suction.
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
too much suction. Here is a link to the trouble shooting guide.
SOURCE: baracuda G4 won't clean whole pool. goes to a corner and stays
Maybe your hose needs to be reprogrammed by unhooking and lying it in the sun for several hours.
Posted on May 03, 2009
mjhedger
  • 25 Answers
SOURCE: zodiac baracuda wont go to shallow end of pool
If you can, adjust your intake valves so more of the suction is coming from your vacuum and less from your skimmers. This will allow the the vacuum to climb out of the deep end.
Posted on Aug 25, 2009
  • 106 Answers
SOURCE: get stuck in the pool corner
try adding a hose length or taking one piece off. Also you can try increasing or decreasing the suction.
Posted on Jan 15, 2010
Zodiac ranger has good suction but doesn't move
Usually if you have good suction with a Baracuda and no movement you either need to clear the diaphragm of debris, or replace the diaphragm if it's got a hole in it.
Check out this video (not mine) for how to pull the diaphragm out.
http://www.youtube.com/watch?v=FRR1Gsps8Js
It's pretty straightforward, just keep undoing things until you get to the flexible rubber bit. You have to check fairly carefully for holes because even the smallest opening means it's curtains for the diaphragm.
Good news is though that Zodiac should have a 1 year warranty on the diaphragm, which you can check by looking at the moulded stamp on the part. If it's under a year old your local dealer should just swap a new one for the old without any dramas.
Mar 16, 2013 | Zodiac Baracuda Ranger - Above Ground...
Barracuda has plenty of suction but hardly moves around the pool, goes very slowly
You likely just need a new pad on the head. When they ware down they allow the head to get closer to the surface that it's cleaning, but the additional suction makes it difficult for the head to move.
I hope this helps you!
Jan 29, 2011 | Zodiac Baracuda Zippy Pool Cleaner
Wont move,has suction but wont move?
If cleaner is pulsing, you probably have a worn out foot pad and it should be replaced. If it not pulsing, you probably have a ripped or torn diaphragm and it needs to be replaced. Also, make sure there is enough suction.
Aug 03, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Baracuda alpha 3 has suction but will not move makes a humming noise.
Their is probally a small hole or tear in your diaprham and will need replacement. If you take it to a pool store they will probally do this for you just for the price of the part.
Jul 31, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Baracuda G3
Check your pool cleaners hose to make sure that it is not becoming tangled. Storing the hose in a coiled position will cause this. If it is not moving and it is not the hose, you could have a leak in a connection somewhere. If the cleaner is getting adequate suction, it should be moving. Try adjust the hose weights to make sure the cleaner is at a 45 degree angle to the pools floor.
Jul 06, 2010 | Zodiac Baracuda G3 Automatic In Ground...
My baracuda G3 stop working is not pulsating and therefore not moving. I checked the suction and the hoses even the diaphram everything looks ok.
If you have suction at the bottom of the cleaner, there has to be a problem with the diaphragm. I would remove it and recheck.
Feb 01, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Changed the fin on the baracuda, but it still does not move around the pool, can fill the suction if I lift it up, but it does not move.
If you have good suction at the head you may have a bad diaprham or something stuck in it. If you have suction but it is weak check for cracks in hoses or you may have a clog in your pump impeller.
Oct 30, 2009 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Lots of suction, but G3 won't pulse or move around pool
theres a throat in it. Its damaged or ripped take a close look at it . you can gey at your local pool store
Oct 05, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Feb 25, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac Baracuda G2 Pool Cleaner Logo
359 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
