Question about HP Office Equipment & Supplies
HP Printer, CP5225, Error message, Right door open,
    Habit-Forming:
  • 91 Answers
Right door is a right side of paper try
check if there is paper jam in this try
Posted on Nov 30, 2014
  • 21 Answers
SOURCE: Error message "cover door is open or printer cartridge is missing"
Try to find the latch in the cover that presses a switch to indicate it is closed it is usually a small stick projection at the sides of the cover. Replace the cartridge it should fit snuggly then try it again.
Posted on May 31, 2008
SOURCE: hp laserjet 2600n printer showing message door open
there door censer problem. i fix new censer
Posted on Jul 10, 2008
  • 113 Answers
SOURCE: Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Posted on Feb 28, 2009
  • 1170 Answers
SOURCE: "Door open" message
Door open could be either the front door, or the top cover. Both have an actuator for the switch.. A pinched wire could also be your problem.
That failure to feed out might be your feed rollers and separation pads .. need cleaning.
especially since you've had to tear down.
I clean them with plain water, and blow them dry.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Posted on Mar 30, 2009
  • 4 Answers
SOURCE: Door open error on HP6840 printer when door is closed
Here's the answer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01065334&cc=us&lc=en&dlc=en&product=385458
The sensor is probably stuck, and it took me a few minutes to fix!!
Good luck...
Peter
Posted on Apr 30, 2009
HP CP5225 giving error message "Re-install image transfer belt" belt is brand new, fixing properly, repeatedly same message appears.
Did you have the printer powered off before you installed the belt? If not the fuse has blown and the message will be on until you replace the belt again.
Feb 13, 2017 | HEWLETT-PACKARD CP5225dn Laser Printer
Recommended action
  1. Close the door.
  2. Use the right-door switch (SP15) test in the manual sensor test to verify that the switch is properly functioning. If the switch fails the test, replace the switch.
  3. Check the sensor flag on the right door assembly. If it is damaged, replace the door assembly.
  4. If the product has been recently serviced:
    1. Check the connector (J708) on the 24V interlock switch and the connector (J181) on the DC controller PCA.
    2. Reseat the formater board and retest.
    3. Reseat the ICB and retest.
Nov 30, 2014 | HEWLETT-PACKARD CP5225dn Laser Printer
HP PhotoSmart computer indicates "open door"
Open "Devices and Printers" in start menu.
Right click printer with green arrow - click see whats printing.
Delete all documents.
Restart computer - then restart printer
See if that clears your error messages.
Mar 12, 2014 | HP PhotoSmart C4345 AllInOne InkJet...
What is the reason for showing the message " right door is open" and how it can be solved
Could be a driver issue, look here for newest driver, and be sure to pick the correct one, win7/8 32/64 bit. http://h20566.www2.hp.com/portal/site/hpsc/public/psi/home/?sp4ts.oid=3974355
Good luck, post more info if this doesn't solve your problem.
Laulund
Jan 28, 2014 | HEWLETT-PACKARD Color LaserJet CP5225...
How to replace dc controller board on hp cp5225n
Remove 5 screws from rear cover and remove it
Open the right door to expose 2 screws holding right cover, release tab and remove Right Cover
disconnect 22 cable connections and 6 flat cables from the DC Controller PCB
Disconnect 3 intermediary wire connections and release the cables from the cable guides on the top and right sides
remove 4 screws from the 4 corners of the DC Controller
Remove PCB
Oct 01, 2013 | HEWLETT-PACKARD Color LaserJet CP5225...
HP Printer, CP5225, Error message, Right door open, door is shut but will not reset error?
This sounds to be a sensor issue. Try:
Reconnect the connector (J708) of the 24V interlock switch and the connector(J121X) on the DC controller PCA.
Also, try to check the sensor flag of the right door. If it is damaged,replace the right door sensor unit.
The sensor worked for me.
Aug 19, 2013 | HEWLETT-PACKARD Color LaserJet CP5225...
HP CP5225 printing from iPad problem
HP has a list of solutions for print quality problems. Have you tried all the solutions suggested here?
Troubleshoot problem for HP Color LaserJet Professional CP5225 Printer...
There were also a couple Mac specific solutions available (links look the same but are different). Both solutions are about prints being different than expected.
I am an HP employee.
Apr 20, 2013 | HEWLETT-PACKARD CP5225dn Laser Printer
Sir, i have hp laserjet colour printer CP5225, having error 55.0601. Kindly give me online solution
this all i manage to find for hope it helps
55.x Error
Error Message
55.X Error
Turn off then on
Description
The printer has experienced an internal error. The printer may experience one of the following errors:
55.0 DC controller communication error
55.0601 DC controller NVRAM data error
55.0602 DC controller NVRAM access error
55.1 DC controller memory error
Action
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the printer to initialize.
If a surge protector is used, remove it. Plug the printer directly into the wall socket. Use the power switch to turn on the printer.
If the message persists, contact HP support.
You need to first check the connection between the dc controller and the formatter and if the connection is fine you need to replace the dc controller.
Dec 22, 2010 | Office Equipment & Supplies
"Door Open" error message
check all the doors of the printer. If they are not closed, The printer will continue to throw this error.
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
203 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
