Question about Exercise & Fitness
What problem in Hyundai elevator error code F11
2 Suggested Answers
AJIN G
  • 6694 Answers
SOURCE: What is the error 75 for elevator? HYUNDAI ELEVATOR Type STVF 7 How to solve this problem? Lift suddenly can stop any floor as not level. Thanks
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on May 19, 2016
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    F11 error code
    I appreciate the post, dan moore!
    From the information you have provided your Frigidaire range is displaying an "F11" error code. Typically, the "F11" error code stands for a shorted keypad. This could be a false error code and the best way to clear any false error codes is to disconnect power from the range for at least ten minutes. If you continue to get an "F11" error code you may need to replace your EOC (Electronic Oven Control), I would recommend having a professional technician come out to properly replace any electrical component to avoid personal injury. Hope this information is helpful to some degree. -Matt
    Dec 14, 2014 | Frigidaire Kitchen Ranges
    I have a HYUNDAI luxen- passengers elevator traped between two floors, No sign at the hall call point, and giving an ERROR CODE F74 :(
    Put in an emergency call to Hyundai - they have operators who can talk you through this situation. Or... call whichever local company services your elevators.
    Aug 13, 2014 | Exercise & Fitness
    this is a low drop voltage in upper PCA, try to test the power cable, and see if the voltage in your outlet box in normally 115vca, DO not use extension cord, or line that will be overload, this causes this problem.
    Otherwise you must replace the PCA, replace the power cord, and use stabilizer voltage, or use another CLEAN line from your panel power breaker,
    God bless you
    Jul 07, 2013 | Exercise & Fitness
    Error code E 7
    proceed according you have two alternative: see the diagrams . God bless you
    ERROR CODE # 7
    E7- 1) Alternative Elevation Motor
    1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
    2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
    3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
    4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
    2)Alternative:
    Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
    c) Cause: Line Cord Damaged Solution: Replace Line Cord
    d)Cause: Fuse Solution: Check Fuse on MCB
    Jan 22, 2013 | LifeSpan Fitness Lifespan PRO3 -Treadmill-...
    I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
    please test the 2 alternatives for error 7. God bless you
    see the diagram attached.
    ERROR CODE # 7
    2)Alternative:
    Jan 08, 2013 | Tunturi T40 Folding Treadmill
    Treadmill KETTLER PACER error code E7, what I have to do?
    see the next steps and fix it. God bless you
    ERROR CODE # 7
    2)Alternative:
    Nov 28, 2012 | Kettler treadmill Pacer
    Error code F11
    Not sure what machine you have?
    F11 Error Code for Whirlpool Duet & Duet HT :
    F11 is Serial Communication Error, communication between the central control and the motor control unit cannot be sent correctly.
    Check all connectors at the motor control and the Main control, check the motor, check drive system for any worn or failed components.
    This is the only F11 Error code I could find for a washer.
    Jan 13, 2010 | Dryers
    Exercise & Fitness Logo
    198 people viewed this question
    Top Exercise & Fitness Experts
    Howard
    Howard
    Sportsmith LLC
    Sportsmith LLC
    Tom Chichester
    Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
