Question about Optoma HD80 Projector
My HD80 has about 700 hours, original bulb assembly, was working fine until I got curious and "activated" the auto off function while going through the menu. Now it will power up, lamp does not go to
My HD80 has about 700 hours, original bulb assembly, was working fine until I got curious and "activated" the auto off function while going through the menu. Now it will power up, lamp does not go to full brightness, and then shuts down. Any suggestions other than bulb replacement? Ironically, I ordered a replacement bulb assembly last night, thinking it would be good to have available 5 years from now when the lamp would be at around 1500 hours (the projector is 5 years old).
    Sergeant:
  • 320 Answers
Ensure a video source is connected to the projector (VGA, DVD, etc)
Unplug the projector to make sure it has completely shut down (not just went into sleep mode)
Plug in power and power on the projector (make sure video source is on first)
The projector should turn on and switch to the video source (manually select if not)
Once you can see the video source, push menu and turn off auto-off.
Auto-off should only work when the projector detect a video source is no longer present on the selected input. So if you are turning on the projector with no video source connected, it will usually turn off shortly after being turned on.
Posted on Dec 02, 2014
  • Philip P
    Philip P Dec 04, 2014
    Thanks for the information, Jeff. I had two inputs prior to getting curious while searching through the menu. I had forgot that I had deselected the "good" source (HDMI) and left the "questionable" source (Video) selected, hence, no signal and then a quick (5 second) shutdown. The "auto off" is now set back at "0" and the projector is functioning like it should once again.
bigg t
  • 640 Answers
SOURCE: Optoma MovieTime: The Lamp that Won't stay on
its definitly a cooling issue.the temp sensor is working because it shuts the unit down.when a lamp goes it goes just like a light bulb.you can open up the unit and locate the fan take it out and go to a radio shack a match it up to a universal fan.
Posted on Aug 28, 2007
Marrie
  • 563 Answers
SOURCE: Optoma EP732H Projector - Image is Whitewashed
Hi tourblack
I wouldn't think that this is a lamp issue , as the lamp will make the picture fade away in brightness and wouldn't look white washed.
Check if the brightness is set to 50% and the contrast on 50% as well.
This could be a colourwheel that is in need of replacement.
Posted on May 13, 2008
  • 6 Answers
SOURCE: HD 70 DLP Projector problem
Hi, My name is Doug Stanko.
I had the same issue and fixed the problem.
All you have to do is take a few screws out..... and blow out the inside VERY well with pressurized air. I have a compressor... and I set the regulator to 50 psi. But the KEY IS TO have the covers off so you can get between the circuit cards and blow them out. They were incredibly dusty. Even after I blew through the side vents.
I agree with all of you that say it is overheating. You are right. There was so much dust on the fan blades them selves... I'm suprised they were still spinning at all.
And like most of you... first I bought the $300 dollar bulb... put it in and 10 minutes later it was doing the same thing flashing through the colors. So trust me.
There are 4 screws on the back. Take these out.
There are 2 small nuts on the back around the VGA input. Take these out.
There are about 5 screws on the underside (think one was on the bulb changeout portion). These have long copper colored bars that go all the way from top to bottom.
All these have to be removed. Then you can take it apart. AND I PROMISE YOU WILL SEE TONS OF DUST ALL OVER.
Make sure you blow out the parts between the circiut boards AND the fan unit.
Put it back together... and remember to make sure that little latch on the bulb change cover makes the click sound ( it is a switch that must close or the unit will not power back up )..... and it will work great again.
No need for a huge fan next to it. Although I will admit that is an excellent idea.
I did this 3 weeks ago and have been watching it with no issues.
If you do not feel comfortable taking the screws out yourself..... I would take it to your local TV repair store and just ask them to take the covers off and blow out all the dust... and give it back to you. No troubleshooting... no repairs... no replacements... just blow it out.
I was an electronic technician in the US Navy for 10 years... Now I work at a nuclear power plant in Illinois. BUT I PROMISE with a good phillips head screw driver and a small crescent wrench you can do this yourself.
Good luck and you are welcome. I know how frustrating this issue is. But this is the fix.
Doug
Posted on May 13, 2009
SOURCE: Purplish-blue after 5 minutes of viewing ...?
I solved a similar problem by putting a small battery operated fan blowing directly into the IN vent (on the right side of unit). This completely takes care of the issue.
Now, I wish I knew what the real problem was so I could fix it...
Posted on Dec 22, 2009
SOURCE: My Optoma HD72 projector operates for about 1
The problem is not over-heating. The Optoma HD72 has a known problem that Optoma won't advertise. The lamp driver is faulty. They simply have to replace the lamp driver. I purchased a spare lamp with my original purchase. I had the exact same experience as you at around 1200 hours on the lamp in ECO mode. I used the spare lamp. Same thing happened at about 1200 hours. I had a friend at Optoma. he confided to me the problem. I sent it in and they replaced the lamp driver at no charge. I got another 800 hours out of the first lamp and am now using my second lamp and have about 600 hours on it. The pic quality is so good with this projector (used Digital Video Essentials to calibrate) that I'll just order a bare lamp or two and use the existing lamp housings when I need a new bulb.
Posted on Jun 19, 2010
Help have onix split system air con and remote not working and it s the only way to turn it on have tried every where to get one model no is TEM-84CHSBE heat unbearable in summer nth qld aust.
Auto-restart Presetting:
The appliance is preset as no auto-restart function by manufacture. If Auto-restart function is needed, follow the
step below to activate this function:
1) Make sure the Air-con's power is off:
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify.
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard.
The Auto-restart function is then activated. To cancel the Auto-restart function, repeat above procedure until four
Remarks: When remote controller is out of work, open the panel and you can see emergency button there, see the
The emergency button for 50, 70, 90 series is at the top right, see " ON/OFF " button there.
Auto-restart set:
the appliance is preset as no auto-restart function by manufacturer. If Auto-restart function is needed, follow the
below step to activate this function:
1) Make sure the Air-con's power is off .
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify .
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard, then Auto-restart
function is activated. To cancel the Auto-restart function, repeat above procedure until four short beeps are heard.
Oct 31, 2011 | Heating & Cooling
I bought the iphone off a friend of mine as it was disabled and he already has another phone... i restored the iphone using itunes which worked fine, however itunes then auto attempted to activate it...
This device will not preform any other function until it is connected to the computer with a valid SIM card in it. The device will then need to be activated with an AT&T (if in the United States) account. Only then will the device function normally
Feb 28, 2011 | Apple iPhone Smartphone
How can I program my Leviton timer model 6651-I?
Leviton 6651 Manual.
http://waterheatertimer.org/pdf/Leviton-6651-manual.pdf
Timer requires a battery which should be replaced each 12 to 18 months.
Timer replaces single-pole or 3-way switch, and does not need a separate neutral wire.
Timer is for incandescent lights only.
500 Watt capacity
Push the door for manual override to reverse program that is in effect.
The 14 hour timing period is represented by 24 dip switches.
Each dip switch is positioned for ON or OFF.
Click the dip switch right or left
Start at the bottom
For example: ON for 3 hours, OFF for 4 hours, ON again for 3 hours:
Click dip switches 1 thru 3 to ON position, 4 thru 7 to OFF position, 8 thru 10 to ON position
ON position is to the right.
OFF position is to the left.
At the end of the 14 hour program, the timer turns lights OFF until the original start time is reached after 24 hours.
Timer will operate like this while in AUTO mode, until function switch is moved from AUTO to MAN or OFF modes.
Function switch is located at very bottom of timer door.
To activate program (on first day), function switch is set to OFF position for 2 seconds, and then move function switch to AUTO mode, and programming cycle begins.
Nov 11, 2010 | Solar Leviton 6651 Decora Programmable...
2003 vw beetle right rear lights keep burning out primarilly the
Sometimes quality of the bulbs are suspect in these cases. Check all connections at the assembly for any corrosion or looseness. I believe these also had a problem with the brakelight switch just above the brake pedal. My guess would be the connection at the brake light assembly or the socket where the bulbs go in.
Apr 29, 2010 | 2003 Volkswagen New Beetle Convertible
Replacing headlight bulb ford focus
Most of this solution for changing a headlamp on a ford focus sedan is taken from solution 2's writeup, accept with a few more details that should help changing the bulb assembly for the novice. Pop the hood. At the front of the car, look to the back of the headlight assembly. There will be a plastic cover on the back. On some models, you need to unscrew the plastic cap; on others, it just pops or screws off. Remove the plastic cover and then take note of the orientation of the three prong connector on the back of the bulb assembly. This is important because the replacement bulb assembly is going to have to be positioned in the same manner. By noting the orientation before taking out the old assembly, it will be easier to orient the replacement bulb assembly after removal.
There is a small retaining clip that surrounds and holds the bulb in place. Removing the clip can be tricky. On my 2003 Ford Focus sedan, there is a special place to push and release the clip that is above the bulb - perhaps further above than you might think. Push the release clip and it will release the retaining clip from the bulb assembly. Gently pull the retaining clip down and out of the way of the bulb assembly. Pull the original bulb straight out. Remove the three prong connector from the bulb assembly. Connect the three prong connector to the replacement bulb and then orient the three prong connector as the original and push bulb assembly straight back into place. Jiggle the assembly slightly to seat it into the correct position in the headlamp housing and replace the retaining clip to hold the bulb in place. Replace the plastic cover on the back of the headlamp and replacement is complete.
No tools. 10 minutes.
Dec 16, 2009 | 2001 Ford Focus
How to change side marker bulb in 1997 altima
The marker lights are removed by depressing the tab (arrow) with a thin bladed tool. Take care not to scratch the paint
  1. Disengage the bulb and socket assembly from the lens housing.
  2. Gently grasp the light bulb and pull it straight out of the socket.
To install:
  1. Before installing the light bulb into the socket, ensure that all electrical contact surfaces are free of corrosion or dirt.
  2. Line up the base of the light bulb with the socket, then insert the light bulb into the socket until it is fully seated.
  3. To ensure that the replacement bulb functions properly, activate the applicable switch to illuminate the bulb which was just replaced. If the replacement light bulb does not illuminate, either it too is faulty or there is a problem in the bulb circuit or switch. Correct as necessary.
  4. Install the socket and bulb assembly into the lens housing.
Dec 07, 2009 | 1997 Nissan.5 Altima
Honeywell HZ-705.....HELP!!!!
Should have oil in it. I don't think you can refill it. If it has leaked out, it's probably no good. Anyway, here are the instructions.
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Aug 17, 2008 | Heating & Cooling
The brake lights my 2000 Chevy Blaser do not work, the turn lights work and the running lights work and the brake light on top of the blazer is working
We bought a 2000 Blazer in '02 and one day I noticed there were no brake lights, but the 3rd light on top worked fine. I did some research online and found out there was a recall on this problem due to the hazard switch on the column. I also found out if I wiggled the hazard switch a certain way, the brake lights worked. I was able to get by for awhile by wedging a 'widget' beside the hazard switch button and the hole in the column cover. This worked fine until someone would knock the widget out of place.
I finally got around to having the switch replaced at a local dealer. All was fine until last week when I was told the brake lights were out again and I found out my hazard lights didn't work either. I changed out the switch assembly myself this time, and once I had it out I saw what happened. The brake light voltage comes in to the assembly on a white wire, and the first contact this goes through is on the hazard switch. In my case the contact had obviously overheated from the brake light current and melted the plastic holding the contact in place, thus breaking the circuit to the brakes. Either a poor design or too much current for the circuit to handle.
Soooooo now I am in the process of replacing the four bulbs in the tail/brake light assembly with 3 watt Luxeon LED plug-in replacements. The current draw of the original bulbs was measured at 2.2 amps at 13.8 volts, times 4 bulbs makes about 8.8 amps that goes through the contact in the hazard switch whenever the brakes are stomped. The LED replacements draw .2 amp each, so times 4 will be .8 amp or less than 1/10th of the original equipment bulbs. These LED bulbs in my opinion are as bright or brighter than the original equipment and hopefully will help from burning out another switch assembly.. David
Jul 28, 2008 | 1998 Chevrolet Blazer
Honeywell oil radiator
Set temperature:
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Optoma HD80 Projector Logo
131 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
