Lg 50pc3d the fan works outside the tv but when plug in the slot it don't work
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Check for any obstrucion is there at its insertion slot; dust blocked, or something like that. Some fans will work outside the set, but when it position changes [horizontally or vertically], it won't work. If this is the case; the fan is defective; and should be replaced.
Posted on Nov 30, 2014
  • 19 Answers
SOURCE: LG 50PC3D not turning on
Without seeing the unit itself and opening it up/running tests I couldn't tell you exactly what is happening, however I can offer some suggestions as to what it could be.
1) your power supply is bad. That clicking sound is the power relay coming on and going off.
2) your main board is bad. It handles a lot of your signals for powering on your set. If it's bad, the tv won't turn on correctly as it doesn't recieve all the right signals.
3) your Y or Z boards are bad. These could cause the power supply to go into shutdown if the voltages on these things are too far out of whack.
Easiest way to tell if you're going to go into your tv is to try to unplug your Y and Z boards and turn it on. If it turns on and stays on chances are one of those two boards are bad.
Posted on Feb 21, 2009
lightnbaby
  • 36 Answers
SOURCE: No Picture on LG 50PC3D
No power?
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you could save $300 at least!
Posted on Mar 15, 2009
  • 1039 Answers
SOURCE: intermittent remote control problem on an LG 50PC3D
When the remote quits do the function buttons on the set still work? If the set is locking up I would suspect the main board. If the buttons on the set work when the remote doesn't. I would go to the store you bought it at and check the remote there on one of thier sets or go to radio shack and get a remote tester card. It may just be easier to just first replace the remote to determine if it's in the set or the remote. After all the remote will be cheaper than a service call.
Posted on Apr 26, 2009
  • 187 Answers
SOURCE: LG 50PC3D w/no picture
Your mainboard is damaged, replace it and that will solve your issue.
Posted on Jun 06, 2009
  • 1779 Answers
SOURCE: my lg 50pc3d remote will not control the tv. the
Take it to a local retail store that sells LG and see if it works there on a set . If it does then you have an issue with the set. If it doesn't then replace the remote, if under warranty, call LG for a replacement remote.
Posted on Oct 15, 2009
T.V. works fine but makes a lot of noise from within
If it works fine; there is no problem with this noise. In most cases, the noise can be with the cooling fans inside it [top side]. Check whether any block is there dust or something else.
Mar 05, 2015 | LG 50PC3D 50 in. Plasma Television
When I hook up my LG plasma to PS3 and Cable box, I don't get any sound or colour on the PS3. The TV /cable box works fine. Any ideas on the wiring?
What type of connections are you using? HDMI? Component? Composite? What audio? HDMI? Optical Digital? Analog audio?
Are you saying you get video from the PS3, but it is in Black&White only? Is there an NTSC/PAL selector on the PS3? If so, it may be set wrong. Set to NTSC if you're in the United States.
Feb 01, 2013 | LG 50PC3D 50 in. Plasma Television
Lg 50pc3d screen and z50pj240 could fit viseversa?
No, they have completely different displays - one is made by LG and the other by Samsung.
You can't mix those two.
Sorry, don't kill the messenger :-)
www.coppelltvrepair.com
Nov 19, 2011 | Televison & Video
Trying to connect my 50 inch 50PC3D plasma tv, to my playstation 3 using HDMI cable. The tv is giving me an invalid format, is there an explanation/solution to this?
The PS3 video resolution setting is too high for the TV to work, please see your PS3 user manual on how to lower the resolution to the native resolution of this TV.
Jun 29, 2011 | LG 50PC3D 50 in. Plasma Television
Jun 05, 2009 | LG 50PC3D 50 in. Plasma Television
No power?
open backcover
Jan 19, 2009 | LG 50PC3D 50 in. Plasma Television
Tv not turning on with renote control
are you using cable card? unit has major issues when using card
Dec 12, 2008 | LG 50PC3D 50 in. Plasma Television
Remote problems
Replace batteries of your LG remote.
Oct 11, 2008 | LG 50PC5DC 50 in. Plasma HDTV
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
