Question about Whirlpool Washing Machines
Whirlpool cabrio 5500 fills with water doesn't agitate then goes through cycle .it does drain but clothes still come out soaked .any ideas
Looked at belts
  • Whirlpool Master
  • 1,253 Answers
Door safety interlock switch. maybe control board. Youtube is your friend.
http://www.youtube.com/watch?v=9XyapB1Uep8
Posted on Nov 30, 2014
gwshaw71
  • 83 Answers
SOURCE: WHIRLPOOL ULTIMATE CARE II
check your lid switch
Posted on Dec 07, 2007
hotuna
  • 288 Answers
SOURCE: Kenmore 20702 Top Load Washer Problem
First check the lid switch. Its a little slot inside the top panel and when the door is closed it has a prong that pushes the switch down when closed. It is a safety feature. If you can find this press the slot with a screwdriver or something and listen for a clicking sound.It is also possible that one of the wires has come off, so that may need to be looked at too. Also check the lid to see if the prong has been broken off. If you have both of these things checking good, then it may be a more complicated issue like power to the wig wag coils, or a timer. We can however eliminate the motor, belt and water pump as these all work. I would put my money on a simple lid switch problem though.
Posted on Dec 19, 2007
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
Maytag317
  • 1136 Answers
SOURCE: Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Posted on Jul 05, 2009
SOURCE: doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Posted on Jul 30, 2009
Whirlpool Cabrio Washer does not spin the water completly out of the clothes
probably not getting into high speed spin mode
they spin slow in the initial stages to allow the clothes to become evenly distributed then after the water is removed they pick up speed
It is possible a problem in the program board not advancing to high speed
Call in a technician for a proper diagnosis and a quote
Jul 07, 2016 | Whirlpool Washing Machines
Cabrio washer stops spinning and doesn't restart
it sounds like the water pump is not emptying properly, blow down the water outlet pipe to see if is clear if not go to the water pump and clean it out there is probably a button , paper clip or other debris preventing it from doing its job eric
Dec 25, 2017 | Whirlpool Cabrio WTW6600SBT Top Load...
Why doesn't Cabrio washer wash the clothes?
This model has gone through different control board revisions, could be control board related, service mode would have to be accessed to have machine run thru self-diagnostics. if it does not agitate on self-diag mode, unit needs board
Apr 03, 2013 | Whirlpool WTW6400SW Cabrio Washer
Whirlpool washer model lsr8233eqo
So when the cycle first starts, it will fill and agitate and spin. But then on the rinse cycle it stops?
Feb 03, 2013 | Whirlpool Washing Machines
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Cabrio WTW6600SB2 won't spin or agitate. We bought it used and they swore it worked. It goes from 45min and drops down to 3mins. It never completes it's load. And after it beeps with a OL on
Hi.
Most spin troubles are caused by drain or pressure switch problems, but it does not look like that is your case. Check for blockage in drain system and clean the hose connected to pressure switch. As said I do not think that this is the problem but the drain system must be checked as part of troubleshooting.
OL code in fact is not related to drain problems, but to motor and mechanical problem. OL is returned when the washer is overloaded and the motor cannot turn the basket properly.
The first step to diagnose the problem is removing the basket and looking for problems under the basket (e.g. broken part or clothes stuck under the tub). Here a document showing how to.
If parts under the basket are OK the next step will consist in testing the motor. The motor can be tested reading impedance at its phase terminal and across the stator winding. The Cabrio's motor should read about 30/32 Ohms across its phase contacts.
If the motor and the rest are OK the problem is usually the RPS sensor that detects the rotational speed of the motor.
Regards.
Ginko
Dec 15, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Not spinning or draining, only fills and agitates
the mixing valve in the rear needs to be repaced-it controls the water flow Also sounds like the clutch of the transmision maybe be a factor if the machine doesn't spin
Jul 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Will fill and drain, not agitate or spin though
I am having the exact same problem with the same brand machine.  I put in a load of clothes to soak till the morning, but in the morning, the washing machine would only fill, spin, and drain.  The agitator would not wash the clothes, so they came out with the soap of course still crusted in.
Jan 22, 2009 | Roper Washing Machines
Whirlpool Cabrio WTW6600SW1: Won't drain
The washer drew half a tub of water on the "Bulky items" cycle, and stopped. All the lights on the cycle dial light up and flash, the machine beeps and the me error message in the "estimated time remaining" field is "Ld". I've tried to shut the machine down and change the cycle to "drain and spin" but it will not agitate, won't drain or spin.
Sep 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
51 people viewed this question
Dan Webster
Dan Webster
Sal De
