Question about Fisher and Paykel Washing Machines
Fisher and Paykel Smartdrive 601 washing machine stopped filling, beeped and then only a single green light remained in 'Wash Progress' area. Computer board problem?
Cold wash. Switched to Hot wash and still didn't work - so doesn't appear to be Cold solenoid. Played with safety switch after taking off lid - seems to not be the problem. Checked water level sensor - is not bent - seems to not be the problem either. I'm guessing it's the computer board. Any suggestions?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
No. It's a water inlet valve problem.
Posted on Nov 30, 2014
Testimonial: "Hi Gary. Thanks, but no, it was the computer board."
  • 159 Answers
SOURCE: No water flow on Fisher and Paykel smartdrive 708 washing machine
Take the lid off,just open it & pull it straight up.There should be a little red button that the lid strikes against unless its a different model,in that case it has a magnetic reed switch under the right hand side of the hob.press this red switch instead of closeing lid,see if it fill with no problem.the lid may not be making good contact with switch..if thats not it then it may be the inlet valve..then you can try the hot,if theres no problem with hot then its the cold valve.
Posted on May 30, 2010
Testimonial: "Very helpful, as I was completely ignorant about the workings of a washing machine. Replied promptly and had a good sense of humour - important in a crisis!"
TheMobilian
  • 8220 Answers
SOURCE: I have a smartdrive 601 that will not fill start
hot and cold hoses connected backwards
Posted on Mar 22, 2010
sonicboomele
  • 1557 Answers
SOURCE: My Fisher and Paykel Smartdrive 7.5 kg fwon't agitate
when they beep the main p.c.b bord has detected an error on the f/p series the main fault we have found with this is the small icb sensor that runs along side the capstan drive drum try cleaning it if this does not work try replacing the head control p.c.b bord
good luck
Posted on Jul 06, 2010
  • 1566 Answers
SOURCE: my fisher and paykel ecosmart gwl15 won't do a hot
There are several possible causes. To track down the problem, first shut off the water supply valve feeding the washing machine, then remove the hot water hose from the machine and direct it into a bucket. Turn on the water supply valve. Does water come out? Is it hot? If you only get cold water, then you need to insulate the pipe between the water heater and the supply valve so you get hot water faster (assuming the water heater is working!)
If you have a supply of hot water, then check the inlet screen where the hose connects to the washing machine. Perhaps it is clogged with lime or sediment. If it is clear, then you have a fault in the hot water solenoid valve or water temperature selector switch.
Posted on Dec 05, 2010
  • 3 Answers
SOURCE: Fisher and Paykel, EcoSmart with lid lock. After
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
Posted on Jul 28, 2011
Fisher paykel smart drive 601
Hi just read your post.When the machine beeps a series of lights will light up on the wash progress line of lights. Staring from left to right the long wah is number 1 and the spin light is number 8 which lights sre on when the machine beeps, is it 2, 4 and 8 or 1, 3 and 7 etc.Please reply with this information and I sure I can help you. Regards LU
Jan 24, 2014 | Fisher and Paykel Fisher & Paykel Washer
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
Fisher Paykel Smartdrive MW058K stops during cycle and hot and cold water temp lights flash along with progress light
This means that the machine can't get any water or enough to wash with.Check to see taps are on hoses for kinks and filters in water hoses are not blocked.
Jul 24, 2012 | Fisher and Paykel Washing Machines
good luck
Jul 06, 2010 | Washing Machines
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
