Question about Fisher and Paykel Washing Machines
Fisher and Paykel Smartdrive 601 stopped filling, beeped and then only a single green light remained in 'Wash Progress' area. Computer board problem?
Cold wash. Switched to Hot wash and still didn't work - so doesn't appear to be Cold solenoid. Played with safety switch after taking off lid - seems to not be the problem. Checked water level sensor - is not bent - seems to not be the problem either. I'm guessing it's the computer board. Any suggestions?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
You are correct.
Posted on Nov 30, 2014
5 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: I have a smartdrive 601 that will not fill start
hot and cold hoses connected backwards
Posted on Mar 22, 2010
sonicboomele
  • 1557 Answers
SOURCE: My Fisher and Paykel Smartdrive 7.5 kg fwon't agitate
when they beep the main p.c.b bord has detected an error on the f/p series the main fault we have found with this is the small icb sensor that runs along side the capstan drive drum try cleaning it if this does not work try replacing the head control p.c.b bord
good luck
Posted on Jul 06, 2010
richroth
  • 9472 Answers
SOURCE: Smartdrive 603 , Started a
It sounds like a lid switch problem. Lift lid up & down slowly about 20 - 30mm, you should hear the switch click. If you can't hear it, remove the lid & push lid switch in by hand. It is small button at right hand side of lower edge of panel. Hold button in & press start. If machine starts to fill with lid off, then you have a problem with the lid not pressing button in far enough.
Please let me know after you check the switch if you require further assistance.
Regards, Richard
Posted on Dec 03, 2010
e-Guru
  • 3917 Answers
SOURCE: My Fisher & Paykel GWL11
Sounds like you probably have a bad diverter valve or diverter valve is clogged with debris or has failed. The diverter valve on a fisher paykel washer moves the water from the drain hose port to the motor.
To access the diverter valve tip the washer back and look in the back right corner. The valve is held into position with two small hose clamps. A wire connection snaps into position on the valves terminals.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on May 25, 2011
Fisher paykel smart drive 601
Hi just read your post.When the machine beeps a series of lights will light up on the wash progress line of lights. Staring from left to right the long wah is number 1 and the spin light is number 8 which lights sre on when the machine beeps, is it 2, 4 and 8 or 1, 3 and 7 etc.Please reply with this information and I sure I can help you. Regards LU
Jan 24, 2014 | Fisher and Paykel Fisher & Paykel Washer
I have a Fisher and Paykel Smartdrive 9 washing machine that won't fill. It starts then stops and continues to do so, then stops altogether and beeps. Can anyone help??
The error code is displayed when its beeping.
I don't know the error code, so It can only be three things,
Out of balance switch,Lid magnetic reed switch,Or Rotor position sensor,Your error code would help me work out witch one of these are faulty. to work out your error code look at picture below.
Add up the lights that are on.
Jan 08, 2013 | Fisher and Paykel Washing Machines
Fisher Paykel Smartdrive MW058K stops during cycle and hot and cold water temp lights flash along with progress light
This means that the machine can't get any water or enough to wash with.Check to see taps are on hoses for kinks and filters in water hoses are not blocked.
Jul 24, 2012 | Fisher and Paykel Washing Machines
good luck
Jul 06, 2010 | Washing Machines
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Fisher & Paykel Smartdrive 701 Model GW701-U
Hi mate
I had the same problem replaced the board still no go. In my case it turned out to be the drain pump. Nothing wrong with it but a small bit of grit that although difficult to see was impeding the impeller
chee3s
Pul
Dec 08, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
59 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
