Electric fireplace I unplugged the fireplace while it was running. I could not get it to come back on. I just get a humming sound.
    Scholar:
  • 146 Answers
Do you have a model number of the fireplace?
Posted on Dec 03, 2014
3 Suggested Answers
  • 87 Answers
SOURCE: its a plug electric fireplace.sparked i unplug
It sounds like you are plugging it in when the unit is in the on position or(under load) make sure all switches are turned off before plugging it in. that will be a good place to start,
Posted on Oct 08, 2009
  • 90 Answers
SOURCE: Why does my electric fireplace makes a humming
sounds like you may have a ceased fan get someone to look for you, but an electrical hum that is louder than normal usually means that the fan or a moving part is trying to turn ot move but can't so make's like a hum noise so seek a service agent
Posted on Dec 16, 2010
Electric fireplace or wood burning fireplace. Which is better ?
Source: The Good And Bad Of Electric Fireplaces
You are able to save money by using electric fireplaces because they are significantly cheaper and more efficient to run. As opposed to turning on the heat for the entire home, you only have to actively heat one area although this is the same case for traditional fireplaces. Still, using an electric fireplace eliminates the need for buying wood, starting and maintaining a flame, and cleaning/servicing a fireplace with a chimney. Moreover, you are able to use an electric fireplace for an extended period of time. Wood-burning stoves are limited by the supply of wood. Gas burning fireplaces don't have that restriction, but require costly installment and creation of gas-line access. A foundational benefit of electric fireplaces is not causing any harmful particle emissions, which are a major side-product of traditional fireplaces, and one of the causes of their degradation.
How To Care For An Electric Fireplace
electric-fireplace-luqhqtew4twq4g4srgxhyj11-3-0.jpg Given the clear advantages that electric fireplaces have over traditional fireplaces, even die-hard fireplace lovers can justify making the switch to electric. Still, it is important to be apprised of the precautions and maintenance requirements before committing to a purchase. The most likely "repair" will be to change out bulbs as they die, typically about every two years. Models with LED bulbs will likely never need replacement. If you have a fireplace with conventional bulbs, replacing them is simple and straightforward. It is done by unplugging the fireplace, allowing it to completely cool if it was in use, and then accessing the rear panel of the unit. The panel can be unscrewed easily with a screwdriver. With the back panel removed, you should look for the bulb housing. This may differ from model to model, so consult the user guide before continuing (making sure to note what type of bulb is required). When you have the replacement, remove the old, and replace it with the new bulb. Some fireplaces require halogen bulbs which should not be handled by hand as this could compromise the longevity and quality of the bulb, in which case you should wear gloves to handle the bulb. With the new bulb in, you can screw back the rear panela and use the fireplace normally.
Electric fireplaces contain fans that are instrumental in providing heat to the room. The fan, as well as the other components, are usually pre-lubricated. However, if the fan is halting or not moving smoothly, it may indicate that cleaning is required. As with any other maintenance, make sure the unit is turned off and unplugged. You can use your vacuum's brush and wand attachments to clean the fan. Begin by taking off the grate and lightly cleaning to remove dust and grime. When finished, you can retrace with the wand attachment to pick up any remaining dirt. Replace the grate when you're finished.
The exterior mantle requires nothing more than occasional dusting and wiping. You should avoid the use of harsh chemical sprays, and instead, opt for mild soapy water and a lint-free cloth. Cleaning the glass display and mantle will make a big difference in the appearance of the unit. Be sure to dry the unit completely to avoid streaks and water marks.
Jun 21, 2017 | Home
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
I have a dura flame electric fireplace and I turned it one and it smells like something is burning. I tried to vacuum it and I turned it back one and it still smells like something is burning. it is a
when things are brand new that produce heat they will smell funny for awhile but give it a couple days and it will not if you see smoke then get excited and unplug.
Jan 28, 2015 | Duraflame L Electric Stove with Remote
Made a sound like fireworks and black smoke came out of machine
the pop sound told you that it blew up so it's time to get a new one
Jan 18, 2015 | Dimplex VCX1525 Convex Wall-mount Electric...
Electric fireplace
Is it that soud stay for long time, let say 10 minutes?
It can be some piece of metal moving when fireplace heats up.
If this fireplace has fan installed, small lousy bit of metal can play.
Nov 13, 2013 | Heating & Cooling
Flame has stopped flickering on our Century Heating electric fireplace, model HEF26. Fuses or motor?
Probably, neither. If there's no brightness at all, the bulbs are burned out and need to be replaced. If the brightness is there, but no flickering, then it's probably the motor or the shaft that the bulbs are on is stuck and can't rotate. Really not an uncommon problem with electric fireplaces, no matter who the manufacturer is. If you don't hear a humming noise when the flame function is turned ON. the motor may have overheated and shut down.
To test this, turn the Master ON/OFF Switch to OFF and unplug the fireplace from the wall outlet. Wait 12 - 15 minutes. Plug the unit back in and Turn the Master ON/OFF Switch to ON. Turn just the flame function ON. If it starts right up, the motor has cooled and the unit reset itself. If this continues to occur on a regular basis, contact the manufacturer's Technical Service Dept. If nothing happened after it was turned back ON, contact the manufacturer for replacement parts.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 04, 2011 | Heating & Cooling
Our dimplex electric fireplace model number 28106D3F shut off and won't turn back on
Turn the Master ON/OFF Switch to OFF. Unplug the fireplace from the wall receptacle and leave unplugged for 10 - 15 minutes. This will give it time t reset itself. In the future, if you finding you're have to do this more often. Unplug the fireplace, stop using it and call Dimplex USA Technical Service 888-346-7539 for further instructions.
Mar 09, 2011 | Heating & Cooling
My electric fire is just blowing cold air?
It sounds as if the heating element has burned out (which is very common with electric fireplaces) or it overheated and the overload switch turned the heater off. Since you didn't mention who the manufacturer of your fireplace is or the model number, it's hard to make any suggestion on how to solve the problem. Other than one: Turn the fireplace OFF, unplug it and wait 30 minutes to plug it back in and hopefully, it will reset itself.
Mar 02, 2011 | Heating & Cooling
Why does my electric fireplace makes a humming noise when on?
Dec 15, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Its a plug electric fireplace.sparked i unplug when plug back in big bang unplug again
Oct 08, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
51 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
