Question about Garden
Tires are ok but to move front with the machine we have to push on it it does not go by itself the v belt seam to slip on the pully
    Problem Solver:
  • 21 Answers
The drive belt must be slipping on the pulley from the engine, looking underneath you should see the drive belt above the belt to the mowing deck, it probably needs replacing. At least look to see if it is slack and loose. You will just make things worse by pushing it etc, unlaess it is the clutch, which I doubt as it it is normally a worn belt. I would replace the blade deck drive belkt too at the same time .
tires are ok but to move front with the machine we - b94db52e-1ef1-42c3-8e63-2737d96a6af8.png
Posted on Nov 30, 2014
4 Suggested Answers
carlsbiz
  • 1124 Answers
SOURCE: Belt slips from pully
If the belt is getting older,, like a few years or so - the belt can get stretched.. If this is the case - you might consider replacing the belt..
Posted on Jul 08, 2009
  • 24 Answers
SOURCE: i have a 2000 mtd
You may have a bearing that is locked up, check to see if you can turn all the pulleys freely. If you cannot you may have to replace the one you can't.
Posted on Sep 14, 2011
  • 11 Answers
SOURCE: mower will not move
make sure the trans disconnect rod is pushed in.
Posted on Aug 11, 2012
I have a creda tvr2 tumble dryer. The fan belt has snapped but i I have purchased a new one. I want to know the easiest way to replace it. Cheers
Not totally clear on the particular model, but generally the belt is the same on most dryers.
Definitely do not mess with that thing in the middle there, that is the pivot point for the drum, and the place where the delicate heating elements usually are.
The belt will go all the way around the drum (tumbler); around the motor pully there you see in the opening there, and then arround another pully that is spring loaded to keep the tention on the belt.
It will probably take a tool to pry the spring loaded pully back so you can get the belt on.
Usually too, the machine pops apart with some force if you pry between the seams on the front, either the top pops up, or the front pops forward, then screws inside lead to the rest of the way.
Over all, the front casing will have to move forward so you can get the belt arround the drum, then move back to keep everything from falling in every direction. Once the belt is around the drum, it's just a matter of weaving it around the other two pullies.
It is not an easy task.
Nov 01, 2012 | Dryers
When running on our treadmill the belt slips.
Hello, It sounds like you have aslipping front roller pully. Remove the motor hood and watch the front roller while you are on it. Once the belt is moving slowly, try to stop the wlak belt by planting your fett for a second, if the walk belt stops, but the drive belt and motor continue to run, the plastic pully is slipping and the whole front roller will need to be replaced.
Hope this answers your question.
Jan 16, 2011 | Nordic Track NordicTrack A2750 PRO...
Belt won't stay on the pulley
These belts are really sensitive. Try messing around with it. Making srue that the belt isnt coming off the big tub pully. You tub pully isnt loose is it. Make sure the bolt that hold the pully onto the tub is tight on. Make sure the pully isnt loose. Inspect it for any small craks where that boltt tightens up. If the pully check out ok. Check the small motor pully as well. Make sure that isnt loose or anything. Pull on it if if its loose then thats you problem.. Inspect both pullys good. I would assume belt is in good shape right? If both pullys check out ok, then i would try to get the belt on and just mess around with it, spin the pully and if you se the belt starting to slip off adjust it as you keep spinning the pully....hope this helps
Jul 31, 2009 | Maytag Neptune Washer
I have a walk behind mower. The drive belt broke and I replaced it and now it wont pull itself. The wheels still spin if I lift it up but when I set it down it wont go anywhere
you must have a belt tensioner somewhere. Have a look near your belt pully or a idler pully that has an adjustment screw where you can tighten your belt to give grip. It appears the weight of the mower is causing the belt to slip hence it no moving because your belt /belts are slipping
Jul 02, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Belt slipping off of pully on maytag neptune mah5500bww
I loosed the moter and the belt is staying on. However, my belt is cutting the tub when the belt is moving off the pully.
Apr 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
HOW DO I REMOVE SERPENTIENE BELT?
On one of the pullys you will see what they call a tensioner pully. Its a small pully with a flat surface with no lip to to prevent belt run off and is the only pully that will pivot on a springloaded arm. Also, the backside of the belt will be the side running across that pulley. Look at the arm on that pully and sometimes (depending on the design) you will may see a Square hole. That hole is made to place a 3/8 " rachet drive or breaker bar into it and by pushing or pulling (depending on your position relative to the pully) you will pivet the tensioner pully so that the pulley moves away from the belt. It should pivet in one direction only. Watch the tension in the belt go slack. Then as you keep the pressure on the ratchet with the pulley fully released (when you can piviet it no more) use your other hand and slip the belt out from under the pully. If you do not see a square hole you can will need to use a pry bar and find a location to pry against the pulley arm that will release the tension. This arm is spring loaded so use caution and be safe that you do not slip to avoid injury.
Mar 17, 2009 | 1997 Kia Sephia
How do I replace a drive belt on a Frigidaire Washer, Model FWS645RBS4?
reomove the front panel then you will see the belt you can slip it on the motor pulley first then you will need to push in the idler pully to spin it around the transmission pulley
May 31, 2008 | Frigidaire Washing Machines
Hotpoit belt
hook the belt around the motor spindle first then get the belt as far round the pully as you can once at that stage hold the belt firmly as you can on the pully and turn the pully round making sure that the belt does not slip off keep turning the puully round till the belt is fully on once on spin the drum around by hand to make sure that it is on the pully square with motor spindle. job done. if this helped please leave feed back.
Feb 20, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Replaced idle pulley but drum wont spin when clothes are in it
Ok, when you removed the front cover to gain access to the idler pully, did you make sure that the drum didnt slip off one of the two roller wheels in the bottom rear of the dryer. If you get one of those roller wheels jammed and not in the track right, they will jam up. Look down at the bottom, grab the rollers, and pull them forward to be sure they are in the groove of the drum. Also, are you sure you relooped the belt correctly back around the idler pully? The best way to loop the belt is to place the idler pully in the correct position, then drop the belt down in front of it, loop the belt under the idler pully, push it back to tension everything, then take the loop and go over the motor pully (should be pretty tight). See if one of those solutions will help. Also be sure that you are properly getting the drum in the right position over the front seal (front should go on pretty easily, if not, reach your hand in the door, and lift up on the drum to center). Thanks and good luck!!!!
Jan 25, 2008 | Dryers
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
