Question about Sony Playstation 3 (PS3) Console
<!-- from fixya rte -->My ps3game console will not take games - Sony Playstation 3 (PS3) Console
  • 3 Answers
If you mean it won't load from a game disc I've had this problem with mine. It was an older ps3 with a lot of hours on it. I would clean the laser lens with a q-tip and rubbing alcohol. When the lens gets too dirty it can't read the disc. I tried laser lens cleaning discs (I know they recommend not using them or touching the laser lens for that matter) they worked a couple of times but usually wouldn't. I had to disassemble my old 80gb or actually just open the case unplug 2 connections from the disc player and remove it. Then take the metal case off the disc player. DO NOT pop the disc player completely apart! The plastic gears in the drive and ejection system have to be in time. Not quite so easy to fix. With the metal case removed you can reach the lens or lenses (there are 2 one is for blue ray I believe) with a cotton swab dipped in rubbing alcohol to clean it. This worked for me at least a dozen times if not 2 dozen.
Posted on Dec 08, 2014
2 Suggested Answers
SOURCE:
flowtron2k2
  • 95 Answers
SOURCE: reads everything but ps3games
ok my friend, the blue ray laser has two high energy beams at 450nm(bluelight) and 730nm (redlight). the highpower diode on your machine im afraid has failed. The bluray light reads bluray games and bluray dvd's. the lower power red light reads audiocds and regular dvds/dvdrs. you need to install a new laser ..only 100 i charge or 160 from sony (150+TAX+2 week wait+frustration from not playing COD4)
Now if you have the newer model laser KES410ACA, then you have 2 SEPARATE light sources...these tend not to fail as often
Posted on Nov 12, 2008
Its plugged up to my tv and will turn on, you can hear the disc moving but there is no picture on the tv screen. I was just playing the game 2 days ago with an hdmi cable, unplugged it and brought it home...
Hi chante,
Yes the disc reading problemon the PS3 is massive!
Let me run through what is going on and how you can fix it:
Cause:
It is the laser that needs readjusting in order to fix this problem. The goodnews is that the drive will still work as long as you readjust the laser inmost cases - so you don't need to replace the drive!
Solution:
You can send it in for Repair and they will fix it for you - although this willcost about $150 in a repair bill and you can expect to wait for about 4 weeksto get your console back.
Quicker Solution:
It is possible to fix the PS3games reading error from home because as mentioned above all you aredoing is readjusting the laser.
Now if you want to go down this route check out the reviews of the top guidesand see what they offer first below:
Click Here For Reviews Of TheTop PS3 Repair Guides.
Hope this helps!
Aug 14, 2011 | Sony Playstation 3 (PS3) Console
My console wont play games
Hi Killa,
Cause:
Solution:
Quicker Solution:
Hope this helps!
Aug 11, 2011 | Sony Playstation 3 (PS3) Console
Xbox Console: i have an irish xbox but american games do...
The Xbox 360 Console is protected by region code. Basically US games will only work for US consoles same as Europe games will only work in Europe console.
May 06, 2010 | Microsoft Xbox Console
Wont play some ps3games like airborne or warhawk
Check where you keep your PS3 while playing. Could it have overheated, if for example you keep it in a cupboard. If you think so, move it to a better place, then let it cool for a while. The PS3 has a great cooling system, it just ocassionly overheats in enclosed spaces.
This could only be a software fault in the PS3. Turn off the console completely, wait an hour or two and then try again. If it still doesn't work, try the following:
1. Don't open the console. If it only doesn't play Blu-ray discs (movies and games) then it might be the lens that reads blu-ray disce, which is a seperate lens from the CD or DVD reader. Call the Sony helpline (UK: 08705 99 88 77 national rate, as for US I am really not sure since I'm in the UK.) They will give you advice.
2. If you don't want to call Sony, most games' stores will find out what the problem is and fix it. Or, if you can, get the console replaced (though you will lose the data on your hard drive.)
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
Can watch movies (not blu ray) and play ps2games (not ps3)
You need a new blu-ray laser. model number kes 400aaa. takes about 30mins to change out.
Jun 17, 2009 | Sony Playstation 3 (PS3) Console
I put a game in the console and it says reading but doesnt
# Turn console off and then on. # Clean the disc and examine it for flaws or scratches. # If this behavior occurs with one or two discs, search the Microsoft Knowledge Base for the specific game title(s). If you find a known problem, follow the information outlined in the article. # Delete the appropriate saved games. See Note 1. Copy a saved game to a Memory Unit (MU) if you have one available. # Try three other games, and then try the original game again. # Try the game on another console if possible. # Replace the disc at retailer. # Repair the console Note 1 If a saved game file is corrupted, it can produce a disk error message in that game, particularly when the game starts. You can resolve this issue by deleting all saved game files for the affected game from the Xbox hard disk. This method is effective approximately twenty-five percent of the time. If you experience this disk error message with more than two games, this procedure will likely not resolve the issue. Another trick to try is to turn your console so its vertical( sometimes works)
Jun 03, 2009 | Microsoft Xbox 360 Console
Reads everything but ps3games
Nov 12, 2008 | Sony Playstation 3 (PS3) Console
PLAYSTATION 3
turn on the ps3 then keep your finger on the on button for approx ten seconds-this will reset the machine to default.
Jun 04, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
44 people viewed this question
Top Sony Video Game Consoles & Games Experts
juanmireles1
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
