My hitachi washing machine sf-90jk spin error c8
Spin not warking lid is not locked
  • 641 Answers
SOURCE: Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Posted on Aug 31, 2007
  • 3 Answers
SOURCE: fisher paykal top load washing machine
I had the same problem. I unplugged the machine for a while (overnight) and it then worked properly when I plugged it back in. Probably just a circuit board issue that was cleared with the power removed.
Posted on Oct 14, 2007
SOURCE: HITACHI WASHING MACHINE MODEL SF-60.
HI,
MY MACHINES MODEL IS KW-D502-HITACHI,
MY QUESTION IS ,HOW TO USE PERFECT?
Posted on Aug 06, 2008
  • 22 Answers
SOURCE: washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Posted on Oct 21, 2008
SOURCE: Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Posted on Dec 19, 2010
SF-P95JJ GIVE ERROR C9
Not "hitachi washing machine error code c9 what to do"
electronicsfurnitureinfo.com/.../hitachi-washing-machine-error-code-c9-...
Info about hitachi washing machine error code c9 what to do in Electronics ... What do you think about this washer Electrolux ZWT-61M, do you like the design?
Jul 28, 2015 | Washing Machines
My washer machine hitachi nw -d8gx code c8 what going on?
C8 indicates that the lid cannot be locked.
Is the lid closed?
Are there any foreign objects in the lock?
Check that the lid is completely closed.
Check that there are no foreign objects in the lock.
Link to users manual.
http://www.hitachi-th.com/hitachi_new/Download/SF-140SV_EN.pdf
Aug 03, 2014 | Washing Machines
Ignis fl 800
i need your help what do i need to do with this problem my washing machine model hitachi 8kg sf-80h cant spin and draining the cloth
Dec 06, 2013 | Washing Machines
Hitachi sf-95kj washing machine stop and shown error code c4 when it's go to spin mode
A lot of new machines need the hoses cleaned out. The slime up. The pump gets shut down and the unit won't spin. Unplug unit before you service it to avoid shock. Top has to come off, and front also.
Nov 16, 2013 | Washing Machines
My washing machine hitachi make model no SF-70EJ having problem with spin please give assistance what to do
Hi.
Most spin problems are consequence of drain system faults.
The first part to check is drain system. Check the drain hose at the back and the drain filter attached to the pump. See article at the end for more detail.
Most machines' timer boards do an additional check on the lid switch before starting the spin part of the cycle. If the lid lock light is flashing and the machine does not spin the lid switch is probably defective.
The lid switch is tested jumping its contacts or reading Ohms at switch terminal. A two-terminals switch must read continuity (low impedance) when door is closed and must read open (infinity of Ohms) when door is open. If the switch is a three contacts, the third contact is called "heater". In that case there must be continuity between the three contacts with lid closed. If the model instead of a simple switch uses a wax motor, then the lock cannot be tested by jumping contacts. The lock motor must be tested reading Ohms and checking that impedance is the same as indicated in service manual.
If lid switch and drain system are OK, then the pressure switch must be tested.The pressure switch detects the water level and among other things determines when to advance the cycle to spin.
If all the above is OK, then the motor and motor control unit (if present) must be tested.
Please read the solution in the article below for more:
If you have no spin ...
You can find parts and diagrams for most appliances using the links listed on this page: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 04, 2011 | Washing Machines
Hitachi washing machine sf6500px washes ok but wont spin, digital signal says dE, does anyone know what that means please?
im not 100% on hitachi gear dont see alot where im from, but for most washing machines DE normally means the lid is open as they have small magnets in both the lid and frame of the washer, most machines will not begin to spin if the lid is not shut they will fill and wash but not spin purely as a safety precaution, if the lid is shut it means the lid (you may have a latch that actually locks the lid shut or just a reed switch magnet sensor that simply detects if its opened) reed switch or lid lock is broken or faulty normally pretty quick and easy to repair
Jan 18, 2011 | Sprint Hitachi P300 Cellular Phone
Jul 29, 2010 | Washing Machines
Aug 31, 2007 | Washing Machines
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
