Question about ASUS Computers & Internet
How do I remove the screw plate that holds the cd driver, Asus K55A-HI5014L laptop?
    Problem Solver:
  • 14 Answers
Here is a video from Youtube made by Bob Johnson.com
This is how it's done........ https://www.youtube.com/watch?v=qEDwR__7Pd0
Posted on Dec 01, 2014
4 Suggested Answers
SOURCE: ASUS M300Np won't start - need to reseat RAM but unable to access
my computer will come on for a few seconds and then shut off and it is plugged in
Posted on Oct 13, 2009
Geekman
  • 32281 Answers
SOURCE: Hi, I am wanting to take the keyboard off of my
There may be a screw on the bottom of the laptop under the middle of the keyboard.
Posted on Apr 14, 2011
bronk50
  • 27725 Answers
SOURCE: how to activate bluetooth on asus k55a
Asus manufactures computers, notebooks, motherboards and other PC components. Some of their machines have Bluetooth capability. You can use prompts in Windows to make sure that your Asus's Bluetooth capability is up and running.
Open Bluetooth Settings
In the task bar, right-click the Bluetooth symbol, then select "Open Bluetooth Settings." If there is no Bluetooth icon in the task bar, go to "Start," then "Run" and type in "bthprops.cpl." Click "OK" to open the Bluetooth Settings window. b> View Options b> Click on the "Options" tab, and select the "Turn discovery on" check box. Click "Apply." b> Allow Devices b> In the "Connections" section, select the check box for "Allow Bluetooth devices to connect to this computer" so that Bluetooth devices can connect to your Asus. Click "OK." b> Testing for Bluetooth b> If you are unsure whether your Asus is Bluetooth capable, try typing in the "bthprops.cpl" command in the "Run" box. If it's unsuccessful, your machine isn't Bluetooth capable. Hope this helps.
Posted on Dec 08, 2012
ASUS K55A won't boot from OS installation on C: Drive. HDD does not show on BIOs boot.
try re seating the drive and your ram. if it does not show then your hard drive is bad.
Dec 28, 2014 | ASUS K55a 15.6-Inch Laptop Black Intel...
Hi, go here: https://search.yahoo.com/yhs/search?p=how+to+replace+the+cd+drive+in+a+asus+K55A&ei=utf-8&hspart=att&hsimp=yhs-att_001&type=sbc_dsl
Nov 29, 2014 | ASUS K55A-HI5014L 15.6 Laptop i5 2.5GHz...
"k55A" dc jack replacement
Hello Kenneth,
The dc jack replacement cable connects from the white connector to system board and the connector where you connect the adapter lay on the edge of board usuallyc6c10d03-2117-4a84-8cc2-a16171601653.jpg
I like to use a litte bit of super glue to keep it held in place on the board.
Gotta remove some components to access it .
Mar 12, 2014 | ASUS Notebook K55A-DB51 15.6inch Core...
Universal password
You need to call/chat with ASUS tech support or replace your BIOS chip with a pre-programmed BIOS chip.
Mar 09, 2014 | ASUS Notebook K55A-DB51 15.6inch Core...
How do i eject cd from my asus k55a laptop
if you look at the cd drawer you will see a little hole. push a pin in the hole and the drawer will open.
Feb 22, 2014 | Computers & Internet
Asus k55a-rbr6 Cd Drive not recognized in Devices and Printers, will not run any CD.
The Asus K55A-RBR6 optical drive uses the Windows built-in driver. The drive may have failed or it could have a power or cable issue. To check for a power issue, try ejecting the optical drive by pushing the disc tray into the computer. If the drive tray ejects and retracts, it has power.
First, go to the Device Manager and check if there are any driver issues identified by Windows. (Click Start > Control Panel (in the right hand column. Click on either System and Security > System or Hardware and Devices and then select the Device Manager. Expand the section for DVD/CD-ROM drives and look for a yellow triangle with an exclamation point or a red triangle with an x. Try to uninstall the driver and then reboot the machine. Windows will try to restore the driver. (You should alsocheck Windows Update for any optional drivers. Start > Control Panel > System > Windows Update.)
Check that you have installed the latest available BIOS upgrade (407), from http://www.asus.com/Notebooks_Ultrabooks/K55A/#support .
The laptop uses a SATA slimline internal optical drive. The drive needs a power connector from the internal power supply and a SATA cable connected to the motherboard. You can access these if you disassemble the laptop. You may want to try just replacing the drive (~$25 at many vendors). If the second drive doesn't work, then try replacing the SATA cable and make sure it's well seated at the motherboard and the optical drive. There aren't extra power cables in most laptops but you should check for damage. Alternatively, get an external USB optical drive to replace the internal drive.
I hope this helps.
Nov 15, 2013 | ASUS Computers & Internet
Touchpad enable
you enable/disable touchpad by pressing the Fn-key and press F9 at the same time.
Sep 07, 2013 | ASUS Notebooks K55a-xh51 15.6" Led...
Computers & Internet Logo
48 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
