Question about Hardware & Accessories
How do I set a work choice mechanical timer?
Tried to run it start at 6 pm stop at 10 ran all night still on
  • 5,245 Answers
SOURCE: Woods Model 59200V Indoor Mechanical Timer. Not working
book says peg should be down for on and peg should be up for stop. How the hell does one pull the peg up...it is blocked and can only be pushed down...now what I am missing?
Posted on Dec 19, 2009
SOURCE: I have GE Model #15089
The problem with answering questions where somebody cannot program a timer, or programming stopped working, is that expert doesn't know if timer is defective, or needs to be reset, or timer has conflicting programming, or if person has mis-read the instruction manual, or if wrong button sequence is being used, or if internal battery has gone bad, or if circuit has interference or loose wiring, or if light bulb burned out, and however expert guesses, the person asking question is unhappy because the timer still doesn't work and/or the manual still doesn't make sense.
I work with timers every day and suggest the following steps to get started:
Reset timer and try setting program again.
Write out steps in manual at point where timer doesn't seem to work.
Double-check that you are pushing correct buttons all the way down.
Make sure same days of operation are selected for ON and for OFF. For example if ON is set for all days, and OFF is set for Tuesday, then timer will not work as expected.
Reset timer and make sure there are no conflicting or overlapping programs, or timer will not work as expected.
Test outlet with cheap circuit analyzer from home center, try timer on different outlet, try timer on different Load, check that Load works when plugged into outlet without the timer.
Save some headaches listed above, and buy another 15089 at Home Depot and return defective one in new package.
http://waterheatertimer.org/GE-timers-and-manuals.html#15079
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 26, 2011
SOURCE: I have difficulty setting up the automatic timer
Timer model number is not known.
Model number shows on inside of timer door.
Open following links for Intermatic T100 series timer, add a comment for different timer instructions:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Posted on Jul 24, 2011
SOURCE: I bought a home which
More information is needed about timer.
Check out following options, or add a comment any time.
Adding a comment send email and I will answer.
1) Open following link for setting analog timers.
Applies to in-wall and plug-in type analog timers.
http://waterheatertimer.org/How-to-set-timers.html
2) For a programmable timer, a comment and describe timer buttons, and include if timer is in-wall or plug-in.
3) Open following link to see Intermatic, Woods, and GE timers plug-in, in-wall, and box timers, including indoor and outdoor:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Posted on Sep 08, 2011
  • 5245 Answers
SOURCE: Problem programming timer settings. Is it supposed to be random or continuous?
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#50006
2) How to set analog timers by experimenting with features:
3) 50001 timer is not random vacation timer like the 50003.
50000 series timers by Woods have 1 year limited warranty, and they are a new design released this year. However the analog timer design has been around for many years.
4) If timer is acting randomly, then
a) timer is defective,
b) the override switch is not fully positioned at 'timer on,'
c) segments are not lifted fully in position,
5) ... other more remote causes: outlet might not test 80% rated voltage?, outlet might have reversed polarity?
5) Try timer on different outlet with different light.
6) As the timer dial rotates, the segments push small lever, and the lever moves switch that turns lights on-off. I suppose if this lever was broken or switch was broken, then timer would act more randomly.
Posted on Dec 06, 2012
I want to set the timer to go out pm, and on am. I find the instructions very confusiing
Actually the timer dial can be either day or night, but usually the dark background with white numbers is 6 pm to 6am (night time)
While the white background with dark numbers is 6 am to 6 pm (daytime)
Gene
Sep 17, 2014 | Hardware & Accessories
How stop sprinklers from starting over
You only program the first zone to turn on at a specific time. The rest of the zones go in sequence.
Aug 22, 2014 | Orbit 6 Station Indoor Dual Program...
I have GE Model #15089 digital timer. I want to reset time to come on to 7:30 pm and turn off at 10:30 pm. It was previously coming on at 6:00 pm and off at 10:30 pm and working fine but when I tried...
Apr 25, 2011 | Hardware & Accessories
My Whirlpool Inglis Model IED4400SQ0 dryer just stopped. The fuse is fine. I think the problem might be in the start button but I'm not sure. I think this is it because the dryer stopped 2 days ago, then...
this doesn't have a board in it so you either have a bad timer or motor,i would think it would be the timer,try tapping on the timer with a screw driver or something light or wiggle the timer knob and see if it starts,also did you have this on timed dry?it sounds like the timer died and then somehow power went through it again and it ran,the timer controls how long the dryer will run so this is why i think it could be the timer,or a broken wire but try wiggling the knob and see if it starts.let me know thanks.
Dec 22, 2017 | Whirlpool Inglis IP8200 Dryer
We have a honeywell cm921 and we cant set the therm astat to come on in the mornijng and then go off then come on again in the afternoon on timer please can you help
Your CM921 has 6 built in temperature settings based on time of day:
1 - 6:30 AM
2 - 8:00 AM
3 - 12:00 PM
4 - 2:00 PM
5 - 4:00 PM
6 - 10:30 PM
meaning that at 6:30 AM the themostat will change its temperature setting to setting 1, at 8:00 AM it will change the temperature setting to setting 2, and so on. To schedule temperature settings which best fit you, determine which time periods you would like more or less heat.
For instance, to fit what you requested in your question you could program a temperature you would like to maintain in the morning and afternoon times when you would like it to be on, and in the time periods in between set a lower temperature as follows:
1 - 20C
2 - 16C
3 - 16C
4 - 20C
5 - 20C
6 - 16C
With this example your thermostat would turn on at 6:30 AM as long as the temperature was below 20C and maintain that temperature until 8:00 AM. At 8 it would change its setting to 16C allowing temperature to drop from 8 AM to 2 PM to a lower setting to conserve energy until afternoon time when the setting would change back to 20C from 2 PM to 10:30 and then change back to 16C to save energy throughout the night. The actual temperatures would be at your discretion based on your individual comfort level.
Pages 5 and 6 of the following link will guide you in setting each of the 6 temperature settings.
http://www.wolseleysbc.co.uk/_STEPData/Assets/Honeywell%20CM921%20Room%20Thermostat.pdf
I hope this helps. Let me know if you have any additional questions.
Dec 10, 2010 | Honeywell Programmable Thermostat Heater
My grow light is on a timer and was off last night when it was suppose to be on i played around with it and got it on, but once again as soon as it went off wont go back on... Maybe it is something to do...
check and make sure you have the timer right am/pm.also the mechanism that rotates the timer might also be bad or going bad.if the am/pm timing is set right i would try another one from your local home center and if it works its likely the timing mechanism.
Mar 24, 2010 | Garden
Dec 18, 2009 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
Hardware & Accessories Logo
4,295 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
