Question about Onkyo TX-NR801 Receiver
Zone 2 music on zone 2 speakers has become distorted at all volume levels. Just started happening, could the zone 2 amp be going bad. Sound from the main speakers is perfect.
    New Friend:
  • 59 Answers
Re: Zone 2
If you have a main speaker system working properly, takea known good amp to ch2. wire the main pre amp out to amp 2 input.. turn both units on(no spkrs connected), fire it up. if the amp does not go into protect mode, turn ALL power off to the system.,connect one Spkr channel on A2, AND TURN THE VOLUME DOWN FIRS!!!!. pOWER UP THE SYSTEM AND SEE WHAT YOU GET.BE GENTLE WITH VOLUME SETTINGD! If ch 1 works, repeat procedure with ch 2 pre amp out.
Posted on Dec 30, 2007
0 characters
3 Points
Look in the speaker setup menu. The zone 2 speakers usually default to surround back, and you must go into the setup menu and tell it you want to use zone 2.
Dec 22, 2012 | Yamaha Audio & Video Receivers
Amp keeps shutting off
• Check again with no speakers connected, if it doesnt shut off,
Check speaker system, connect one at a time to find the cause.
• If the receiver still shuts down without the speakers,
troubleshoot inside the unit.
Aug 04, 2012 | Yamaha Rx-a710 Aventage 7.1 Home Theater...
I cant get zone 2 to work on my yamaha rx v673. They are 2 outdoor speakers.. please help
I had a similar problem where I could not increase zone 2 volume - Page 100 in the manual notes that 'power amp assign' must be set to "7 Ch + 1 zone" before zone 2 max volume can be changed. Try that.
Jul 08, 2012 | Yamaha RX-V663 Receiver
Yamaha rx-v1600. I am failing in my attempt to get sund out of zone 2 speakers. I have the 2nd zone speakers hooked into surround zone 2/3. In primary zone I only have center and surround back as my fronts...
After 6.5 hours, I am now listening to music outside on my patio using my rxv-1600!
Connect your speakers to the Presence Zone 2(3) output on back. Then power up amp and select zone 2 on front of amp. Nothing will happen, because as I found out, you must route an input to zone 2 or 3. Which is cool, because you can listen to something outside that is different from your inside.
You select what to route to the zone by pressing Zone Control button, just right of zone 2 and 3 button. While you see red zone light blinking, rotate input select knob to prefered input, i.e. radio/cd/aux/etc... also, you can adjust volume by pressing zone control and turning up the volume knob, only while ZONE light is blinking.
hope that helps, i know i was frustrated figuring that out!
Nov 25, 2010 | Yamaha RX-V1600 Receiver
Denon AVR-3805 zone 2 no longer working
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Denon AVR 1609 Receiver Zone 2 has no sound
you have to change the power amp assignment to zone 2, you must also have Analog audio connections to the Denon from your devices.
Try this put your remote in the zone 2 mode, select tuner in zone 2 and turn zone 2 volume up to -10
Dec 18, 2008 | Denon AVR588 Receiver
Zone 2 problem
I know this is old and im sure you have it solved by now, but it might be a good idea to check the amp setting of Zone 2. Is it switched to Internal or external? I remember something strange about this amp in that when you change from using the rear surrounds and go to use them in Zone 2, it resets the amp setting or something like that. Hope it helps if you still need it.
Sep 15, 2008 | Yamaha RX-V659 Receiver
Zone 2 connections
go into your amp settings menu then to speaker settings,set zone 2 on and main on, turn up the volume for zone 2 about half way then connect phono cables from zone 2 pre out to a input on the external amp (eg cd input )
never use the phono input this is for turntables,connect this amp to your speaker switch/selector then to speakers.
hope this helps
cable guy.
Jun 04, 2008 | Yamaha RX-V2500 Receiver
No sound from Zone 2/3 speakers
make sure that you are selecting the sp2 to be working with zone 2/3. Be careul and check volume to zone 2/3 on front panel before you activate sp2 with zone2/3.
Jan 20, 2008 | Yamaha RX-V2700 Receiver
No sound
possible problem will be on the speaker relay ckt. as discussed in onkyo's service bulletin.
"When the speaker relays are activated, the collector of Q231 and Q232 should drop to near 0Vdc. Voltage can be monitored at terminal P6830 and P6832. Q231 supports RL6600, RL6602 and RL6603, where as Q232 supports RL6605 for Zone 2 operation. If the DVC at P6830 collector or its follower terminal is HIGH, it should be an open transistor Q231."
Oct 08, 2007 | Onkyo TX-DS797 Receiver
Onkyo TX-NR801 Receiver Logo
147 people viewed this question
Top Onkyo Audio & Video Receivers Experts
 Mike M
Mike M
D. E. Hev
Are you an Onkyo Audio and Video Receiver Expert? Answer questions, earn points and help others
