Question about Lasonic TRC-931 Cassette Boombox
Which wires do you hook up from the back to the front( on the inside)
Two wires on the back seven connector's on the front panel( inside)
Front 4 usb ports and microphone and headphone jacks don't work but the rear usb and speaker jacks do work. I've had the computer new since 2009 and they have never worked.
it sounds to me like the wires from the front panel connectors are not connected to the motherboard inside the computer case, open the case up find the front connectors wires inside and find out if there are any connectors on the motherboard to plug them into.
the reason the rear ones work is because they are soldered directly to the motherboard.
good luck.
Jun 28, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
REPLACE BELT
Disconnect the power.....PLEASE!
Look under each side if the control panel on the bottom. There you will find 2 1/4 inch screws....unscrew these about 6 full turns...this lowers the hooks that hold control panel in place...it is hinged and will flip down...sometimes you have to pry it down gently!
Once the panel is down you disconnect the white wire connector going to the door switch and remove the 2 screws holding the front cover on....then carefully lift up on the front cover to unhook it from the 2 hooks on top...kind of slides up and out. The tub is going to stay inside and drop down...the front cover supports the tub. At this time you can remove the tub and clean out all the lint...(recommended)
Putting the front cover back on is a little tricky...you have get it attached on the top hooks and then pick up on the tub to put it on the bearing ring in the front cover ..then put the 2 screws back in...3 hands are nice to have now.
Let me know if you need any further help. Thank you and have a good day.
Apr 06, 2008 | Washing Machines
Headphone jack is broken INSIDE the port and is overriding the speakers. Can I override this override?
Or instead of having to open up your computer and messing with the mobo. Just use the control panel in to disable the headphone jack.
May 09, 2014 | Dell OPTIPLEX 745 PC Desktop
Wire came loose from driver door harness on 2000 grand prix
My service information say's that is a dark green wire . Door side connector ????? Where is this connector located ? In the door ,A pillar . I see three different connectors that wire is hooked into. Connector at the driver door master switch ,C-355 C-301
Check it out here http://www.bbbind.com/free_tsb.html Free wiring diagrams . Enter your vehicle info. Year ,make , model an engine size. Under system click on body & accessories ,then under subsystem click on power windows. Click the search button then the second blue link.
C301 (16 cavities)
Body wiring harness to the left front door wiring harness, behind the trim at the base of the A pillar
broken inside the flex boot from body to the door ?
Nov 17, 2017 | Cars & Trucks
How to remove disk drive
The front of your computer is the Front Panel. The Front Panel needs to be removed, along with the Side Panel, to replace an optical disk drive. (CD/DVD drive)
Gateway Support > LX6810-01 Desktop PC > Main Support page,
http://support.gateway.com/us/en/product/default.aspx?tab=1&modelId=2308
In the list click on -> User Guides
In this list click on the blue -> Gateway Hardware Reference Guide
This is a Zip file. If you do not know how to 'unzip' a Zip file, please state in a Comment, and I will guide you.
Page 45: Opening the case
FIRST <-
A) Unplug the computer from power.
B) FOLLOW Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your computer.
Computer on a table, computer unplugged from power, computer case open.
TOUCH an unpainted surface, of the metal frame of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
Looking at the Front of the computer the LEFT Side Panel removes.
There are two Philips head screws along the edge of the Side Panel, on the back. One towards the Top, one towards the Bottom.
These are removed.
The Side Panel is then slid back with the 'finger bump' on the panel, until it stops. Then the top is brought out, and the Side Panel removed.
Removing the Front Panel: Page 47
Look towards the inside, and towards the Front.
See the 3 black plastic tabs, sticking in slots of the metal framework?
One towards the Top, one in the Middle, and one towards the Bottom.
These tabs are gently squeezed in towards the inside. Towards the motherboard.
These tabs are formed out of the plastic of the Front Panel. They have a hook on the end. The hooked end catches on the side of the slot, in the metal framework of the computer case.
Once the hooked end is moved to the center of the slot, the tab is free.
Ease the Top tab in, then follow with the Middle tab. The Front panel should start to come off.
Now move the Bottom tab in.
The Front Panel will now swing towards the Right.
USE CARE as it is NOT stated, or shown, if the main wires are going to the Front Panel, OR the Front Panel is merely a cover.
You DO NOT want to pull the wires off of the Front Panel header, on the motherboard.
If the Front Panel has wires attached, and is not just a cover, use care, and set it to the side.
[The Front Panel header, is the area of contact pins on the motherboard, that the main wires from the Front Panel connect to ]
You will see two Philips head mounting screws, along the rail in the optical drive bay cage, that hold the optical drive in, that you wish to remove.
Remove these screws, keep track of them. (They like to roll off of the table, lol!)
Slide the drive forward a little, then holding onto the drive, remove the power cable, and data cable. If it is the main optical drive, (And you have two drives), you may also have to remove a small audio cable.
Now slide the drive out of the front.
Harddrive removal: Page 52
Remove the power cable, and the data cable.
[For a 4-pin standard Peripheral power cable, you just ease the connector out,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
BY THE CONNECTOR, and NOT the wires.
For a SATA power cable there may be a small lock tab on top, that you depress down with a thumbnail,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata ]
The Harddrive has a metal 'box' cage around it. The harddrive cage.
On the back of the cage, (Towards back of computer), there is a thumbscrew located at the top of the cage.
This thumbscrew is removed, and the Harddrive cage is slid out, towards the back of the computer.
Remove the screws that hold the Harddrive in the harddrive cage.
Then remove the Harddrive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 14, 2012 | Gateway LX6810-01 PC Desktop
How to remove dryer cover?
Instructions
    • Open the dryer door and locate the screws underneath the front lip of the dryer top. Unfasten the screws with a screwdriver and set them out of the way.
    • Flip the dryer top back so it is setting on the rear hinges. Locate the screws on the inside of the front panel near the top of the dryer.
    • Unfasten the screws on the inside of the front panel with a screwdriver and set them in a safe place. Lift the front panel up so it comes off the metal clips at the base of the dryer in the front.
    • Unplug the two-pronged electrical wiring connector from the back of the front panel by hand. Set the front panel of the Amana dryer cabinet out of the way.
Jul 02, 2012 | Amana ALE230RAW Electric Dryer
I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
Answer
FRONT DOOR TRIM PANEL
REMOVAL
Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
Disconnect wire connector from courtesy lamp.
If equipped, remove screws attaching door assist handle to inner door panel.
If equipped, remove screw attaching door pull cup to inner door panel.
If equipped, remove screws attaching trim panel to door from below map pocket.
If equipped, remove window crank.
Using a trim stick, remove screw cover from switch panel.
Remove screws attaching switch panel to door trim.
Remove power accessary switch from door trim Front Door Switch Panel
Disconnect power switch from wire connector.
If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
Lift trim panel upward to disengage flange from inner belt molding at top of door.
Tilt top of trim panel away from door to gain access to latch linkage.
Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
Separate linkage rod from latch handle.
Remove front door trim panel from vehicle.
INSTALLATION
Hold top of trim panel away from door to gain access to latch linkage.
Place linkage rod in position on latch handle.
Engage clip to hold linkage rod to inside latch release handle.
Place front door trim panel in position on door.
Install trim panel into inner belt molding at top of door.
Install clips to attach door trim to door frame around perimeter of panel.
If equipped, install screw to attach door trim to door panel behind inside latch release handle.
If equipped, connect power switch into wire connector.
Place power accessary switch in position on door trim.
Connect wire connector into memory seat/mirror switch and install switch into trim panel.
Install screws to attach accessary switch panel to door trim.
Install screw cover into switch panel.
If equipped, install window crank.
If equipped, install screws to attach trim panel to door inside map pocket.
If equipped, install screw to attach door pull cup to inner door panel.
If equipped, install screws to attach door assist handle to inner door panel.
Connect wire connector into courtesy lamp.
Install lamp in door trim.
Feb 02, 2012 | 2000 Dodge Caravan
Hello i need to know how to reconnect the computer case wires to a sr1703wm compaq motherboard
Hello.
The Compaq Presario SR1703WM desktop computer, uses an Asus A9AE-LE motherboard.
HP/Compaq's name is AmberineM - GL6E
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00496280&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=1815742
1) I would like to start with the Front Panel wires.
The Front panel, is the plastic front on your computer tower, where the Power On button, Power On LED, and so on is located.
The Front Panel header is the connector on the motherboard, where the cables, (Wires), from the Front Panel connect to.
Looking at the HP Support link above, I would like you to scroll down the page to the illustration of the motherboard, and the photo of the motherboard under the illustration.
Looking at the illustration observe the bottom Right corner.
F_PANEL1 indicates the Front Panel header.
Note there are 4 pins going across the Top, and 5 pins going across the Bottom.
Looking inside your computer, the motherboard will be located in a different position, compared to the illustration.
The Front Panel header will be located Vertically, (Up, and down)
Note that there is a twisted pair of Black, and Red wires.
These wires form the Power On cable.
They come directly from the Power on switch.
There is a twisted pair of Yellow, and Black wires.
These wires form the Harddrive Activity LED light cable.
(HDD)
When the harddrive is active, this LED flashes.
There is a twisted pair of Green, and Black wires.
These wires form the Power On LED light cable.
The wires, (Cables), should be in one Black connector.
Looking at the Front Panel header in your computer, align the Black plastic connector's socket holes, with the pins sticking up out of the Front Panel header, on the motherboard.
Note that the Front Panel header is rectangular in shape. There is 1 pin missing.
The Black connector coming from the Front Panel of the computer, has one socket hole blocked off, to match.
Align the four socket holes in the Black connector, to match the 4 pins sticking up out of the Front Panel header, on the motherboard.
The other 5 socket holes in the Black connector, will match up to the 5 pins sticking up, automatically.
Use care, and you may need a bright light to assist.
These pins can be bent quite easily.
(Also watch your fingers, as the ends of the pins are S-H-A-R-P!)
2) Where it states CLRTC (CLPWD under it), is the Clear CMOS jumper.
Suggest you leave it alone.
3) Where it states F_ USB1, and F_USB2, is where the USB cables from the front of the computer connect to.
(The USB ports on the front of the computer's Front Panel.
F_USB1, and F_USB2 headers on the motherboard, are shown on the illustration to the Left, of the Front Panel header. F_PANEL1)
The plastic connector on a USB cable coming from the Front Panel, has an orientation just like the Front Panel header cable does.
There is 1 pin missing on the USB header on the motherboard.
There is a blocked socket hole in the USB cable's connector.
Align the connector to match the pins.
Doesn't matter which USB cable from the Front Panel, that you connect to the USB headers on the motherboard.
BIOS will find them, and assign an IRQ to each, once you turn the computer on.
All you will see at a first glance is a series of thick Gray insulated cables, coming from the Front Panel of your computer.
If you follow the cables by eye, you can see where the USB cables are connected to the back of the USB ports, on the Front Panel.
You may, or may not, have to remove the Front Panel to see more clearly.
Computer case open, look inside towards the Front Panel.
There is a Green plastic tab towards the Top.
This locking tab is depressed Towards the Inside of the computer, to START to unlock the Front Panel.
Towards the bottom in the same plane, is a Black locking tab. This tab is pulled Towards the Outside of the computer.
There is another Black plastic tab on the opposite side.
At the Bottom are two more Black plastic locking tabs. These are depressed down, towards the Bottom of the computer case.
One on one side, one on the opposite side.
Start by depressing the plastic Green tab, and gently easing the Top of the Front Panel, slightly out.
Then go to the two Black plastic locking tabs located towards the Middle, and depress them.
Ease the top of the Front Panel out a little more.
Finally go to the two Black plastic locking tabs located at the Bottom, and depress them.
Ease the Front Panel off.
(NOTE*
Your computer's Front Panel may not have locking tabs located at the bottom.
Just locking tabs located up from the bottom, more towards the middle)
It's no picnic for your first time, but once you have done it, it becomes easy. (Ummm, Easier!)
4) The Firewire (a1394) cable on the Front Panel, connects to the F_1394 header on the motherboard.
In the motherboard illustration the F_1394 header is located to the Left, of PCI2
Need any further cable connections, post in a Comment.
Aug 14, 2010 | Compaq Presario SR1703WM PC Desktop
How to remove drivers door panel on 1999 ford escort. I need to repair the windows switch for the drivers side. My window is in the down position and won't come up when I push the button. All other windows...
Remove the screw cap and the screw from the inside door handle and slide the handle rearward to disengage the hook from the inner sheet metal.
  • Disconnect the inside door handle from the front door latch remote control link
Remove the two-piece pushpins from the front door trim panel (23942).
NOTE: Use a commonly available spring loaded trim pad removing tool with a long thin nose to prevent damage to the door trim panel.
Release the seven front door trim panel bullet nose fasteners and push inboard, then upward to release the front door trim panel.
  • If equipped, disconnect the master window regulator control switch electrical connector
Remove the retainer from the master window regulator control switch panel.
  1. Pull outward on the cup retainer tabs and remove.
  1. Remove the master window regulator control switch electrical connector from the retainer
Jun 05, 2010 | 1999 Ford Escort
Lasonic TRC-931 Cassette Boombox Logo
51 people viewed this question
Top Lasonic Audio Players & Recorders Experts
stynger007
Level 1 Expert
Joseph Hoffmann
Are you a Lasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
