Question about Maytag MFF2557HE Bottom Freezer French Door Refrigerator
How do I read the diagnostic lights
Trouble diagnostic lights readout
    Novelist:
    Champion:
  • 210 Answers
There is probably a section of the user's manual that will tell you what each sequence of lights means, and whether you could fix it yourself or call a repairman. So, check your user manual first to see if it gives any information on it. And if it does make a note of it.
Posted on Nov 30, 2014
Overdrive OFF light is blinking....just trying to figure out how bad it is when this happens or can my transmission be repaired versus being replaced?
The blinking is a trouble code for the auto trans. It will tell you what the trouble is, which may be quite minor. If unsure, have a mechanic connect a readout device to the car to interpret this code.
May 28, 2017 | Cars & Trucks
My 1990 camry started missing and sputtering on interstate and has only started for 30 seconds In 3 days. After reading it could be Anything! Please help stranded
You are right, it could be almost anything. The first thing would be to check the trouble code readout to see if that gives a clue.
My 94 did this twice at different times. The first was fractured contacts under the base for the EFI main relay. Thus the fuel and spark would sputter on and off. Older Camrys develop this fault commonly. You can see it when you turn on the ignition, (but don't start it) and the trouble light on the dash does not show up
The second time the ECU (computer) itself had become faulty. The car would start, then not, then run rough. It is not an expensive repair with a ECU from the wreckers, and it can be tested on a diagnostic machine.
May 24, 2015 | 1990 Toyota Camry
WILL THE SERPENTINE BELT MAKE MY 97 FORD TAURS KEEP JUMPIN OUT OF GEAR
Try going back to the part store and have them to do a diagnostic readout done....
I don't think your transmission is actually jumping out of gear, But I do believe that your transmission is either low on flued or has a stopped up filter. It could possibly be that the pump is going out in your transmission or even a bad solenoid....
The problem is definately in your transmission...
Try getting back to that part store to get a troubled code read out on their diagnostic computer... Email me the codes at Andyt435@gmail.com and I'll tell you what the code is and how to fix the problem.
I hope this helps...
May 15, 2013 | Cars & Trucks
I have a Broaster 1600-1800 electric model and it takes about 3 hours to heat up. The digital readout blinks on and off saying both lo and intermittently going completely blank. After it heats up the LED's...
If the digital display is going blank, but the Power On light is staying on, the problem has to lie in either the Controller Transformer or the Controller. To determine which, just check the voltage at the 2 red wires that go from the Controller Transformer to the back of the circuit card. That should read around 26VAC whenever the Power On light is on. If the voltage is still present when the Controller goes blank, then the problem lies in the Controller. Contact The Broaster Company through their website, www.broaster.com, and call the Service Department. They can easily provide a Service and Parts Manual to you, as well as help you troubleshoot your problem. Good luck and I hope this helps.
Feb 03, 2011 | Kitchen Appliances - Others
Peugeot 206 1.4lx misfiring engine light flashing run fine for a few days then start problem again diagnostic showed too many faults to determine problem
i would reset the light and start over. it sounds like things were unplugged for testing purposes. dont let it intimedate you. let me know what else you find. you can e mail me at iambanshee74@yahoo.com
Nov 04, 2009 | 2005 Peugeot 405
Orange engine light come on
it means there is a trouble code in your computer the only way to read them is to have a diagnostic computer for your car. most shops probly wont be able to read alfa romeo codes so you may need to shop around
Oct 31, 2009 | 2000 Alfa Romeo 156
Engine light comes on when i open up throttle
I would start by retrieving the diagnostic trouble codes. To do this, with the run switch on the right grip set to run, hold the odometer reset button in and turn on the ignition to run then release the odometer reset button. Background lighting should illuminate, the speedometer needle should sweep its full range of motion and the indicator lamps should illuminate. After that the readout on the odometer should indicate any trouble codes. If there are any trouble codes I have a list of them to direct you to the problem. If you want to clear the codes, press the speedometer reset switch for more than 5 seconds when the DTC is displayed.
Apr 07, 2009 | 2008 Harley Davidson FLHX Street Glide
Air Conditioner for Benz 1998 E320
Check system for codes;
Displaying & Reading Trouble Codes (DTC Memory)
Air Conditioning (A/C)
Models 208 as of MY 1998
Diagnostic trouble Code Memory [15]
Note:
  • The A/C pushbutton control module (N22) has DTC memory and data output. The diagnostic trouble codes and data are displayed via the temperature display window. The stored DTC's will remain in memory even with the vehicle battery disconnected.
  • The DTC memory differentiates between current and intermittent faults.
  • Numerous DTC's can also be read with the Hand-Held Tester (HHT).
Preparations for DTC Readout
  1. Review 11, 12, 13, 14, 15, 21, 22, 31, 31, 41
  2. Ignition: ON
  3. Temperature selector: left: "HI"; right: "LO"
  4. Ignition: OFF
  5. Ignition: ON
  6. Within 20 seconds press REST and EC simultaneously for more than 5 seconds.
  7. The LED in Recirculated Air flashes and the display shows "d1A".
  8. Press AUTO repeatedly until all DTC's are displayed. Record each DTC as it is displayed.
  9. Each fault (short circuit, open circuit) is assigned a DTC. Thus in the left display: "E1" appears, and the right display indicates the DTC. The current faults (refer to table) are displayed first, next, the intermittant failures (e.g. 45 °5) are displayed in the display window next to the FAN symbol. By pressing the right AUTO the next DTC is displayed.
  10. To erase: Can only be performed after all faults have been readout. Press left AUTO and right AUTO buttons simultaneously for more than 2 seconds and the display shows: left: "d" and right: "FF". To cancel erase: By pressing the left AUTO button, the current faults will appear again.
  11. Select a base temperature setting.
  12. Turn ignition OFF, to end test.
Note: Due to instrument cluster (IC) series interface, DTC's may be stored in IC memory, therefore readout and erase DTC's from IC memory.
133090425133090426
Aug 20, 2008 | 1998 Mercedes-Benz E-Class
Maytag MFF2557HE Bottom Freezer French Door Refrigerator Logo
60 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
