Question about Mach Speed Trio Stealth G2 9.7" 8 GB Wi-Fi Black Tablet Android 4.1 LCD Touchscreen, 1024x768
How do I add Bluetooth keyboard to trio tablet?
Tried using connect button
How do I connect irulu usb keyboard to my Visual Land Prestige Elite 7q tablet?
Make sure the tablet and keyboard are charged.
On the tablet, go to setting - it looks like a gear icon. Open settings and about the 3rd item down from the top of the drop down menu, you will see "Bluetooth." Make sure it is set to "ON"
Then go to the keyboard. It also has an "ON" button and press the botton. A tiny red light will blink slowly close to the button. There is a second "Connect" that must also be pushed - it is the "Connect" button and it will search for the Bluetooth signal from the tablet.
When it finds te tablet signal, you will see a message on the tablet screen [it must e turned on} instructing you to enter a 5 or 6 digit code on the keyboard. When you enter the code, a "Connected" signal will show on the screen.
Open a document and start typing!
I'm pretty sure this pertains to all tablets and keyboards.
Feb 12, 2016 | Tablets & eReaders
How to connect the keybord
On your tablet, make sure bluetooth is turned on. Then on the keyboard, turn on the bluetooth button. They should automatically pair, but if not, the tablet should detect the keyboard and then choose it.
Nov 07, 2015 | Tablets & eReaders
How do you get the rca RCT6378W2 tablet connected with a Bluetooth keyboard
If your tablet is Bluetooth-enabled, follow the set up instructions that came with the keyboard. Basically, you turn Bluetooth on on both the keyboard and the tablet. Start the process of pairing and connecting from the tablet. If you are asked to enter a password/passkey and it is not specified in the keyboard's manual enter '0000' or '1234' (without the quotes). Note that the password is required only for pairing, therefore it will happen only the first time. If your tablet is not Bluetooth-enabled, you cannot connect the keyboard to it.
Dec 21, 2014 | Tablets & eReaders
Connect wireless keyboard?
for bluetooth keyboard, usually long push power button (or setting button) to set the keyboard to pairing mode. then go to setting in your tablet, bluetooth then search new device, follow the instruction in the tablet for pairing until finish. done
Nov 22, 2014 | Tablets & eReaders
Where do i find an app to upload an external bluetooth keyboard to my trio stealth g2 tablet?
I have not seen this model listed with built in Bluetooth. You could add a USB bluetooth device and it should work. Usb keyboards and mice will work for sure.
Jun 09, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
What downloads for my computer are there to communicate with my trio stealth 8
"Communicate" is a vague term. When you connect a tablet to a computer it is usually recognized as a folder containing files (data). You can move files between the two devices. You can also connect via Bluetooth if your laptop and tablet BOTH have Bluetooth.
It is better to ask a question stating what it is you want to do rather than ask about concepts.
May 16, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Trio tablet screen stuck on trio logo
hi try doing it this way.all data will be lost...
Jul 07, 2017 | Tablets & eReaders
Activate bluetooth on stealth g2
Hi Ali.. as far as i know and im pretty sure of this.. trio stealth aka Mach etc.. only has wi fi..no blue tooth. Here is a link with more info
for u.
http://youtu.be/mK-AGDPtoNU
Good luck
Chad man
Oct 26, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Mach Speed Trio Stealth G2 9.7" 8 GB Wi-Fi Black Tablet Android 4.1 LCD Touchscreen, 1024x768 Logo
Top Mach Speed Tablets & eReaders Experts
BrikimG
Level 1 Expert
David Payne
David Payne
Robert Graf
Are you a Mach Speed Tablet and eReader Expert? Answer questions, earn points and help others
