Question about Bose Audio Players & Recorders
BOse lifestyle 12 Series 2 Bass Module Front panel ratteling how to fix?
BASS Module Front Plastic is Ratteling how to Fix it?
  • 47 Answers
Happy to help . well its a classic case of over tightnening the screws on the body of the speaker and then it cracks and the ratteling sounds starts coming or they r loose . just glue it down with super glue or tight them as required.
Posted on Nov 30, 2014
SOURCE: Digital Sound from Sky HD and DVD player to Lifestyle 8 series 2.
I HAD BREAK DVD NOT OPEN AND I STILL LOOK FOR NAME JVC-DVD DIGITAL THEATER SYSYEM TH-C7
Posted on Apr 07, 2009
  • 9 Answers
SOURCE: Bose Lifestyle 20 system. sound from only two speaker
A lifestyle 20 system is stereo only. Two channels. Left and right.
Posted on Jun 07, 2009
  • 3 Answers
SOURCE: bose lifestyle 12 no sound is there a fuse in the
Yes there is a 1.6 amp fuse just behind the AC socket.
Had the same problem, changed fuse ok now !
Posted on Nov 09, 2009
  • 4 Answers
SOURCE: The display stopped working on my Bose Lifestyle
i did have encounter the same problem!!!! what i did was have the whole capacitor replace ! I didn't bother to have them check beside its will cost you less than $10 this is how a capacitor will look like http://www.allproducts.com/manufacture97/qiyu/product1.jpg . check the ( + )positive ( - )nagative by marking either one on the PCB board before you proceed! very important! good luck
Posted on Dec 06, 2009
dunnbiker
  • 8546 Answers
SOURCE: front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Posted on Dec 28, 2009
How to add secon subwoofer to my lifestyle bose system?
You cannot add a second sub woofer to your Bose system unless you are very well versed in electronics and would like to tamper with the internal electronics of the Bose module. Unlike other systems the 6 channel amplifier ( 5 + 1sub ) and its crossover electronics + power supply unit is built into the Bose bass module. The circuit uses very small surface mounted devices with double sided pcb ). And even a professional technician might refuse this work in fear that he may damage the whole unit itself !!!!.
Mar 19, 2011 | Bose Lifestyle 12 System
No power to my speakers. How do you open the amp? BOSE acoustimass 5 Thanks
A powered AM5 bass unit? Undo the 1/2 screws, tease out the toothed quadrant by 90deg then tap the plastic panel down/away from the toothed quad. not easy the clips are usually very tight.
Oct 10, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Jun 04, 2009 | Bose Lifestyle 20 System
Bose lifestyle 28 will not come on?
The Bose Lifestyle System has two power connection. One is the adaptor for the media center/DVD and the other one is the bass module/ subwoofer. Both has physical indicators showing that power is present. If your pwoer adaptor is ok, then the media center display should show "BOSE LIFESTYLE SYSTEMS" on startup. The bass module power module should be OK when you see a green blinking or steady linght underneath.
If only the media center/DVD has no display then there is something wrong with your pwer adaptor and should be sent for repair.
Hope I have helped you
Apr 05, 2009 | Bose Lifestyle 18 System
Bass/Treble balance on Bose Lifestyle 5
You need to go into your menu and set the "MOVIE EQ" to your liking. That is where your bass/treble balance is on a Lifestyle system.
Mar 01, 2009 | Bose Lifestyle SA-2 2-Channel Amplifier
Front bose speakers and bass module stopped puttimg put sound
Dec 23, 2008 | Bose Lifestyle 12 System
Changing out my monitor speakers to bose cube speakers
You probably can do it as long as the speakers there now are 8 ohm speakers and you must use the bose bass module with the cubes because the crossover is built into the bass module for the cubes to work. If you just wire up the cubes you will mess the cubes up and they want sound right at all. The cubes are no good without their bass module in other words. Hope this helps.
Nov 09, 2008 | Bose Lifestyle 12 System
No output from Bose Lifestyle 12 system
Sounds like you have a problem in the circuits, which of course would take an experience technician to find and repair. But a 1994 electronic item has pretty much reached the end of its expected life cycle (sadly, compared to older equipment which is still working great). Basically, it sounds like the power amp circuit is shutting down a few seconds after startup. Might check to make sure no speakers or cables have shorts, which could activate a protection shutdown circuit. If any of the cubes don't hiss when you turn it on, that would be the first place to look for a problem.
Jul 01, 2008 | Bose Acoustimass 15 System
Bose lifestyle no sound
Hi, best practice when troubleshooting a no-sound Bose Lifesytle system is to first begin with the internal sources (i.e. the AM/FM). Bose Lifestyle system when connected properly (media center and bass box via the data cable) should show a steady green light underneath the bass module. Begin by simply playing AM/FM tuner and try to increase the volume till 45 (normally the sound becomes audible at this level). If the system still has no sound, then try to check if the bass module is steady green. When you see a blinking green LED (slow green) then do kindly check the DIP siwtch (red latch switch with white mini switches) just beside the Light and data connection. All of the switches should be in "ON" position (basically toggled upwards with the arrow marking indication). Before changing DIP switch settings do ensure that the bass module is not connected to the electrical power. after ensuring that all DIP switch are in the "ON" position, connect the data cable firs and then power up the bass module. Then you should see the bass module blink green twice and once you turn on the nedia center, the green blinking should turn steady green. That should sort out your problem.
Also do note tha this procedure applies only to Series II Lifesytle System and does not include the Series IV (with the smaller bass module).
If all still fails, there is an internal problem with the bass module which would require servicing.
Hope this helps!
Jan 27, 2008 | Bose Lifestyle 18 System
78 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
