Question about Refrigerators
The digital panel is not working. After pressing the two button (power freeze and power cool) at the same time. The refrigerator is not kicking on and running. What could be wrong with the panel?
Refrigerator lights are on and the panel has a single dash flashing.
    Sergeant:
  • 304 Answers
You have an error code in your refrigerator the dash wis telling you what's wrong and where the problem is
Posted on Dec 02, 2014
  • 3 Answers
SOURCE: lights flashing all cooling appears normal ice maker flap continually opens and shuts no water buttons not operational
As I mentioned before my Maytag was doing the same thing, I called Maytag expecting a big fight but they were really nice about it.
This is a recall problem and even if your warrenty is up Maytag will repair it at NO COST to you.
They shiped me the HV board and sent a repairman who had it fixed in about 10 minutes with a newley designed HV board.
Posted on Mar 30, 2008
22yooper
  • 828 Answers
SOURCE: LG refrigerator not working
Check and clean the condenser. Unplugging the system allows it to cool off. when you plug it back in it will cool until the heat rebuilds if not rejected through the condenser. Make sure the condenser fan comes on when the compressor runs. A faulty fan motor will cause the same type of problem.
Posted on May 19, 2008
SOURCE: Kenmore refrigerator not cooling or freezing
my refrigerator suddenly stop cooling all the fans run normal. It makes a click Noyce.
Posted on Jun 22, 2008
  • 864 Answers
SOURCE: Whirlpool runs, but freezer not freezing and frig not freezing
If the compressor is running but the unit is not cooling you may have lost the refrigerant.  See if the condenser coils at the back or bottom are hot.  If they are only warm then the refrigerant is low and can be recharged.  Service tech should check for leak in coolant system.
Posted on May 30, 2009
BMT60
  • 126 Answers
SOURCE: refrigerator side not cooling, but feezer is still freezing
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE LOWER AREA OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. THE HEATER IS THE MOST COMMON. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING THE DEFROST HEATER. 95 PERCENT CHANCE. JUST REPLACE THE HEATER SOON AFTER DEFROSTING SO YOU DONOT HAVE TO DO IT AGAIN.
Posted on Apr 25, 2010
Samsung rs263tdbp and demo/cool off mode will not turn off
from the manuals Page 1. Activating/Deactivating Cooling Off Mode When the refrigerator is in Cooling Off Mode (aka Demo Mode) the display will read "OF OF, O FF, or OFF OFF." Cooling Off Mode prevents the unit from cooling. It is used by retailers to display units without wasting energy.
Note: Models without digital displays will display scrolling lines when the unit is in Cooling Off Mode.
Tip: If your display panel has buttons that have to be pushed in to perform any functions, replace the word "Touch" with "Push" or "Press" in the following steps.
  1. Touch and hold the top two buttons on the left side of the display panel.
  2. Important: You must touch the 2 buttons at the exact same time. Not doing so will result in an unsuccessful attempt to activate/deactivate Cooling Off Mode.
    [img src="http://www.samsung.com/us/system/support/content/2011/04/25/h5408/Demo_Mode_250_Pix_1.jpg" align="bottom" border="0" height="127" width="250">
    Notes:
    • As long as the display panel is located on the exterior of the left door of your refrigerator you will use the top two buttons on the left side of the display panel to activate/deactivate Cooling Off Mode.
    • If your display panel is located inside of the unit along the door frame you will need to locate the words "Cooling Off (Hold 3 sec)" printed on the panel. The Power Freeze and Freezer buttons are the two buttons used for Cooling Off mode on these models.
    • Wi-Fi Touchscreen displays on RF4289* and RSG309* are exceptions to this article. Cooling Off Mode is activated/deactivated through the settings menu.
Apr 01, 2014 | Samsung RS263TDBP Side by Side...
RT50 control panel not responding
It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
Mar 31, 2014 | Samsung Refrigerators
Of error code on display screen. how do I fix it?
If your control panel displays "OF" instead of the temperature, your refrigerator is in "Cooling Off" mode. In Cooling Off mode, the refrigerator appears to be running normally, but the compressor is off so the unit does not cool. Cooling Off mode is used by retailers to save electricity when the refrigerator is on the showroom floor.
Note: Cooling Off mode is also called Demo mode or Exhibition mode.
Depending on your refrigerator, to remove your refrigerator from Cooling Off mode:
  • Either press and hold the Energy Saver and Power Freeze buttons for 3 seconds
  • Or press and hold the Power Freeze and Freezer buttons for 3 seconds.
The temperature display re-appears after the unit is out of Cooling Off mode.
Aug 21, 2011 | Samsung RS267TD
Hi. We had a power outage and now the control panel will not reset. Any tips?
Hi and welcome to FixYa, I am Kelly,
Press power cool and power freeze at the same time for 8 seconds.. The control panel should reset. If pressing pwr cool and pwr freeze shuts off the compressor it can be 10 mins of more before it restarts. If it does not reset... respond here and I will dig through the service manual and get back to you.
Kelly
Apr 28, 2011 | Samsung RF267AB (25.5 cu. ft.)...
Power went out briefly. Refrigerator control
Press the Power Freeze and the Power Cool button at the same time. Hold for 10 seconds and the digital panel reset.
Aug 14, 2009 | Samsung Refrigerators
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Model rs2533sw panel not reseting after being unplugged
I had the same problem (panel would not start up - just flashed one dash after a power outage).
The solution above: pressing the top two buttons for 12 seconds (Power Freeze and Power Cool buttons) reset the panel and everything is working fine now.
Thank You!
Dec 24, 2008 | Samsung RM255LASH Side by Side...
Samsung refrigerator RS2534WW ICE MAKER DOES NOT FUNCTION PROPERL
Hello here is how to fix the problem, first you have to remove the ice bin then then press the freeze temp and power cool buttons for about 12 seconds until the display panel switches to the option mode and you hear a beep.
A number under "Frige temp" corresponds to the option number. Press the fridge temp. button to increase the number and the power cool button to increase the number and the power cool button to decrease the number. set the option number to 3
now you have to select the input data to control the water supply time. Press the freeze temp button to increase the value. Press the power freeze bottom to decrease the value. Choose the right amount of water supplied to the ice tray which should be to where the water level is even with the rib on the inside of the tray.
input data = 00, 5 secs/01, 4 secs/02, 3 secs/ 03, 6 secs/ 04,7 secs/05,8secs
Let em know if this helps or not.
Nov 27, 2008 | Samsung RS2534 Side by Side Refrigerator
Samsung rs2578sh
Yes, you have a faulty defrost heater or thermal fuse, the fault will re-occure within a few weeks. Regards Advisor
Aug 22, 2007 | Samsung RS2578BB Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
