Sansui super 21 after replace 4460 out put voltage drop
Where to find the owners manual for the Sansui QRX 7500A?
Sansui QRX-7500 Manual - Four Channel Receiver - HiFi ...
www.hifiengine.com/manual_library/sansui/qrx-7500.shtml
May 21, 2014 - sansui qrx-7500 four channel receiver. Sansui QRX-7500 ... service manual English - honestsoul99. Related Catalogues. HiFi Buyers Guide.
Sansui ' Hifi Manuals Free: Service Manuals, Owners ...
Dec 19, 2015 | Audio Players & Recorders
My tv its showing black fant pictures with sound. When you put it on it spacks in side. What can be the problem of all this? Sansui sv2916.
open the tv and then put it on then look carefully where the spack is, if it is from the line transformer then replace it with thesame number if u can but if u can not take it to a qualifield techni bcuse the voltage is very high
Jun 03, 2015 | Sansui Televison & Video
My sansui tv have a problem.transister 4460 getting short after replace output voltage drop stand by realese
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 30, 2014 | Televison & Video
Fault finding retrace line on screen ?
Check the video output supply voltage. If it is less than normal, retrace lines will be visible. If the screen voltage is greater than normal, the retrace lines will be visible. You should check all these. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Check these above said voltages at the CRT base card.
Apr 14, 2014 | Sansui Televison & Video
TV MODEL :SANSUI HARD ROCK 21'' PROBLEM : TIME TO TIME ONE HORIZONTAL LINE COMING WITH BLACK SCREEN
Hi The problem of your teevision is what we called the vertical line problem.The problem is in the vertical section of the board.There are many of cause of that problem.First is either loose connection,the circuit at the vertical section have cold solder so its need to resolder using soldering iron.Second,it maybe no vertical supply,its better to check the 12 volts dc supply of vertical ic output.if thers no supply in the ic,there a open resistor near the flyback.try to replace.Third if theres no loose connection and have a voltage supply the problem is either leaked capacitor or deffective vertical ic output. Commonly in that problem is the loose connection,try to resolder the verical section.
Jul 12, 2011 | Sansui DTV2760 27" TV
Where can i buy a drive belt for my 4460 breadmaker in new zealand
Here is a link for a company which sells spare parts for Russell Hobbs products:
http://www.lvmartin.co.nz/public/info/FAQ.aspx?FAQCATID=21
Hope this helps!
Apr 18, 2011 | Russell Hobbs Microwave Ovens
How to enter into Service Mode in Sansui Hard Rock 21 eye model
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 14, 2009 | Sansui DTV2760 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
