Question about Cub Cadet Riding Lawn Garden Zero Turn Tractor
How do I unstick the parking break on my Cub Cadet 50 in. Zero turn? It is stuck in the off position and will not even start unless the parking break is on. Thanks
Pulling on it
  • Cub Cadet Master
  • 1,169 Answers
Check your brake cables. One if not both are frozen in their housing,
Posted on Nov 30, 2014
  • 146 Answers
SOURCE: I have a Cub Cadet RZT 50 mower. The left drive
First, check the level of the hydraulic fluid (usually the dipstick is right inside the fill cap, and you just raise the seat to access it). If it's low, fill 'er up with the right fluid.
If that's OK, test if the lack of 'pull' affects the left wheel in both forward and reverse -- try going up a hill forward, and backing up it in reverse. If it affects both directions, maybe you will be lucky -- the problem could be that the bypass for the left hydraulic motor has opened somehow. (The bypass is used to let you push the mower by hand in case of an engine failure, etc.) So look for a fat-headed bolt sticking out of the left hydraulic motor. Check that it's tight -- rotate it just like you would tighten a bolt, clockwise. If it wasn't tight, that may be the problem; just tighten it and try the mower.
If this doesn't resolve it, you probably have a problem in the hydraulic valves, hoses, or motor, and a trip to the dealer is needed. Probably won't be cheap, sorry my friend. Good luck, and please rate if this was helpful, thanks!
Posted on Jun 04, 2010
  • 146 Answers
SOURCE: Cub Cadet 2166 series. Mower will not engage.
Unfortunately, the circuit is a little complicated - it involves the "PTO switch" (the switch you pull on to engage the mower), a "reverse switch" that senses if you've put the mower in reverse, and a relay operated by the reverse switch. The reverse switch is there to disengage the blades if you try to reverse while mowing. A failure in any of those items, or the connectors and wiring between them, will prevent the blades from engaging. Unless you want to "shotgun it" and replace parts one-by-one on a guess (which many repairmen to do save time, but at your expense) you need to use an ohmmeter or test light to trace and isolate where the failure is.
Posted on Jul 10, 2010
suzukiracing
  • 200 Answers
SOURCE: cub cadet zero trn rzt 50 mower deck will not come on
try checking the cable running to it
Posted on Jul 20, 2010
  • 6468 Answers
SOURCE: My cub cadet zero turn mower wont turn right or left. It will go straight or reverse but wont turn. I just changed the drive belt, but that's all I've done to it.
take a good look at the linkage
Posted on Apr 08, 2012
  • 6468 Answers
SOURCE: What would cause a Cub Cadet Zero Turn Mower to not steer to the left?
check the linkage for the pumps
Posted on Apr 19, 2012
M60 cub cadet zero turn. What causes it to shut off?
There is also a safety switch for each of control arms, they both have to be in the neutral position. You may have to adjust the arms.
Are you checking the resistance at the switches?
Jul 09, 2015 | Cub Cadet Garden
How do I find year model on Cub Cadet rzt 50
The Manufacturers Serial and model numbers should be on a plate under the seat. Go to the Cub Cadet Website navigate to Manuals, enter the Serial/Model numbers and the year of manufacture should pop up.
Sep 21, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
Cub cadet zero battery is dead after sitting a few days.
This is an electrical issue, you have a short in the harness, can very well be the keyswitch...even though you turned it to the off position, it's giving the unit the impression that it's still in the on position.
BriMaxSmallEngineRepairCo
Gibbstown,NJ
Jun 02, 2014 | Garden
Cub cadet enforcer 54 lunges
Possible transmission fluid issue. Drain, Fill, Drain, Fill.
Call dealer or check online to find which fluid it takes. It's probably 20w-50.
Look at sticker underside of tranny to fetch its model number then look it up online to see parts shematic for transmission.
Parts shematic shows the amount and type of oil.
You will have to work the axels and do the transmission purge located in your manuals first few pages then top it off its last few 8 or 10 ounces.. (unboxing)
Possible carb dirty.
Jun 13, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
I have a cub cadet rzt 50 with a kawasaki 22hp engine it cranks and runs fine for a while and then sounds like its running out of gas, I shut the pto off and it eventually quits running, I pull the choke...
PDF]OPERATORLS MANUAL - Cub Cadet
https://www.cubcadet.com/.../CubCadetCatalogAssetStore/.../own...Cub CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline ...
cubcadet.custhelp.com/.../basic-troubleshooting---zero-turn-riding-mowe...
Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
May 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have a cub cadet zforce 48 zero turn. It wont start unless I jump across the solinoid. I've changed it and still does the same. Whats the problem?
Make sure the control arms are all the way out, the brake is locked in the on position. There are safety switches on each control arm and one on the brake lever, also there is a safety switch on the seat...if either is faulty the mower will not key start.
Apr 21, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Riding Lawn Garden Zero Turn Tractor Logo
259 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
