My sansui tv have a problem.transister 4460 getting short after replace output voltage drop stand by realese
    Top Expert:
  • Televison & ... Master
  • 74,106 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Nov 30, 2014
5 Suggested Answers
MikeNJ1964
  • 398 Answers
SOURCE: No Power on Sony TV
Be sure to use an ORIGINAL Sony transistor and be sure to resolder the pins of the small horizontal driver transformer and all parts connected to and around it, and your set should be fine.
Posted on Aug 18, 2007
  • 556 Answers
SOURCE: tv dead
please check flyback transformer for short
good luck
Posted on Nov 02, 2007
jerryg50
  • 1667 Answers
SOURCE: Sony 2167 No power on
I have not worked on your particular model. But, I have serviced many TV sets over the years. My answer will ge generic.
Check all the capacitors in the horizontal output stage and power supply areas for high ESR. All the caps that are out of spec must be changed.
The high voltage multiplier & flyback can also cause the fault you are having.
You have to consider that the DC voltages are not the only important spec that has to be met. There are also many power drive signals that work with reactive devices. If there is any defect in the critical areas there will be failures.
Jerry G.
Posted on Nov 26, 2008
Mike1963
  • 8 Answers
SOURCE: no power
Try to change the output horizontal transistor , usally located near the flyback transformer.
Posted on Mar 05, 2009
A sansui tv switches on and off by itself. What could the problem?
Desolder out the horizontal output transistor, and now power on the set. If the set now powers ON, replace the horizontal output transistor. It is faulty. [Collector to emitter or collector to base leak]
Jun 26, 2015 | Sansui Televison & Video
Sansui tv no picture but has sound
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Jul 31, 2014 | Sansui Televison & Video
Why my sansui tv chassis nr sv218n stays on standdby
Short circuit at the main board. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Do a search by type in the brand name of your device at its search box.
Jun 13, 2014 | Sansui Televison & Video
Horizontal transister heat up and shortens
Try to replace new harizontal output transistor.Before replacing the transistor,check the regulator and the flyback if shorted or not.If the flyback is shorted the harizontal output transistor will be damage again if you trying to turn on again.Thanks..
Aug 26, 2011 | JVC TM-2703SU 27" TV
I purchased an old Realistic TRC-431 CB. When I turned it on it worked fine, the mic was keyed then the lights went dim and stayed dim. Now the lights remain dim. I checked the two output transistors...
The problem is with your power supply. There should be a big round transister on the power supply this is the power transister. It will be mounted to the power supply case. Replace this transister and try to operaste your radio again. Make sure that the power supply you use is at leat 7 amps or the radio will not operate properly and you will possibly blow the transister again.
Jul 16, 2011 | Radio Communications
29 inch TV model no.CS 722 AN. H. output tr blows off and stand by blinks
Sir 1- Use heavy ampier transister for hor output
2-measure h output transister base and emitter resestance value it is nearabout 15to33 ohms,you can use.
3-check lot by replacement
Oct 03, 2010 | Samsung Televison & Video
No power we change transister 2sc 4460 but stil no power
Mar 05, 2009 | Televison & Video
Help for TCL Brand of tv
I WANT THE SERVICE MODE CODE FOR MODEL NO: DP21E101 TCL TV 21"
Jun 15, 2008 | LG 30FS1D TV
check video processor output diagram and signal amplitude if u can find video processor raplace it and try it must work
Aug 13, 2007 | Sharp 32C-240 32" TV
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
