Question about Sony Televison & Video
My Sony Cd playyer stopped working can it be fixed???
I had't used it for awhile and when I tried to use it it wouldn't work. Can it be fixed???
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 924 Answers
Yes, whatever the issue, it can be fixed, as long as parts are available. Unfortunately, it is not cost effective to fix it. Sorry.
Posted on Nov 30, 2014
After years of working fine my Sony 5-disc CD recorder has suddenly decided that every disc is a "data disc." The music blanks that have always worked in the past are now being read as "data disc" when I...
Mine was doing the same thing. I even posted the same question. Then after reading through other questions, I found that the discs I was using were CD-R that would only record on my PC. They are Data Discs. There is a different kind of CD-R and it is for music only and they are marked CD-R MUSIC. The little compact disc symbol on the package should read recordable underneath. I had not used mine in awhile and forgot to look for that on the package. Now mine works, Hope yours does too.
Oct 08, 2010 | Sony RCD-W500C 5-Disc CD Recorder
Sony Vaio Notebook PCG-661L - CD/DVD Drive Won't Open
lolz, this time you call a technician, i tell you it will be fix to them...
Jun 17, 2009 | Sony VAIO Notebook
Sony Xplod Amp
well you might want to try using 30 amp atc fuses instead of 10 amp fuses on your amp, because you are getting an overcurrent from your alternator then from your battery. I have the same amp and you will find that your subbs will hit better too. also check on your ground wire from your amp as this also will cause the RED light to come on. :)
Mar 24, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
My cd player on the Sony HCD-G101 rotates the discs but ...
i had the same problem after i moved and everything ran but when i put in a cd the disc would spin for awhile then change to the next disc and just kept spinning and moving from one disc to the other none stop. so i opened mine up turns out during the move there is a small black plastic piece that sits on top of the laser in the middle it shifted during the move making it block the view of the disc. you will have to carefully remove the plastic piece from the top of the laser with out touching the laser lens and that fixed mine good as new. my problem is i need the remote code movers lost my remote and can't find the code to use the replacement i bought. Hope it helps if this is the same problem i had should work. i tried to move the black piece back into place but it just did not go back right to just removed it all together. they did not use anything to really hold it into place to avoid slipping.
Dec 15, 2008 | Sony MHC-RV777D 220 Volt Hi-Fi Music...
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
Recovery
Since the "recovery" partition is no longer there, your only option is to request a CD recovery disk from Sony. This will allow you to rebuild the PC to the factory starting point. You will need to provide proof of ownership +/or license.
Dan
Jun 10, 2008 | Sony PCV-RS420 (027242635845) PC Desktop
Aiwa CSD TD310- manufactured 2001 - looks like this(above)1)Problem getting cd to work; 2)need help with "sleep" button:how to set
Well, for the CSD-ED27 the sleep works like this:
1. press STOP/MEMORY and then also
2. press PREPEAT/FM MODE/OSC
3. your display will show 10
4. use the tuner - & + to good from OFF-90 mins
As to you CD player not playing:
it is sounds like the spinner might be not spin completely flat to the optical reader. This happen with my portable CD player, however at this time I do not have a fix for you. Good luck though.
Mar 20, 2008 | Aiwa CSD-ED27 Boombox
Sony crx320e cannot read cd but can read dvd.
try re-installing the Drive.
Cleaning the Laser head.
Using a different read-write program.
Mike @ Compurepair.
Oct 20, 2007 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Televison & Video Logo
100 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
