Question about Sharp Televison & Video
My video recorder was working perfectly now all tapes stop when I hit play, some do rewind and fast forward, any fixes please? Tried user manual cleaned heads best I can still no joy.
Was going through old tapes recorded on short play , long play, xl play and now none will work. Even tried the 10 second reset from user manual, still no joy. Is the machine goosed?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
Goosed? A quaint way of saying it's trash? Well, it can be fixed, but unless it's vital to your video, it may not be worth fixing. You probably have a lack of torque, which would not unusual for an old video recorder.If you need more assistance, or would like to inquire about a repair, please visit my website, audioserviceclinic.com. you may contact me there. Thank you.
Posted on Nov 30, 2014
SOURCE: tapes keep getting stuck
we have 4 of the decks. they will often fail to unload panasonic and maxell tapes, i think its due to the design of the reel bases. sony tapes always work fine, they are flat where the others have a groove.
Posted on Nov 27, 2006
  • 883 Answers
SOURCE: My VCR is playing too fast
try recording on a blank tape and setting the tape speed to SP (standard play). you should also see options for (LP-long play) and SLP (super long play). I think your machine is stuck on SLP option. if no-go, look for a manual on the web.
Posted on May 27, 2007
  • 129 Answers
SOURCE: Video will not rewind to beginning of tape.
the clutch gear needs to be replaced . you can order the part partstore.com go by brand and model easy to replace around 30.00 dls .
Posted on Jun 20, 2007
SOURCE: VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Posted on Oct 08, 2008
SOURCE: When tape is inserted the unit starts beeping and
The beeping indicates that an error has occurred and that the unit has been disabled because operation could damage the unit further. To determine what the problem is- Turn unit off. While holding the STOP button, turn back on and continue to hold the button for 8 sec, then let go. Press display and you will get an error code on the monitor, for instance, C:21:00 error code (the most common code I get) indicates a condensation problem. If this is the code you get then leave the unit open in a dry place for 24 hours or so, and it should dry out the dew sensor and clear the code. The unit will hold up to 6 error codes in the order that they occur, rotate the wheel to cycle through the codes. Codes are displayed as - C:XX:XX. If you get a code other than C:21:00, then google the code,(Sony C:XX:XX) and the description will probably come up. Good luck.
Posted on Oct 19, 2009
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
The camera is not showing a picture on the camcorder screen or tv when trying to play in play mode. It ate a tape when I tried to play back a video. I took out the tape, fixed the tape and then tried a...
This is most likely caused by a damaged or misaligned video drum and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 22, 2011 | Canon ZR600 Mini DV Digital Camcorder
Loads tape then stops - won't play rewind fast
Way to go. Usually if you use anisotropic Alcohol with a few Q-tips works well I've found.
Try cleaning the other tap path items like the capstan that the pinch roller get's pushed up to also with this Alcohol. The cleaner the better the tape goes through. Much better picture.
Blessings,
A/V Media Guy
Nov 19, 2009 | Sony EVC100 Hi8 VCR
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
Tapes will not play
Video head is dirty / clogged. Use good quality Mini DV Head Cleaning cassette.
Oct 01, 2008 | Sony DCR-HC32E DV Digital Camcorder
Feb 28, 2008 | Televison & Video
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
Incompatible Tape
try a cleaning tape first - best not to rewind the cleaning tape because it will put back the crud previously removed ? into your heads and guides ( last tape to play is prime suspect ) ; - - digital heads wear faster than analog so a new set of heads is next possibility but if the cleaning tape works . . . retire your library soon as possible .
Jul 26, 2007 | Panasonic PV-DV400 Mini DV Digital...
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
Help it's going to fast
Your camera has a capstan servo problem which is more than likely being caused by the capstan motor itself.Nothing you can do youself,would suggest bring to service but reccomend getting estimate before repairing.
May 23, 2007 | Panasonic PV-GS31 Mini DV Digital...
Televison & Video Logo
79 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
