Question about Garden
While using ryobi 100 bar pressure washer it started smoking
  • 47 Answers
I take it this is an electric powered machine.
If using these pressure washers with an extension lead for the electric supply it can cause a multitude of problems. voltage drops to motor etc, which increases current and overheats the motor.
I am not familiar with this model I work with industrial pressure washers. If the type of motor is a universal motor with brushes, similar to a vacuum cleaner, then I think the motor will be toast.
if it is a squirrel cage induction motor with capacitor, then the capacitor usually fails first. this is a cylinder with either wires coming out of it or push on spade connectors for the wires.
I have meters to test these but you can usually see that the cylinder is bulging , blown the cap off or pushed out a trail of grey stuff.
hope this helps.
Posted on Dec 08, 2014
How to hook hose to ryobi pressure washer
same as an air compressor connection,pull back on outside and insert in middle
Jul 25, 2015 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
We have a Ryobi pressure washer. Used one time. I have no water pressure.
Could be a stock Pressure Washer Unloader Valve. You can find videos of how to remove and to clean it. It is not that difficult to do. Good luck.
Sep 10, 2014 | Ryobi Gas Pressure Washer: 3100 psi 2.5...
Our Ryobi 3100 2.5 gpm worked one time and has no pressure. I am livid. How do you fix it? what good is a pressure washer without pressure?
These have very small openings. Try cleaning end with fine wire supplied with your unit. Any slight corrosion will cause your current problem.
Sep 10, 2014 | Garden
Ryobi rcs4040ca chainsaw
Its unusual for a saw to start actually smoking, are you sure the chainbrake has not come on and you have been running it, this will make it smoke and damage the clutch, sprocket and brake.Remove the side cover and check for signs of heat,
Aug 31, 2013 | Garden
I have a ryobi rcs4040ca chainsaw that started smoking during use and now won't start. It had plenty of bar oil and the right mix of petrol. I did work it quite hard. I took the spark plug out and cleaned...
Two things come to mind. The ignition coil burnt up or the condensor failed. You did not say where the smoke was comming from. If it was from the exhaust it could have a failed reed valve in the head.
How much oil in ryobi rpw 2400 power washer engine?
they take from a half a quart to a full quart
Aug 10, 2012 | Garden
My Ryobi 700R "EZ" weedeater smokes excessively.
Check the fuel/oil mix ratio you are using. Some Ryobis use a 32:1 mix and some use a 40:1 mix. There isn't much difference there. To be on the safe side, if you machine is possibly running or tuned a little "lean" I would start off with about 4 oz/gallon oil to gas mix. Use synthetic 2-stroke oil also. Your machine will perform much better.
Nov 27, 2010 | Ryobi Garden
I got the pressure washer started - lots of smoke etc after not having used 3 years. I then poured in wrong oil to top it off - my brother's chain saw bar oil. DARN. After 3-4 minutes it started rattling...
nope! you have blown the seals and most likely the cylinder is full of water. You will need to take it to the repairer to have it cleaned checked and new seals fitted. $200
Jul 31, 2009 | Karcher 1750 psi Electric Pressure Washer
Garden Logo
161 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
