Question about Frigidaire Refrigerators
The freezer temperature will not stay programed, keeps fluctuating
Frigidaire model fphb2899lf8
  • Official Brand Answer
  • 2,267 Answers
Hello Charlotte Goodman, thank you for your post!
From my understanding your Frigidaire refrigerator, FPHB2899LF8, will not stay programmed. It sounds like a possible problem with your control panel. I would recommend performing a reset on your refrigerator and you can do that by disconnecting power from it for ten minutes. If you continue to experience an issue with your temperatures I would suggest consulting with a professional technician for proper replacement of the control panel. I hope this is helpful. -Matt
Posted on Dec 04, 2014
  • 173 Answers
SOURCE: Freezer temperature will not get cold enough
Clean cooling coils. Check refrigerant level.
Posted on Jul 08, 2009
SOURCE: Freezer temperature won't get cold enough.
This might sound stupid, but I had a similar problem. A few years ago when I was renting I noticed that suddenly my freezer stopped working well. I eventually had to call my landlord to check it out. It turned out that there was a knob to adjust the freezer temp and I had turned it to the warmest setting somehow. If it isn't that, I would return the freezer.
Hope that works for you
Posted on Jan 18, 2009
  • 256 Answers
SOURCE: Freezer temperature fluctuating way up.
Your problem could stem from an issue with the defrost timer, the compressor or its attachments (e.g.: relay, capacitor, etc.), or the freezer/evaporator fan motor. Contact an appliance service company.
Posted on Feb 11, 2010
kdgrayson
  • 195 Answers
SOURCE: freezer temperature keeps fluctuating
Defrost heater may be sticking in defrost mode a bit.
Posted on Apr 24, 2010
  • 44 Answers
SOURCE: Inside the freezer has bunch
Your evaporator fan motor might be bad. This causes the icicles. Listen for the fan motor turning next time, you may want to hold down door switch.
Rich
Western Appliance Repair Boise id
Posted on Dec 02, 2010
How to raise the glasstop Frigidaire range
Hello, John -
The information here may prove instructive:
https://homesteady.com/how-7979236-replace-glass-stove-top-frigidaire.html
You can also add the model number of your Frigidaire range by choosing "Comment" and providing the model number so that I or another Fixya.com answerer can provide you with the user manual for your model of glass top range.
Best wishes.
Mar 29, 2018 | Frigidaire Kitchen Ranges
FPBM189KFC MANUAL
Most Frigidaire manuals are available through their support site: http://www.frigidaire.com/Owner-Center/Product-Support-FAQs/ . Enter the model number in the search box and press enter.
The direct link to the owner's manual in English for the FPCM189KFC is http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316902454en.pdf . An installation manual and wiring diagram are also available from Frigidaire.
I hope this helps.
Aug 09, 2017 | Frigidaire Microwave Ovens
Fridge keeps bleeping
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Mar 19, 2016 | Refrigerators
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jan 20, 2016 | GE Refrigerators
I am trying to locate an owners manual for a Frigidaire Dishwasher model # FGHD2433KW1
Below is the link, you can download it
http://www.manualslib.com/products/Frigidaire-Fghd2433kw1-2885301.html
Dec 05, 2015 | Frigidaire Dishwashers
Why dose it keep beeping ?
Jun 20, 2015 | Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Apr 10, 2015 | Refrigerators
Keeps beeping without stopping
Mar 09, 2015 | Smeg Refrigerators
What is the normal fluctuation range of a top freezer in a freeze-refrig combo? That is if I set the temperature of the freezer a 0 F, at what temperature should the freezer come on to keep the air i
Hello Richard;
My name is Peter. I am a retired field service refrigeration technician.
The normal range for a freezer is -2 to +2 Deg. F.
The normal range for the fresh food section is 35 to 40 Deg. F.
If you set your freezer at 0 Deg. F. it will stay at 0 Deg. F.
When the freezer temperature drops below 0, your compressor will kick in to bring the freezer back to 0 Deg. F.
Dec 15, 2014 | Frigidaire Refrigerators
Refrigerators Logo
259 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
