Question about Emerson Televison & Video
My sound bar does not want to work with my new 50 inch tv. Emerson model # LF501EM5F..any suggestions?
Hooked red and white audio cables from sound bar to audio inputs on tv.
    Top Expert:
  • Emerson Master
  • 75,581 Answers
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on Nov 30, 2014
jerrysland
SOURCE: No sound from my AVOL tv
U have to use the Connector labeled RF-1 U have to screw the connector on. I had the same problem
Posted on Aug 28, 2012
SOURCE: Connecting Wii to Emerson 37 in LCD tv
Finally found the correct point of entry to tv and correct channel on my own.
Posted on Dec 26, 2008
welcomejee
  • 10594 Answers
SOURCE: I cannot get my PC sound to play through my Samsung LE32457A HDTV
I hope 3.5mm to twin phono would have plugged in headphone jack of PC to get sound for TV, right?
Reduce PC volume level up to zero and increase it very little bit to get sound in TV.
TV is getting excessive sound level from headphone jack and causing mute circuit to activate to avoid any internal damage.
Posted on Sep 26, 2009
Testimonial: "Good advice, but didn't work. :("
SOURCE: hooked up cable box, wii box and dvd player to new
Connect the Wii and the DVD player to different ports on the TV to and any other device to the port in which the Wii and the DVD player were connected to check if the issue is with the port.
If other devices also display in black and white after connecting them to the port to which the Wii and the DVD player were originally connected then the ports require servicing.
Posted on Dec 01, 2009
walesarumi
  • 6993 Answers
SOURCE: Im trying to connect my
You will be needing a RCA Digital TV box converter or Digital RCA TV box converter. This converter will be the link between the Sound bar system and TV.
You should find this converter in any electronics accessories store within you vicinity or check walmart store close to you or order it online from walmart (But I don't recommend ordering online because of it's problem sometimes).
Check the back of the converter, it should have an input for Digital and RCA output and vise-a-vise.
Take a look at this Walmart link; http://www.walmart.com/ip/RCA-Digital-TV-Converter-Box-DTA800/8343230
I hope you understand the above.
Good luck.
Posted on Feb 26, 2011
I own an emerson lf501em5f 50 inch tv believe the main board to be bad
according to what you tell me . already tried a new power supply . , then the problem is is the main board.
Nov 18, 2015 | Emerson Televison & Video
Emerson LF501EM5F LED TV makes beeping sound and does not switch on
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 04, 2015 | Emerson Televison & Video
I have a proscan with no sound so I brought a
You hooked up the sound bar to the cable box red & white sockets, right. Now you have the soundbar hooked up to the TV red and white sockets. Did you notice any difference with the labeling on the two sets of sockets? The cable box sockets were labeled "Audio Out", but the TV sockets are labeled "Audio In"
AV signals are directional. Any socket labeled "Out" will give a signal from it for connecting to another device e.g. the connection from the cable box to the soundbar.
Any socket labeled "In" is designed to accept a signal from something else, but it won't give a signal out. So you can't connect the TV's Audio In socket to the soundbar's Audio In socket because both expect a signal from something else and neither supply a signal out.
Check the back of the Proscan TV. Is there a socket labeled Audio Out? If so, use that.
Sep 03, 2014 | Televison & Video
Hook up sound bar to zenith plasma tv
If the sound bar has the red and white cable then yes you can use those. Make sure in your settings for the TV you have it set for an external audio source. Since you don't want to use the built in speakers. Probably best to get a tuner if using multiple speakers and a sub.
Dec 29, 2012 | Zenith Z60PV220 60-inch Plasma TV
I am attempting to attach a Samsung Sound Bar to my 42 inch LCD 1080P Polaroid Television. I can not seem to get sound from the Television connected to the Sound Bar. Thoughts?
Connect the audio out RCA jacks (white and red) on the TV to the white and red RCA input jacks on the sound bar for analog stereo sound or connect the black digital audio output jack (typically optical) on the TV rear panel to the sound bar's optical digital audio input jack for surround sound. Use an optical cable. There may be some user settings on the TV for audio.
Aug 12, 2010 | Polaroid FLM-4201 42 in. LCD Television
Televison & Video Logo
506 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
