Question about RCA Televison & Video
The picture from the dvd is cut off at the top, bottom, and sides. only analog channels are found so zoom buttons on remote can't help. what to do? dvd player works fine on a different tv. this is a R
I've tried to search for digital channels through the search method but none found. only analog and the zoom buttons don;t work for them.
    Top Expert:
  • RCA Master
  • 74,136 Answers
Check with an other known disc; have recording in aspect ration 4:3. If that disc show full screen picture, the recording to the present one; you're viewing has wide screen recording. Electro help
Posted on Nov 30, 2014
Testimonial: "it's an RCA TruFlat model 20F424T. don't know what you mean by check with another disc."
  • The Knight
    The Knight Nov 30, 2014
    You might have an other DVD disc, which has full screen recording of any; cenema or other video. Play that disc ; and see whether the TV displays it in full screen. That's what i meant.
  • 35 Answers
SOURCE: RCA CONSOLE TV will not work with DVD Player
what is the model of your tv and the method in which you are trying to connect the dvd (ie rca cable, component, composite, hdmi) and do you hear audio
Posted on Dec 21, 2007
quare3
  • 48 Answers
SOURCE: RCA TRUFLAT VOLUME,CHANNELS MOVE ON THERE OWN
i would honestly suggest if you still have the receipt return it back. dont forget your rating thanks.
This is a very common problem for RCA TV. I have one as well. or go to www.tv.rca.com/ there are free manual there
Posted on Jan 25, 2008
freetek
  • 5568 Answers
SOURCE: 3 DIGIT CODE FOR SANYO TV MODEL DS19730
If you are working from the provided user guide, it may not be the most current list.
Try here:
http://www.thompsontv.com/rcarc.html
Thompson owns the RCA name now so this is the primary website.
BTW, 'universal' is an often abused word!
Posted on Jul 12, 2008
  • 899 Answers
SOURCE: Why does my RCA TV cycle through channels on its own?
this is the same type of problem happening with other rca models and I know it is the EPROM CHIP but why this is failing is either because of design flaw , dirty enviroment that they were made in , to much voltage or current to the chip or too much of a draw from the chip causing it to fail . Or even a random frequency from the IR sensor or its circut I'm still investigating and testing.
leave the tv unplugged for at least 3 weeks durring this time resolder any solder that don't look good , I did this and it lasted for about 6 months(always plugged in to the wall) before it started doing it again. model # 27v412t
Posted on Oct 06, 2008
t5mustang
  • 3 Answers
SOURCE: RCA HD27F754T picture color and screen size.
check your hook ups, sounds like you have a component hook up conected to a composite jack.
Posted on Mar 09, 2009
When viewing HD programs the picture size is larger than the screen. In other words the picture is cut off top/bottom/sides. Can this be corrected? Ratio does not help.
Are you using AT&T U-verse? You should check the zoom by clicking on the zoom button at the bottom right of your remote. If you are using another service provider for your television service, you should also check the zoom.
Mar 01, 2011 | LG Televison & Video
Part of the picture is being cut off, how do i
Just called Sony about this same problem...taking your CABLE BOX remote, push the # key on the bottom right of the remote (it also says HD Zoom on mine). You can cycle through 4 or 5 zoom options...make sure you are on an HD channel to see the changes. :)
Nov 27, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Heads cut off on the screen
Ocean's Eleven. Best remake movie, I think.
I believe your TV is in "ZOOM" mode for the screen. This will make a 4x3 picture come up closer to fill in the 16x9 screen, but this cuts off the top and the bottom.
Keep pressing the WIDE button on your remote until the picture looks best.
If you have HD channels, the screen mode should be on NORMAL. HD channels will have the 16x9 screen format.
The non-HD channels will have 4x3 screen format. When the screen mode is on NORMAL, you will have the cut off picture on the sides because the 4x3 format will not fill in a 16x9 screen.
May 30, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
Picture format to large
There should be a format button on your remote to change between widescreen & fullscreen as well as the zooms. May say format or aspect. If not on remote look through your menus. Make sure which ever u select u do not choose a zoom. This will cut of top & bottom of picture
Apr 06, 2009 | Televison & Video
Olevia 232-s13 tv - screen is cut off and cannot see top and bott
The TV is set on zoom. Just go to the remote control and look for the button (not sure what is is on olivea usually zoom, P. size, wide, stretch or something similar though). just press the button until you cycle through to normal (on an analog signal it will have black bars on both sides).
Mar 24, 2009 | Televison & Video
Panasonic PT-53WX42F-Stuck in Zoom mode
on the bottom left side of your dish remote, there should be a button that says format, that should help you
Jan 07, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Digital LIfestyles 32
On your remote control you should see a zoom or picture size button. Try changing this back to 16:9. I expect that your screen got zoomed either on purpose or by accident by someone. Some people zoom in the picture to eliminate the aspect ratio areas at the top and bottom and/or sides.
This should be your problem, just un-zoom the picture
Sep 09, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
IMAGE IS ZOOMED ON SCREEN
use the format button, might be called screen size. You are looking at a format that the screen cannot show completely, I can cut the top and bottom off or make it widescreen and lose the edges on my TV
Feb 24, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
High def picture is cut off on the sides
I have a Toshiba 50HP15 PLasma flat screen TV. Its been working tone for 2 years now. All of a sudden without warningm the right 1/3 of tghe picture is missing and is black, where as the other 2/3rd of the picture is great picture and in HD. When I press DISPLAY on the remote control is says FULL 720p. When I press the Picture Size button on the remote the message NOT AVAILABLE come on. Anyone with suggestions. Thanks
scotto
Dec 27, 2007 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Picture too large
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
Some Motorola Cable receivers need to be set up in the menu to go to a wide screen or zoom mode when an analog signal is detected. There may be a format button on the remote.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Oct 14, 2007 | LG 32LX1 32 in. HD-Ready LCD Television
Televison & Video Logo
61 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
