Question about Food Processors
The blade for the food processor is stuck to the centre post stem. How do I get the blade off the stem? (it is the large blade for the large bowl) Please help!
No food was allowed to dry on it. I could not get it off the stem from the moment I finished using it (I always disassemble everything as soon as I am done). But it is stuck fast, no amount of force will get it to budge and I am reluctant to use pliers or anything for fear of damaging it. I tried soaking it in hot water, but that did not work. The food processor is only a few months old and does not get a lot of use.
    Top Expert:
  • 75,599 Answers
Contact any service tech: Gopakumar Gopalan Google
Posted on Nov 30, 2014
snakehead
  • 1074 Answers
SOURCE: Food processor blade stuck on motor shaft
my friend if you had not removed that blade for a while it will certainly stuck due to the moisture that forms on the shaft of the blade holder causing it to have corosion you will have to carry that item to be removed by a qualified tech by you doing it your self could cause damage,which could cost you more.good luck
Posted on Jun 19, 2007
SOURCE: food processor
I phoned the 800 number at Cuisinart (800-243-8540) and the person who answered the phone explained to me what to do: Fill the bowl with the hottest tap water I have (but not boiling) above the entire blade (including the part that fits over the shaft). He said to pulse a few times, then try to pull it off, but not to expect it to work right away. He said to do this until it comes off and that it could take 1/2 hour. I did what he said, and the blade came off after the first pulses. But also, the water was pouring out all over the counter--leaking between the bowl and the base (possibly because my old work bowl is also cracked, but I'm not sure).
I was told that the problem would happen again, and that I needed replace the blade and the shaft (which is cracked, as he guessed), both of which are available from Cuisinart.
Posted on Oct 08, 2008
  • 24 Answers
SOURCE: GE Food processor knife blade, bowl and cover .
plz con-022-23095757 / 23051554
Posted on Feb 03, 2009
Cuisinexpert
  • 61 Answers
SOURCE: Cuisinart DLC-7--blade stuck--cannot remove from bowl.
First off, is it a BLADE that's stuck, or a DISC?
If it's a disc, and the disc is blocking your access to the center post, put a ziploc baggie full of ice on top of the disc (right in the middle) and let it sit for about half an hour. That should shrink the plastic enough to pop it out.
If it's a blade, you can try the ice trick, or you can try Pam (or another food grade cooking spray) to loosen it up, and then just try to take the workbowl off like you usually would (aka, DO NOT grab the blade, or you'll risk cutting yourself--you can just pull up on the bowl, and the blade should pop off.
If you need further help, you can always contact Cuisinart--their phone number (according to their website, www.cuisinart.com ) is 1 800 726 0190
Good luck! :)
Posted on Aug 31, 2009
SOURCE: my braun 3210 food processor will not work with
I had a similar problem. Part of the lid had a small piece of plastic chipped away. It was the part of the lid that rotates and locks into the machine base. If the lid is missing a small piece of plastic on where it connects to the base, the machine will not switch on. You can compare the lid for the food processor to the mixing lid and see if the piece that juts into the base is broken at all. If it is order a new lid. There are several online places that still carry them; or try a local parts store.
Posted on Jan 28, 2010
Why wont my chopper blade come off in the unlocked position?
Help! My Cuisinart is Stuck! - Chowhound
www.chowhound.com/post/cuisinart-stuck-353459
Dec 21, 2006 - Read the Help! My Cuisinart is Stuck! discussion from the Chowhound food community. ... The lid seems stuck and won't come off. I've tried pressing down,... Make sure all the buttons are in the neutral position. Reply ... In case of clarification- Turn the lid back on before unlocking, then twist off. Reply.
How to remove a stuck Kitchenaid Food Processor Blade (blade in ...
https://answers.yahoo.com/question/index?qid...
Aug 25, 2009 - Now the blade in the smaller bowl (4 cup) does not come off the bowl.... UNless i take out the 4 cup bowl blade, it doesnt allow me to remove the bowl ... I've used the screwdriver method for years in my shop with nearly 100% ...
Jan 12, 2016 | Food Processors
Blade of cusinart dlc 7 superpro food processor will not spin when food is in the bowl- works when no food is in it. Is it is the stem? How do I replace it?
It'll probably cost more to fix than replace. If you have a collection of blades, maybe find one in working order on a shopping site and meld the two together. Happy hunting! Happy New Year!!!!
Jan 01, 2015 | Food Processors
NEED REPLACEMENT BOWL AND METAL BLADE
place one foot on it and pull it out or you can try to wiggle it out
I’m happy to help further over the phone at https://www.6ya.com/expert/taisean_6df1de1d23f88296
Jan 22, 2014 | Wolfgang Puck BFPR0015 Food Processor
Hi there, my dough blade won't come out from my fp2500mc wide-mouth food processor. Is there's anything that I can do. I've tried everything but it won't come out
i have had this same problem and unfortunately it seems that the disc stem gets so hot that it melts the top of the bowl to the blade. I finally got it out but the bowl was ruined as was the dough blade.
Mar 17, 2011 | Black & Decker Food Processors
Black & Decker Food Processor F1-CFP-10 need the BLADE
I have the Black & Decker Shortcut food processor Model CFP10 and it has a broken bowl. I would prefer to replace the bowl but haven't found a source. So I would be willing to sell the good parts: Food Pusher, Food Chute/Cover; Food Fingers/ Reversible Disc, Disc Stem, Knife Blade. Make me an offer and e mail me at:
hersh@powwwer.net. I'll accept Pay Pal or certified checks.
May 16, 2009 | Black & Decker FP1400 Quick N Easy Plus...
My hamilton beach food processor model 702r has a broken Blade. Is there a place to find the spare parts around Orange county in Southern California? The Blade itself is good but we overloaded the...
Goodmans, ebay and amazon by post
hamilton beach food processor blade 702 ' eBay
https://www.ebay.ca/.../i.html?_...0...hamilton+beach+food+processor+blade+702...
62 items - Hamilton Beach Shredder Slicer Disc Blades for Vtg Model 702-4 Food ... Hamilton Beach Food Processor Model 702R Parts Your Choice Blade Stem ...
hamilton beach food processor 702 blade ' eBay
m.ebay.ca/.../i.html?_...hamilton%20beach%20food%20processor%20702%20blade
48 items - Hamilton Beach Food Processor Scovill Model 702 Replacement Dough Blade. C $18.63. Hamilton Beach Scoville Food Processor 702-4 Replacement ...
Hamilton Beach Food Processor Parts ' eBay
www.ebay.com/bhp/hamilton-beach-food-processor-parts HAMILTON BEACH DUAL SPEED FOOD PROCESSOR MODEL 702-7 WORK ... Hamilton Beach Food Processor Shredder BLADE 702R Replacement Part.
Hamilton Beach Food Processor Blades ' eBay
https://www.ebay.com > ... > Food Processors > Hamilton Beach Food Processor Blades Results 1 - 48 of 348 - Hamilton Beach Replacement Parts Model 702-7 Dual-speed Food Processor Sears 400 7) Rubber Feet Set of 4 W/ Suction Cup GripSee ...
Hamilton Beach Blade Food Processors with Slicer ' eBay
https://www.ebay.com > ... > Hamilton Beach Blade Food Processors with Slicer Results 1 - 48 of 64 - Hamilton Beach Replacement Parts Model 702-7 Dual-speed Food Processor Sears 400 7) Rubber Feet Set of 4 W/ Suction Cup GripSee ...
Hamilton Beach Food Processor Model 702R Parts Your Choice ...
www.ebay.com > ... > Small Kitchen Appliances > Food Processors Hamilton Beach Food Processor Model 702R Parts Your Choice Blade Stem Lid Bowl ' Home & Garden, Kitchen, Dining & Bar, Small Kitchen Appliances ' eBay!
Hamilton Beach 702R food processor for sale on Ebay! - YouTube
? 1:08
https://www.youtube.com/watch?v=qS7jwpIPmqk
Nov 24, 2016 - Uploaded by Dave halverson
This item is for sale on Ebay. Check it out under the seller name Niterider!
Food Processor Parts - Goodman's
www.goodmans.net > Small Appliances > Food Processor Parts Replacement 3214-701-0001 Food Processor Belt fits Hamilton Beach 702R, etc. Our Price: $7.99 .... Kitchenaid Kfp79bl Multipurpose Blade for 9-cup Models.
Amazon.com: Hamilton Beach food processor blade post.: Food ...
https://amazon.com/hamilton-beach-processor-blade-post/dp/b000f38ire Hamilton Beach 68001800 blade post. Fits Hamilton Beach food processor models P70550, IG70700, 702, 702-7, 702R, 702RW, 702W-220, 702WS, 70300, ... hamilton beach food processor model 702r blade Google Search
Sep 17, 2017 | Hamilton Beach 702R Food Processor
How to attach grating/shredding blades to GE Food Centre FP22
When you remove the regular chopper blade, it should fit on top of the stem. The chopper blade must be removed to use the slicer / shredder attachments.
Jan 05, 2009 | GE Food Processor
I am unable to remove the disc stem
There is no mechanism to lock the stem onto the base of the KFP750. It's just held on by gravity, so you're not missing anything simple!
It's possible that the soap dust got in there and glued in on. Take a blow dryer or very hot rag (use tongs!) to the stem to see if you can soften the soap, then pull up the stem.
Dec 26, 2008 | KitchenAid KFP750 Food Processor
Food processor
Oct 07, 2008 | Cuisinart DLC-5 Food Processor
Food Processors Logo
325 people viewed this question
Top Food Processors Experts
Ross Keen
Are you a Food Processor Expert? Answer questions, earn points and help others
