Question about Crafts & Hobbies
Hook up transformer - Crafts & Hobbies
  • non sequiter
    non sequiter Dec 12, 2014
    Hi jeff maulick, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    what scale train, type/model of transformer, type of track.
How to change 110v to 220v on sonance cinema 260 subwoofer amplifier
I suggest contacting the manufacturer as there may be an internal "reconnect" that would allow 220v operation. Good luck!
May 21, 2014 | Audio Players & Recorders
How to wire the humidistat to the transformer
your transformer should have multiple wires on it. 2 of them are for 120 volt side hook up usually black is your hot 120 v wire and white is the common or neutral wire. on the other side of the transformer you have 2 more wires these are your low 24v side colors can range from red,green, blue, yellow ect. the wires for 24v dont matter about polarity or which one you hook up. one is 24v and the other is common.
Feb 08, 2013 | Aprilaire Humidifiers
Transforer has three places to hook up wires instead of two
This will be for different output voltages.
Use multimeter set to ohms to test which wires have continuity.
If you connect Hot and neutral to wrong wires, it will burn up the transformer.
Copy following lind for illustration showing Intermatic 4-wire low voltage pool transformer:
http://waterheatertimer.org/images/PX-600-wiring-diagram-900.jpg
Jun 09, 2012 | Intermatic Malibu 300W Power Pack...
OVERLOAD LIGHT ON TRANSFORMER IS ON
FIND OUT HOW MANY AMPS MAX YOUR TRANSFORMER IS RATED FOR, FIND A AMP GAUGE 'SAY ON EBAY, THATS ABOUT 5 AMPS MORE THAN YOUR TRANSFORMER IS RATED FOR, HOOK IT IN LINE AND YOU WILL BE BETTER ABLE TO MONITOR LOADS THAT ARE PUT ON YOUR TRANSFORMER. AND IT WILL SAVE YOUR TRANSFORMER FROM COOKING . TRY TO FIND LED BULBS FOR YOUR STREET LAMPS AND OTHER LIGHTS, THIS WILL DROP THE LOAD ON THE TRANSFORMER.. HOPE THAT HELPS YOU .. JAY FLORIDA
Feb 02, 2012 | Athearn Ho Rtr Union Pacific Train Set
Overload light on athearn transformer
Feb 02, 2012 | Athearn HO RTR GP60M BNSF 157
On my therostat it show and talks about the R wire and the Rc wire. What is the differet?
If you would have a two transformer system..... The power wire from the furnace transformer would hook up on R and the power wire from the Air Conditioner transformer would hook up to Rc....
BUT most systems now only have one transformer...... So if you are using this thermostat you will need to put a jumper wire from R to Rc. So the Air Conditioner will work. Furnace is the source of the transformer. R/Rc,W,Y, C, on the Thermostat will Hook up to R,W, Y,C on the furnace and Two wire from the Air Conditioner would hook up on Y and C on the furnace.....Good Luck.
Apr 02, 2011 | Heating & Cooling
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
Why two 24 Vac on aprilaire 700's control unit?
Okay, I looked up the installation manual online to see exactly what you are working with.
Yes the R anc C need to be hooked to the transformer supplied with the unit. The primary 120v side needs to be hooked into the power coming into the furnace. this can easily be done were the L and N get hooked into your furnace or circuit board on the furnace. This will provide the contiuous power to the unit. Preferably you will hook this after the door switch of the furnace so that you will kill the power toit if you take the blower door off.
The ODT terminals are for the outdoor sensor if you want to hook that up it will vary the humidiy in your home according to the outdoor temperature then.
Now the W/G and Cf terminals. If you have 24v coming from the HUM terminals of your furnace you DO NOT need a second transformer. You must check your furnace manual or check the voltage to them with the furnace blower energized. The HUM terminals will only have power to them when the blower should be running.
If the HUM terminals are 120v then you need to get another transformer and hook up the primary side to the HUM terminals so it is powered only when the the blower is running. Hook the secondary side to the W/G and Cf terminals.
So bottom line is that you need to figure out what voltage your furnace is giving to the HUM terminals and then go from there. Some times the EAC terminals or the ACC terminals will be 24v on the furnace board. Either of them could be used also, as they are only energized when the blower is running also.
Heatman101
Jan 25, 2010 | Aprilaire 700 Humidifier
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
Different color leads in transformers
No, it doesn't matter. If you want to make sure hook up the leads to the 120 side and then turn on power and check the leads coming off the low voltage side to make sure you getting the 24v before hooking it into the board.
Jul 31, 2009 | Heating & Cooling
Crafts & Hobbies Logo
48 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
