Question about Welding Tools
Why do i need those wores unit was adapted to another motor and it has its own battery and starter the battery was not hooked to the welder
The welder and welding assy was mounted to a deutz engine by way of a coupler and no wireing between them
  • 4 Answers
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Posted on Apr 08, 2009
  • 4 Answers
SOURCE: Welder not welding
SOunds like your ground is not connected solidly either inside the machine or at the ground clamp. Check to make sure the ground wire at the clamp is not broken then make sure the ground wire is connected solidly inside the machine.
Posted on May 25, 2009
KingDWS
  • 1606 Answers
SOURCE: I have a Lincoln wire feed SP-200 welder and my
Try replacing the circuit breaker. They can/do get weak and tend to trip before they actually reach the rated limit.
Posted on Aug 31, 2009
KrisJohn1
  • 7 Answers
SOURCE: Lincoln Weld Pak 100 arc welder troubleshooting
There can be a switch that makes the wire electrically "dead" so it can be fed through the liner. Also suitcase style welders have a sensor wire with a clamp that must be connected for the arc to be able to be struck.
Posted on Nov 24, 2009
oneStan
  • 431 Answers
SOURCE: I have a hobart handler 120/90amp wire feed welder
I have welded countless hours with Linde & Lincoln & even a few Hobarts & the only time that I ever had the same problem was when the ground connection either to the object I was welding, or the welding cable ground wasn't good & clean & tight. Same on stick welders also. I did develop the habit of grinding not only where I was preparing to weld, but where I was placing my ground clamp & that always provided a better "frying bacon" sound as I went along the business of pushing a bead. In a welder, the only other thing than that is involved is the step-up transformer and your wire. Hope this helps.
Posted on Feb 02, 2010
I have a miller bobcat 225, it keeps blowing 30 amp inline fuse on a blue wire that runs to the hot side of the starter, any idea?
millerwelds.com will let you down load a manual for this unit, it can help you with this problem, also you can call miller and tech support should help
Jan 22, 2015 | Bobcat Miller 225 Welder Generator 907209...
Do I need a battery hooked up to a miller 225dplus for it to generate or weld
No , as long as the engine is running it should be producing power .
Dec 07, 2014 | Miller Welding Tools
What wire do I need in my 125 flux core welder to
Aluminum wire, get it from a welding supply store as they can sell it to you and provide what you need for the type of welder and the type of welding you wish to do.
Oct 04, 2014 | Welding Tools
Why does wire weld to tip when trigger is pulled when welding aluminium
The tip of the welder may need cleaned out, your feed speed might need slowed down, check the polarity is it straight or reverse?
Sep 20, 2014 | Welding Tools
Sorry for the lack of info The starter is new, disconnected the battery replaced the starter ad when the battery was connected the starter starts turning with out the ignition on but not engaging. The...
Well, if your starter starts to turn when you hook the battery cable up, then you have hooked the cable to the wrong post on the starter. You have two large posts and one small post on the starter solenoid, the battery cable goes on the large post that has nothing else hooked to it. The other large post should have a large braided cable going into the starter motor housing. If the starter still will not turn the engine over when it is wired correctly then you will need to look closer at the flywheel ring gear.
Sep 06, 2014 | 2007 Toyota Tundra
Welder won't speed up to weld ?
What doesnt speed up to weld? the feeder? is the wire burning back? are you getting any wire? this is gmaw / wire right? sounds like it may be running slow
Jul 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
I hook cable up to battery starter motor spins
Ok so reason that is happening is because you either have the battery terminals on backwards or you have the starter hooked up improperly .i would make sure you have the red battery cable on the positive terminal+and out the black battery terminal on negative - .if that doesn't fix your problem them you need switch wires on starter
Jan 13, 2014 | Vehicle Parts & Accessories
We have a culligan mark 1000 we wish to buy a starter motor
Since the parts for all Cullligan units are proprietary you will need to contact your local dealer for parts.
RJH2O
Dec 28, 2012 | Culligan 34" Whole House Water Filter...
How is the wire feed cable assy held in place at the wire feed assy on the lincoln weld pack 100?
There should be a thumbscrew or set screw in the portion of the wire feed assembly where it goes through inside of the cabinet that snugs up to the straight portion of the cable assembly.
Dec 25, 2011 | Lincoln Welding Tools
Welding Tools Logo
41 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
