Question about Panasonic Radio Communications
Can;t use 2 headphones simultaneously on my Panasonic TV because it recognizes the same model number for both and will connect only one at a time, and disconnecting the other. Both pair fine.
Re-pairing
    New Friend:
  • 61 Answers
Use a splitter cable to allow both to use a single output. This is a description from Amazon : Hosa YMM232 6-Inch Y Adapter, 1/8-Inch Stereo Male-Dual 1/8-Inch Female
Posted on Nov 30, 2014
SOURCE: Need help with Case Logic bluetooth ear piece model BTH-10
The generic PIN for that bluetooth is : 1234
Good luck
Posted on Dec 12, 2008
SOURCE: Pairing NOkia BH-207 with Blackberry 8120
Power it off
Press the power on button for at least 10 seconds, until it keep the blue ligth on and then pair it with your BB
Posted on Feb 20, 2009
  • 38 Answers
SOURCE: Z9i Connecting problem.
Have you tried resetting the Blueant Z9i? You push the Volume Up, Volume Down and Blueant buttons all at the same time (with the device on). This will eliminate all paired phones, then re-pair with just your phone (hold down Blueant button for 6 seconds or so to enter pairing mode).
Posted on Mar 26, 2009
SOURCE: ST3 will not pair to any phone. Phones recognizes
I had similar problem with Motorola and Blackberry Perl. It seems that the device may have been used or demoed at the store, and had to be re-set to factory defaults. The procedure is simple.
  1. Make sure that the device is OFF
  2. Press and hold Volume UP and green ON buttom at the same time
  3. After reset, power the device OFF and wait for approximately 10 seconds
  4. Power the device ON, select a language, and follow voice prompts to complete pairing
Posted on Sep 29, 2009
SOURCE: What is the pairing code for these headphone
The pairing code is simply 0000. It is written in the instructions manual.
Posted on Oct 07, 2009
How to wire headphone to Panasonic TV
If there is not a headphone jack then I'm assuming you are trying to connect t to either the red or white cra style jack on the back. These are line level connections and will not work without some type of amplifier.
Jul 15, 2016 | Panasonic Televison & Video
Panasonic TH-37PX70BA
Yes there should be a headphone conenctor.
Apr 13, 2008 | Panasonic TH37PX60 37 in. Plasma...
Where do I find the model number
The words "red and blue lights", "paired", "connect" and "beeps" make me believe that your headphones are Bluetooth-enabled. However, I never heard of a TV that is Bluetooth-enabled. Therefore, I do not think that you will be able to pair, nor connect your headphones to your TV. If you want to listen to your TV wirelessly, you will have to use regular (not Bluetooth) wireless headphones, which consist of two pieces: the headphones and a transmitter that connects to the audio output(s) of your TV and transmits the sound from your TV to the headphones wirelessly.
Dec 06, 2014 | iHip Audio Players & Recorders
Connect headphones to tv
It sounds like you have wireless headphones so maybe its not tv maybe more like transmitter signal between headphones and reciever so hopefully you have a way to test siganal. However the default headphone jack on TV should work fine unless turned off in audio settings in TV. Hope some of this helps you.
Apr 15, 2014 | Panasonic Audio Players & Recorders
How do I use headphones with this model
The unit does not have a headphone output or a provision for headphones. An option will be connecting headphones or wireless headphones that have a digital optical input to the digital optical output of the TV. The TV speakers should be off in order for the output to work.
Sep 04, 2013 | Panasonic SC-HTB770
Whereis the headphone socket in panasonic viera th-42pz85u?
hi,
ur tv doesn't have a headphone connection. it only have an RCA audio out. if u wish to use head phone with ur tv, then bought a head phone amplifier and connect it to the audio output of ur tv.
ok
Dec 17, 2010 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
How to connect headphones to this tv.
The only way to accomplish this will require an external amplifier.
Connect the program out to the input of the external amp and use the headphones from there. Disconnect the speakers or turn them off in the audio menu.
Hope this helps,
Dan
Jul 11, 2010 | Panasonic TH-42PX60U Television
Unable to connect headphones to Tv.
You TV have no headphone port.
You can download the user guide for your reference from:
https://docs.sony.com/release/KDF55WF655.pdf
Apr 24, 2017 | Sennheiser RS130 Headset
Radio Communications Logo
52 people viewed this question
Top Panasonic Radio Communications Experts
Jason
Clive
Clive
Are you a Panasonic Radio Communication Expert? Answer questions, earn points and help others
