I put my next book 8.1 on reset and it stopped at 5 percent Its stuck at 5 percent
  • 11 Answers
Press and hold the power button for 5 seconds. It should restart
Posted on Nov 30, 2014
Pass word for next book Ares 10a demo mood seetting
Ares8 NextBook: How To Stop Demo Video ' Android Tablet Forum
www.androidtablets.net > News > Forums > General Discussion > Android Tablet Q&A
Sep 2, 2015 - 7 posts - ‎5 authors
I would like to find out how I can stop the incessant demo video from running on my tablet ? I cannot ... My Hisense tablet has a setting there, to stop the demo video. ... I have this tablet, very good cheap tablet, unchecked demo mode. ... ares 10 remove demo lock ... nextbook 8 ares demo mode password.
Disabling the start up demo on nextbook - YouTube
? 1:35
https://www.youtube.com/watch?v=B8iALxyoxKg
Apr 29, 2016 - Uploaded by Tim Bockin
How to disable the start up menu on the nextbook. ... Disabling the start up demo on nextbook. Tim Bockin ...
Password to turn off nextbook ares 8 demo mode - Android Forums at ...
https://forums.androidcentral.com/.../808331-password-turn-off-nextbook-ares-8-de... 6 days ago - 2 posts - ‎2 authors
Bought a Next book ares 8 tablet from amazon keeps popping up a demo video very 5 seconds you have to have a password to turn off demo mode Ive done a ... of other ares 8 asking for this, i know the 8a has the ability to enable demo mode ... Samsung S5 mini will no longer connect to Windows 10 PC.
how to uninstall demo video from nextbook 8 - Forums - CNET
https://www.cnet.com/.../how-to-uninstall-demo-video-from-nextbook-8-595765/ Jun 23, 2013 - 2 posts - ‎1 author
google nextbook demo video wont uninstall. This is driving me crazy~cant even listen to a whole song before it starts playing.any help would be ... Ares8 NextBook How To Stop Demo Video
Jul 03, 2017 | Tablets & eReaders
Next book 8" 16GB Windows 8.1. Can't get it to turn on and can't find the reset button.
Power off device, select volume up and then power, hold power for 5-7 seconds and let go without releasing volume up. When u get the android menu scroll down to wipe data navigating with the volume buttons and then to wipe data.
Jan 02, 2015 | Computers & Internet
Hi i just bot a bass boat with a 40 hp mercury motor that has ben sitting up for 8 or ten years. so what should i do before i try to start it again because it wont start at all
First know that they have a neutral safety switch which will stop the motor from spinning if the gear is engaged. so put it in neutral first.
Second- will it even go round? take the hood off and try to spin it by hand. Just to see if it is free. If it is stuck, check the lower unit oil for a lot of rust and water. That will stop it too.
Next - charge or change the battery,
Take the spark plugs out and see if there is any compression, or are there metal pieces found on the spark plug?
Then- or first- buy a book on your motor and a general book on boating.
Practice un-tying the boat and moving it off the trailer at home so you don't look like a novice at the ramp.
After 5 years the water pump should be serviced- use a garden hose and flush attachment or trash can full of water when running it at home- don't forget to put oil in the gas.
Dec 06, 2012 | Boating
P0068 map/maf throttle position correlation
Hi there:Here's the printout from the diagnostic tool. Year: 2006Manufacturer: ChryslerMake: DodgeModel: DurangoEngine Type: V8, 4.7LTransmission: AutomaticTrim Level: SLTMileage: 127555 KMs
=== Stored Error Code(s) ===Error Code: P2074Possible Causes: Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Higher LoadError Code: P0068Possible Causes: MAP / MAF - Throttle Position Correlation
Freeze Frame Information:1. DTC for which Freeze Frame was Stored - P2074.2. Fuel System 1 Status - Closed Loop.3. Fuel System 2 Status - Closed Loop.4. Calculated LOAD Value - 74.51 percent.5. Engine Coolant Temp - 199.40 degrees F.6. Short Term Fuel Trim - Bank 1 - -3.91 percent.7. Long Term Fuel Trim - Bank 1 - -3.13 percent.8. Short Term Fuel Trim - Bank 2 - 0.78 percent.9. Long Term Fuel Trim - Bank 2 - -4.69 percent.10. Intake Manifold Absolute Pressure - 22.21 Inhg.11. Engine RPM - 2,404.00 Rpm.12. Vehicle Speed Sensor - 73.94 Mph.13. Ignition Timing Advance #1 Cylinder - 25.50 degrees.14. Intake Air Temperature - 64.40 defrees F.15. Absolute Throttle Position - 31.37 percent.16. Time Since Engine Start - 1212 Sec.17. Commanded EGR - 7.06 percent.18. EGR Error - 0.00 percent.19. Commanded Evaporative Purge - 62.35 percent.20. Fuel Level Input - 93.73 percent.21. Barometric Pressure - 26.35 Inhg.22. Control Module Voltage - 14.35 V.23. Absolute Load Value - 0.00 percent.24. Commanded Equivalence Ratio - 0.00.25. Relative Throttle Position - 0.00 percent.26. Ambient Air Temperature - -40.00 degrees F.
Monitor Information:1. MIL - OFF.2. Misfire Monitor - Complete.3. Fuel System Monitor - Complete.4. CCM Monitor - Complete.5. Catalyst Monitor - Complete.6. Heated Catalyst Monitor - Not Supported.7. EVAP Monitor - Complete.8. Secondary Air System Monitor - Not Supported.9. O2 Sensor Monitor - Complete.10. O2 Sensor Heater Monitor - Complete.11. EGR Monitor - Complete.12. NMHC Monitor - Not Supported.13. Nox Adsorber Monitor - Not Supported.14. Boost Pressure System Monitor - Not Supported.15. Exhaust Gas Sensor Monitor - Not Supported.16. PM Filter Monitor - Not Supported.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa.
Mar 04, 2012 | 2005 Dodge Durango SLT
Chevy k1500 5.7 v8 wont start
Sounds like your timing is off when you placed the distributor back in or your spark plug wires are crossed. Start with the simple and check the spark plug wire firing order. 1-8-4-3-6-5-7-2 Cylinder numbers drivers side 1-3-5-7 radiator to firewall. Cylinder numbers passenger side 2-4-6-8 radiator to firewall. Distributor cap #1 is at 5 O'clock and rotates clock wise. Once that is establish to be good then make sure the cylinder 1 is at TDC with the distributor rotor at the #1 position. Good luck and hope it's a crossed firing order.
Jan 11, 2010 | 1994 Chevrolet K1500
Can not seem to set my altimeter on the ws4 timex i have tryed do this but it is giving me the wrong hight ? and know one in the shops can figger this out to????? what am i doing wrong iv tryed to folow...
Setting and Calibrating Your Altitude
1. Press MODE until CAL is shown.
2. Hold SET to begin the calibration.
3. Press START/SPLIT (+) until HOME ALTI is displayed (or choose WEATHER when calibrating weather).
4. Press MODE (NEXT) to begin the setting process.
5. Press START/SPLIT (+) or STOP/RESET (-) to increase or decrease setting values.
6. Set the value to your current elevation.
7. Press MODE (NEXT) to advance to the next setting option.
8. Press SET (DONE) to finish.
9. To complete calibration for the REFRENCE HOME altitude (or WEATHER setting), press and hold STOP/RESET until watch beeps.
Repeat this procedure for WEATHER, making sure to choose the proper weather condition on the WS4 that matches your current weather.
Once these two variables are calibrated, your WS4 will be ready to go, providing you with accurate altitude, pressure, and weather forecast information at your fingertips. Enjoy.
Jan 05, 2010 | Timex Watches
Percent to chemistry problems.
Hello
You should ask a question, we cannot guess what you want.
Percent means per 100 or 1/100. So 75% = 75/100 or 0.75. Here are some exemples of percent calculations with %
Percentage (5% of 250)
250 [x] 5 [2nd] % [=] gives 12.5
Ratio (Ratio of 250 to 5)
250 [/] 5 [2nd] [%] [=] gives 5000.
Add-On (5% add-on of 250)
250 [+] 5 [2nd] [%] [=] gives 262.5
Discount (5% discount of 250)
250 [-] 5 [2nd][%] [=] gives 237.5
Some percentages and decimal equivalents
1 = 100% ; 2 = 200%, 3=300%
0.5 = 50%
0.4 =40%
0.1 = 10%
1/3= 0.33333 = 33.33%
1/4 = 0.25 = 25%
2/3= 0.66666 = 66.66%
1/5 =0.2 = 20%
1/8 = 0.125 =12,5 %
Hope it helps.
Nov 03, 2009 | Texas Instruments TI-30XA Calculator
RESET OIL GAGE ON CHEVROLET VENTURE
Get in turn the key to acces. II Don't start the engine. And press the gas pedal down 3 time within 5 second. If that dosn't work turn the key off and try agen.
If that dosnt work try pressing it down 5 times withtin 10 seconds.
Dec 13, 2008 | 2007 Honda Ridgeline
Kenneth Cole KC3500 Chronograph
Pull your time adjustment knob out 2 clicks. hold down the chronograph time reset button and then press the start stop button and it will move to the next second. keep doing it until it is back at the 12 o'clock position.
Aug 20, 2008 | Kenneth Cole KC3500 Wrist Watch
37 people viewed this question
jasbo
jasbo
