Question about Maisto Rock-crawler Remote Control 4wd Truck
The front wheels will not move anymore on my Rock Crawler. What can I do to fix them?
Tightening the front axle of my Intruder 1400.
Your front wheel is not something that you want to take a chance on not being installed correctly. It sounds to me like you're missing a spacer. You should be able to tighten The axle up to 90 pounds and it should still move freely. If a spacer is missing or on the wrong side of the bike it will stop the wheel from spinning. Be safe !
Sep 26, 2017 | Suzuki VS 1400 Intruder Motorcycles
What is the best Electric RC Rock Crawlers?
Electric RC Rock Crawlers models tend to be quieter and have less power, but are generally beginner friendly. These are good all-around models you can run just about anywhere. Good for beginners, no smoke and not a lot of engine noise to annoy people around you.
Pros:
Ideal for Beginners
Some Models are Waterproof
All Around and Budget Friendly. These are best because of much more reasons for knowledge of that view on Best RC Rock Crawler.
Apr 29, 2017 | Televison & Video
What are the pros of Danchee Trail Hunter?
Danchee Trail Hunter rock crawler is an affordable and reliable unit, it's also one of the best rock crawler RC starter units that can get you into this hobby. It has many more pros because of which you should get it. To get more details you can refer Best RC crawler.
Apr 29, 2017 | The Optics
Front wheel s making humming noise
sounds like a wheel bearing assembly to me. i would have the clearance checked at a jeep dealer. if you can rock the wheel gently while moving forward and the sound fades and comes back, definitely a wheel bearing assembly.
Nov 14, 2013 | 2004 Jeep Grand Cherokee
Maisto Rock Crawler stopped working when drove thru puddle
Nothing Works? My guess is you might have fried the circuit board. if that is the case you can either junk the car or replace the board if you can find a replacement one. Also, you might want to check that the batteries are firmly in place and no obstructions to connection.
Nov 16, 2012 | Maisto Rock-crawler Remote Control 4wd...
Suspension and drive ability problems, as you accelerating the steering wheel wobbles form left to tight and you can feel the front pass side of ven move up and down, im not sure where to start looking
hi first thing to check are the front wheel nuts tight next jack up the front passenger side of car place hands at 3 0clock position and rock wheel if it feels like that there is excess movment it probably track rod end next check for ball joint by positioning hands at 12.30 position and rock wheel if movementits ball joint while you have car on jack have a look under front passenger side to see if there is any visible signs of what it could be make sure car is secure before doing any of the above aid of some one to either rock wheel or look under car at the bits described would make life easier if nothing obvious check other side hope this of some help
barrhead0
Feb 17, 2011 | Ford Aerostar Cars & Trucks
Maisto rock crawler. How do you remove the rear wheels? Front wheels have a phillips screw - easy; back ones look to be riveted on?
I am fairly certain the rear wheels can be removed with a 7 mm socket, but not sure if I remember correctly. They can be removed easily though. I am sure of it. it is just a matter of finding the correct socket size.
Jan 26, 2011 | Maisto Rock-crawler Remote Control 4wd...
Took the truck out of box, installed brand new batteries, drove for about 10 seconds then truck just stopped with slight burning smell.
well probelly the batterys where to much voltage i have arounf 70 masito rock crawler and 2 of mine had the same problem
Dec 27, 2010 | Maisto Rock-crawler Remote Control 4wd...
Front right side grinding sound
Possibly a wheel bearing. Get the wheel on that side off of the ground safely, and then grab the tire at the 12 and 6 o'clock positions and try to rock it back and forth.
If there is more than just a little movement, you need either ball joints or a wheel bearing.
Apr 18, 2010 | 2000 Dodge Durango
One side front wheel bearings need changed How do I know which?
It may be your alignment but if it is wheel bearings jack up the front of the vehicle and try to rock or shake the wheels by hand if there is play or it does move it is your wheel bearings
Mar 30, 2009 | 1998 Oldsmobile Intrigue
Maisto Rock-crawler Remote Control 4wd Truck Logo
119 people viewed this question
Top Maisto Toys Experts
ray gallant
17 SOUTH INDUSTRIES
17 SOUTH INDUSTRIES
Are you a Maisto Toy Expert? Answer questions, earn points and help others
