Question about Canon Office Equipment & Supplies
Canon icd320 paper keeps jamming before it goes into the imager. how to fix
I removed the paper jam by opening right cover and took out the toner cartridge. does not seem to be loading into the imager.not sure what is causing this to happen or how to fix
    Top Expert:
  • Canon Master
  • 75,581 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Nov 30, 2014
SOURCE: paper jam
We had this same problem. You need the back cardboard section of a legal pad. Take out the cartridge and slide the back of the cardboard slowly into the rollers, pushing it out the end where the paper comes out. This helps push the paper jam out. You may have to do this several times slowly to get the jammed paper out. But it worked for us!
Posted on May 21, 2008
SOURCE: Paper Jam
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
  • 2692 Answers
SOURCE: Paper Jam detected. None found.
Here is the Xerox support page for your printer. It even has a movie on removing paper jams.
http://www.office.xerox.com/perl-bin/product.pl?page=sprt&product=8400&country=United%20States&language=en#_manuals_and_documentation_
Posted on Jan 04, 2009
  • 15 Answers
SOURCE: DCP 7020 Brothers laser printer paper jam & back cover open fault
Try doing the following prior to messing around with the fuser itself:
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002000/000024/faq002024_006.html?reg=us&c=us_ot&lang=en&prod=mfc7820n_all&Cat=4
Posted on Jun 13, 2009
anantakumarj
  • 330 Answers
SOURCE: A paper is jammed in my printer and although it
in right side of the printer one green color lock is there pull that luck ......paper feed unit will come out there you can see the paper ......
if you want manul send me your mail id anantakumarjena0@gmil.com
Posted on Nov 05, 2009
ALL COPIES BLANK. NOT LOW ON TONER. ALREADY REMOVED AND SHOOK. D320
probably the problem is in laser shuter or toner cartridge pin in toner holder. But when you try to copy, when paper goes to the drum, open the right cover and produce paper jam, now look at drum for image, if on drum isnt image its laser problem...
If the laser shuter is faulty, these means that when you close the right door, the nose on door doesn't lift the laser shuter and so the laser unit cant write on drum.
If the toner crg. pin is faulty, when you insert toner in holder inside the copier, on right side of toner holder is small circle with pin that contacts the toner and gives voltage. You can apply some wd40 to that circle, that goes in and out when you open or close door.
But, probably is laser shuter... to check him you need to dismantle the copier.
Hope that helps!
Jun 23, 2011 | Canon imageCLASS D320 Digital Copier
I have a paper jam and it says to open the front cover, put the front cover just shows the ink cartridges and there is no visible paper jam. how do i find the jam and remove it? It's a canon image...
The paper jam could be in three places.
First:
Open the cover of fixing section, its above bypass, and check for jamed paper
Second:
Open the transfer cover, these cover has handle and it goes by pulling toward you, and check for jamed paper.
Third:
In hight of first paper cassette, on left sideway of copier, beaneath the bypass are small door, open it and check for paper jams. Be sure that you closed them properly because if they arent closed the check printer cover message will arrise.
Hope that helped
Jul 07, 2010 | Canon ImageRunner 1600 Copier
Error: open upper cover exit jam
Feed Jam or Exit Jam ecblank.gif ecblank.gif dot.gif ecblank.gif 1. Remove the tray and clear any misfed sheets as given above.
2. Open the top cover.
WARNING! The fuser area will be hot. This area is clearly marked. Do not touch it.
CAUTION! Never expose the image drum unit to light for more than 5 minutes. Never expose the image drum unit to direct sunlight. Always hold the image drum unit by the ends or from the top. Never touch the surface of the green drum inside the image drum unit.
3. Carefully lift out the image drum, complete with the toner cartridge. Be careful not to touch or scratch the green drum surface.
4. Remove any jammed sheets from the paper path.
5. Re-install the image drum complete with toner cartridge, ensuring that it correctly locates into the slots on each side of the printer.
6. Close the top cover and press down to latch it closed.
7. The printer will warm up and commence printing when ready. he page lost through the jam will normally be reprinted.
NOTE If the edge of the jammed paper protrudes (or can be seen) from the exit, reinstall the image drum, close the top cover and switch the printer on. Remove the jammed paper from the exit when the exit roller begins rotating after a few seconds after switching on. However, if the jammed paper cannot be removed, contact a service representative.
Mar 12, 2010 | OKI B4350 Laser Printer
How to fix paper jammed error of canon mp145
Please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
My canon mx310 keeps showing a paper jam alarm and there is no paper jam. how do I fix it?
give this a try
alternative :
Jun 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Paper jam /Message says Rec. Paper jam Open right cover
From right side of fax, open the toner door, remove the crg.unit, and look for paper, if not also from left side open the door and check for paper or broken parts in fixing unit.
May 21, 2009 | Canon FAX-L400 All-In-One Laser Printer
Canon MF3240 Paper Jam - No Real Jam
try this
alternative :
Dec 18, 2008 | Canon imageCLASS MF3240 All-In-One Laser...
PAPER JAM
laser printers dont use ink.
you will have to check the sensors. first the one where you put the media (paper) then check the registry one (remove the cartridge and you should see it) then the fixing on, from the back it has a small cover you can open an dthen a pair of green coloured levers to remove any jammed paper in fixing (the hot ***'y) then check the delivery sensor right where normally you see the page printed out and coming your way. there should not be any media remains anywhere. also if you copier is dirty it may also be causing this. try to clean it with compressed air.
Oct 29, 2008 | Canon imageCLASS D320 Digital Copier
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
103 people viewed this question
old marine
old marine
