Question about Bobcat Miller 225 Welder Generator 907209 Or 907210
Replaced bobcat225 motor with diffrent diesel need wireing for engine plug
Replaced engine with deautz 3 cyl diesel and need wireing from welder to engine
What is the cylinder order for a 4 cylinder toyota camry
It is 1-3-4-2 with No 1 being at the timing belt and crank pulley end.
Jun 09, 2014 | 2001 Toyota Camry
How to connect welder to a portable generator
There are many adaptors , form generator to other connectors, go to Ebay find out which one you need, most hardware stores have converter cables from generator to what you need, most adapters covert 240 to 120v 30 amp or 15 amp or 30amp to 50amp!
Apr 07, 2017 | Diesel Miller 907218 Trailblazer 302...
I need the part number for the termial output and ground for my 302 diesel Trailblazer and a part number for the starter motor for my 400P Big Blue Diesel. Also any suggestions on spare parts I should...
Hi:
Part number for the ground output terminal is MIL 039046, list price is $24.34.
For the Big Blue need to specify what engine/model does your machine has or serial number.
Aug 07, 2011 | Miller Trailblazer 302 Welder Generator...
Changed plugs and wires now it has no power and
You didn't post your engine size so please pick the applicable motor:
Firing order and spark plug wire installation for the 2.5L engine
Firing order and spark plug wire installation for the 2.0L engine
Jan 10, 2010 | 1999 Mercury Mystique
Put Diesel into tank but did not run
IS your car diesel I hope
3 things your car needs to run
GAS fuel in the engine or diesel
Air air to reach the fuel to ignite it
Spark check for spark ,
unless your diesel than spark is not needed as your engine work diffrent and produces spark by engine speed when cranking and compression of both mixes above
Last check the pump make sure its pumping fuel
Sep 24, 2009 | 2002 Saturn VUE
Need wireing diagram for 2002 dodge grand caravan
------>>>FRONT>>>>of Van >>>>
______________________________
#5 cyl #6 cyl
#3 cyl #4 cyl
#1 cyl #2 cyl
_________________
I COIL BLOCK I
I I
I #3 #1 #5 I
I I
I I Firing Order Is
I I 1 2 3 4 5 6
I #6 #4 #2 I
I _______________I_
the Wires Go Accordingly to prospective Terminals, So Sorry Unable to Send Pics through FixYa, A Formating Problem Exists
and they show on my end but not on your end this is TRUE and CORRECT To The BOOK other than the Lines from Coil to Spark Plug ENDS at CYLINDERS. Please dont Forget to RATE Me
Thank You And Happy Motoring!!
Mar 27, 2009 | 2002 Dodge Grand Caravan
Dead cylinders 2003 sebring
it sounds like you may have the wires on the wrong coil. It should be #1 on the #4 coil, and the #3 wire on the #2 coil. you probably have them backwards so 1 and 3 are firing on the exhaust stroke.
the firing order is 1-3-4-2.
they should be hooked like this.
Jan 23, 2009 | 2003 Chrysler Sebring
Keeps mis-firing on cylinder #3 check engine light flashes and stays on car chugs on uphill slopes
check plugs wires for damage or just replace if you have replaced the #3 plug already if not replace it also
Aug 04, 2008 | 1999 Ford Taurus
Bobcat Miller  225 Welder Generator 907209 Or 907210 Logo
53 people viewed this question
Top Bobcat Welding Tools Experts
Troy
Troy
Level 1 Expert
Lawrence Oravetz
Timllfixit
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
