Question about Paradise Basic EGA
My computer not reading the EGA on my 2004 saturn vue so not able to pass inspection
Clean the unit
2003 Vie Saturn computer wiped out and can not pass VA inspection. What to do?
You need to drive normally for two weeks and then return for testing. They should have explained that. The data is only removed if you disconnect the battery or have had a flat battery.
Dec 01, 2015 | 2003 Saturn VUE
2002 Saturn VUE Gas gauge reads empty with a full tank of gas. What is problem?
possible blowen fuse or a bad sending unit inside fuel tank also check the connections at the tank
Jul 27, 2012 | 2002 Saturn VUE
My 2004 saturn vue had unwanted acceleration!!
get the insurance company and Saturn involved ASAP.
Jun 10, 2010 | 2004 Saturn VUE
OBDII COMMUNICATION FAILURE
If your engine light is coming on, then there is a code somewhere in the computer,it may be a pending code.Its possible your computer is bad. Have your computer tested.
Apr 09, 2010 | 2003 Saturn VUE
Check engine light is on in 2004 Saturn Vue
Take your Vue to a local parts store like AutoZone and they will read the codes for free and will also recommend what may fixit.
Nov 27, 2009 | 2004 Saturn VUE
Check engine light 2005 Saturn Vue
the scan tool that you are using will not read codes from all of the modules. take the car to a gm dealer to have it checked with a tech2
Apr 03, 2009 | 2005 Saturn VUE
Cel on a 04 saturn vue
Disconnect your battery. touch the neg. and positive cables together for a second. let it sit for at least an hour. that should reset everything. as far as reading codes you would need a scanner. on OBD-1 cars you could use a paper clip and flash the codes. but on OBD-II you need a scanner
Jan 21, 2009 | 2004 Saturn VUE
Anti lock brakes
2006 Saturn VUE AWD, same issue - only it was very intermittant and happened at very slow braking (like rolling to a stop sign) when it kicked in. Turned out it too was the wheel speed sensor. Although I had to take it to the dealership 2x, the first time they checked engine codes with no avail, and a visual inspection didn't show anything either. It was only when I happened to take it there on a day that it was happening frequently. They actually had to hook up the diagnostic computer, drive around, and get readings from the speed sensor to confirm it was shot.
Jan 04, 2009 | 2004 Saturn VUE
Paradise Basic EGA Logo
42 people viewed this question
Top Paradise Computers & Internet Experts
David Payne
David Payne
Are you a Paradise Computer and Internet Expert? Answer questions, earn points and help others
