Question about Home Security
Have a Pelco KND300A joystick to control PTZ cameras. Were working great and the lost control to ALL my PTZ cameras. Nothing unplugged and can still change from camera to camera but cannot control them. How do I fix this?
My ptz camera gives the video in a night vision mode yet its daytime why?
in the menu there is an option for day and night mode, check the settings it is probably on night mode. if it is on auto switch it to day mode.
Oct 28, 2013 | Pelco DF8CB Pg 1V21A Domepak Pendant Color...
PTA cameras wandering on their own
check if the Auto Pan setting is enabeld. if not the joystick on your PTZ Controller might be faulty. open the unit up and check for any dust build up on the joystick area.
Aug 26, 2013 | Pelco KBD960 Full-Functionality, Desktop...
Spin out of control
Reset the power to the camera and test first.
If it worked before you may have a wiring fault... or if it is new or someone tampered with it, the baud rate settings or protocol setting might have changed.
Apr 03, 2012 | Pelco CONTROLLER MATRIX- PTZ CONTROL
Does it supports any brand of cctv cameras or will there be any incompatibility with same brand..
It support all brand of CCTV.
for PTZ CCTV, It has to have the Pelco protocol so the WJ-HD716 can control the camera.
in that case, the connection will use the RS485.
Oct 19, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
I have a Pelco Spectra mini in a warehouse, we replaced the previous camera with this new one but the PTZ function does not work. The old camera worked for while and stopped. We moved the new one to...
Hi. Did you call Pelco's customer support? They should be able to talk you through troubleshooting the camera to at least determine if this is a defective camera or not.
Aug 18, 2009 | Cameras
On the monitor there is a small little camera
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} That is not coming from the camera...They don't put anything like that out. Check the OSD settings of the device the video is going into. If there is On Screen Display setting with in the device (DVR, MUX, Matrix Switch, ECT)....if that doesn’t work then check the monitor menu to see if its a display feature you can turn off...good luck and let me know if this helps just remember the pelco camera will not push any graphic out except in the case of a PTZ where you will see the Protocol information text...
Jul 09, 2009 | Pelco DF8CB Pg 1V21A Domepak Pendant Color...
Why the Pelco spectro mini PTZ camera getting stuck(not rotating)
Normallay when getting stuck in Mini dome, we found 2 common problem.
1. Take out the cover and test rotating. Dome are deflect and causing resistance between camera dome and bubble.
2. The 2 screw are too tight. Loosen abit and try rotate.
Jun 03, 2009 | Pelco DF8CB Pg 1V21A Domepak Pendant Color...
I have an exterior pelco PTZ camera and the screen shows all Q's
The model number can be found on the back side of the dome drive and it would help to pull it out of the back box any way so you can cycle power to the dome drive....If the Q's do not go away call 1-800-289-9100 24/7 and you will get a live person in tech support and they can issue an RA number for repair....the estimate is free you just have to pay the shipping....Pelco is the best when it comes to warranty's and bending the rules for the customer on them....let me know if this helps and good luck
May 11, 2009 | Pelco DF8CB Pg 1V21A Domepak Pendant Color...
Pelco Spectra III PTZ camera wrong fuse?
It is replaceable, as long as no harm has come to the rest of the camera.
Mar 14, 2009 | Pelco SD53C22 Smw 0 Spectra III Se White...
Installing a pelco ptz camera using my old controller
pelco cctv ptz doec not moving can you give me a solution?thanks a lot.
Aug 18, 2008 | Cameras
Home Security Logo
94 people viewed this question
Top Home Security Experts
Are you a Home Security Expert? Answer questions, earn points and help others
