We just got a new elements TV. When we try to hook up the smart cycle we can put the red/white cables in the matching color connections. The yellow has to go into the green connection but the video will not display. The cords are working as we can bring up the DVD player. Any tips on getting the smart cycle to work?
  • Televison & ... Master
  • 5,427 Answers
The green RCA port has a red and a blue RCA port nearby, so you are connected to a component video port. Your TV can't interpret the composite video feed because it is looking for the other two parts of the video signal.
Some Elements TVs only have one composite TV input. Look at your DVD player and check if it has a component video output or perhaps an HDMI output. If it does, get the appropriate video cable and switch it over to a different input on the TV. Then connect the Smart Cycle to the composite video input on the TV. If you need to get a cable, try an online store that specializes in cables. Monoprice.com is a good source and their prices are much lower than the big box electronics stores.
The other options you can use:
1) If you have a DVD recorder, plug the Smart Cycle composite video cable into the (or one of the) DVD's line in ports. Then set the DVD to the appropriate line in and the TV to the composite input when your child wants to use the Smart Cycle.
2) Get a composite video switch or a signal converter (like a composite to RF converter). Then connect the devices as needed to the switch or converter and then to appropriate ports on the TV.
(For the switch, you would connect both the DVD player and the Smart Cycle to the switch and then the switch output to the composite video port on the TV. For an example switch, see http://www.walmart.com/ip/SIIG-4-x-1-Composite-Video-and-Audio-Switch/16606752 . This model will let you switch between 4 composite video devices.)
I hope this helps.
Posted on Nov 30, 2014
  • 2 more comments
  • Mel bolt Nov 30, 2014
    The smart cycle comes with red/white/yellow and the cables are hard wired to the Fisher price smart cycle. They can't be changed.
  • Cindy Wells Nov 30, 2014
    That's why I suggested changing the DVD player's cables or using a composite video switch. Many DVD players have component video and HDMI outputs. Using either HDMI or component cables between the DVD player and the TV will also let you see HD video resolution (at least 720p) from your DVD player. Composite video is 480i. Please add a comment with the DVD player model and the TV model. Then I'll be able to tell if the alternative cables or the composite video switch will work best for your use. The other option is to unplug the DVD player's composite video cable from the TV every time your child wants to use the Smart Cycle. Then you plug in the Smart Cycle's A/V cable to the TV's composite video port. Repeating this cycle at every device change would be frustrating. Cindy Wells
    My statement was the DVD player works fine with the avi cables so I know the cables and TV are functioning properly. The DVD player was used to test the TV and cables. The smart cycle, using the working avi cables and the working avi input does not work. The DVD player is a non issue. The problem is with the smart cycle. The smart cycle works on other TV but not the brand new elements TV. I think it has to do with the video input. There is no yellow input, there is only a green. The TV manual says to use the green for the yellow input. Do I possibly need a green cable?
    Which model TV is this? I've never heard of any that used a green port for the yellow composite video. There are some TVs that use 3-1 RCA plug reducing adapters. However those still have composite video or audio only to a yellow port. The green port gets the three component video cables connected. Based on your additional information, I think you temporarily connected the DVD player to the TV and the DVD's composite video output went into the green port on the TV. Then you unplugged the DVD player; I thought you had both devices plugged in full-time and should swap the inputs being used. In that case, I'd check if the Smart Cycle's yellow cable is connecting firmly to the port. If it's at all loose, the signal would be uninterpretable. The other possibilities are slight damage to the cable or interference. Damage could mean the wire doesn't conduct the signal through a bend as it is routed between the TV and the Smart Cycle. This might not have happened on a TV with the inputs in a slightly different configuration. Try smoothing out any twists or places where the cable forms a loop. If the power cord (or another source of interference) is very close to the video input, you might also need a Ferrite core placed around the wire (possibly two one at each end) to prevent the interference. The DVD player's A/V cable may have better shielding. Here's one ferrite core designed to snap around an existing cable:http://www.amazon.com/Ferrite-Core-Cord-... . I hope this helps. Cindy Wells
    New Friend:
  • 87 Answers
Use the newer type connectors, you'll lose quality otherwise.
Trying to connecting my Bose lifestyle to my Samsung led smart tv to play a DVD with a yellow video cord and picture is blurry and double and has jo color? Any ideas how to fix Bose lifestyle is older...
Without the specific LifeStyle model # it's not easy to say for sure, but it sounds like you might have a composite cable plugged into a component video output of the Bose. Assuming it does not have HDMI output, it might have white/red/yellow (RCA-type jacks, aka "phono") and that yellow jack is a composite video output. It would plug into the same color jack on the TV. There are also RGB (Red/Green/Blue) component outputs on many devices and similar inputs on the TV, so you have to match like color out to same color in and make sure the TV is set to composite video input, not HDMI nor component.
Also could just be a bad cable. It's always the cheap things that we overlook, so with the same output/input setup, assuming you match type, try a different cable. The actual color of the end on the cable does not matter, but don't plug a yellow-colored output jack to a red, white, blue or green input jack on the TV - that won't work.
Feb 18, 2015 | Samsung Televison & Video
Connect a Wii to VCR
Hello
Take the Wii's audio/video cable and the power cord and hook them up in the back of the Wii.
Take the Wii's audio/video cable and plug it into the 'audio-in and video-in sockets on your VCR.Make sure you match the cable colors with the input colors.i.e white goes with white,yellow with yellow and red with red.
Take the RCA cable which looks like the picture below,
and plug one end of this audio/video cable into the 'audio out' and 'video out' ports on the VCR.Make sure the cable and ports colors match.
Now take the other end of the RCA cable and plug into the 'audio in' and 'video in' ports on your TV.Again make sure you match the color connections.
Hope it helps.
Ken
Jan 22, 2012 | Nintendo Wii Console
Can't hook vcr to tv
on the back of your VCR there will be a yellow colored port - most likely labeled "OUT" as well as possibly a white/red pair of ports.
The yellow is for a VIDEO hookup, the white and red are for AUDIO hookups.
These ports use what is called an RCA type connection.
Radio Shack, or just about any department store should be able to sell you an inexpensive set of RCA cables.
now on the back of the TV (possibly on the side) you will also have the yellow, white and red ports.
Hook one end of the RCA cable to the colored ports on the VCR, the other end of the cable to the colored ports on the TV.
last thing - the TV most likely has multiple inputs. there is probably a input button on the TVs remote, you need to press that button to cycle through the inputs until you get to the one the VCR is hooked up to.
its easiest to put a tape in the VCR and press play - when you get to the right input, you will see your tape...
good luck
Apr 05, 2010 | Dynex DX-L32-10A 32" LCD HDTV
Can't not get our Nintendo 64 to work on our new Bravia TV
The Nintendo 64 sends out a signal that can only be properly decoded by old CRT TV's
Those Bravia TV's are the God's TV's even if they did work on it I wouldn't recommend it because it would most definitely eventually ruin the life span of your TV.
But to answer your Question the Cables should be plugged into AV1 which is the Red White and Yellow Connections
Nov 22, 2009 | Nintendo 64 Console
Hook up of dvd to tv
hey I think you need to use component cables blue green red from the player to the tv, make sure the blue green red ports are also on the tv, note: red yellow white composite cable will not interchange with blue green red component cable or connection.
simplify- blue green red= component
red white yellow=composite
*wires must match colors on both tv and player inputs.
then set your input on your tv to where you conected the cable.
Jun 15, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
I don't know where to put the yellow, red and white connectors on the TV or the dvw
look on the back of your flat screen , there is a panel with inputs , example: VIDEO 1 , VIDEO 2 , etc. , connect your yellow , red & white from the DVD COMBO to video 1 (input) there colored to match with your cable , yellow w/ yellow , red w/ red , white w/ white , hope this helps AJ
May 08, 2009 | Sanyo DVW-6100 DVD Player/VCR
Hook up Memorex MVD4544 DVD/VCR combo
ok on the back of the dvd player look for the yellow red and white plugs you should have gotten a cable with yellow white and red plugs match the colors from the dvd player to the colors on the back of the tv labeled VIDEO 1 then plug the power in and tune the tv to video 1
Mar 27, 2009 | Televison & Video
TRYING TO HOOK UP OLD RCA COMBO (DVD/VCR) TO MY NEW TV. USING THE RED/WHITE/YELLOW CABLES ALONG WITH PUTTING MY CABLE SIGNAL DIRECT INTO THE DVD/VCR PLAYER AND THEN CONNECTING THE OUT LINE TO THE NEW...
ok so what you need to do is put the cable from your cable provider/ antenna (or what ever you use)to the combo players CABLE IN connection.. then color match of the red yellow and white cables from the OUT on the combo to the IN on the TV your tv has to be set on AUX sometimes called L1 or L2 depending on your tv and which set of red yellow and white holes on the tv you use... your combo will also probably need to be turned on.. try that should work!
Oct 16, 2008 | RCA Televison & Video
Different sound to picture
When connecting VCR to TV. Verify all connections. First if the connection is with coaxial cable make sure you signal from outside is screwed to the cable input on VCR. Then the VCR/TV output has the cable running to TV input. If hooking up with RCA cables , which is the yellow, red, and white cables. Hook one side up to VCR output. Yellow for Video, while red/white to audio output matching the colors. The same is done to the Television input. yellow for video, red/white for audio. Do a test recording. Use a blank tape, not one already recorded on. Record about 5 minutes Stop recording , rewind and playback. You should see the difference.
Oct 13, 2008 | Televison & Video
How do we hook up the D.V.D. player to the T.V. We think we have done it correct but it does not play.
couple of ways but the easiest way would be connecting the video and audio out from DVD (need rca connections yellow red and white)
Yellow --- Video
white and red is audio out left and right.
find in your tv set inputs with similar colors its going to be input 1
or input 2 (as an example)
once you conect the cable matching colors yellow to yellow red to red and white to white make sure you select the same input on your set (video 1 or 2) that its throu input selection in remote control from tv or set itself.
Jul 03, 2008 | Televison & Video
Televison & Video Logo
180 people viewed this question
Top Televison & Video Experts
